楼主: alei643
[教程系列] Node Red系列教程之三 实现Node Red与Home Assistant之间的联动
发表于 2020-4-29 10:55:13 | 显示全部楼层
发表于 2020-4-29 14:44:28 | 显示全部楼层
谢谢,学习了
发表于 2020-5-1 07:41:25 | 显示全部楼层
学习一下
发表于 2020-5-1 23:16:39 | 显示全部楼层
流程由于缺少节点类型而停止。请检查日志的详细信息
server
server-state-changed
老是提示确实这2个节点,反复卸载安装还是一样的提示。
发表于 2020-5-1 23:21:24 | 显示全部楼层
1 May 15:19:40 - [info] Waiting for missing types to be registered:
1 May 15:19:40 - [info]  - server
1 May 15:19:40 - [info]  - server-state-changed
发表于 2020-5-1 23:24:50 | 显示全部楼层
装了几遍都是这样,郁闷
发表于 2020-5-1 23:55:49 | 显示全部楼层
1 May 15:52:37 - [warn] ------------------------------------------
1 May 15:53:00 - [info] Installing module: node-red-contrib-home-assistant-websocket, version: 0.22.3
1 May 15:54:24 - [info] Installed module: node-red-contrib-home-assistant-websocket
1 May 15:54:26 - [info] Added node types:
1 May 15:54:26 - [info]  - node-red-contrib-home-assistant-websocket:server : SyntaxError: Unexpected token ...
1 May 15:54:26 - [info]  - node-red-contrib-home-assistant-websocket:server-events : SyntaxError: Unexpected token ...
1 May 15:54:26 - [info]  - node-red-contrib-home-assistant-websocket:server-state-changed : SyntaxError: Unexpected token ...
1 May 15:54:26 - [info]  - node-red-contrib-home-assistant-websocket:trigger-state : SyntaxError: Unexpected token ...
1 May 15:54:26 - [info]  - node-red-contrib-home-assistant-websocket:poll-state : SyntaxError: Unexpected token ...
1 May 15:54:26 - [info]  - node-red-contrib-home-assistant-websocket:ha-webhook
1 May 15:54:26 - [info]  - node-red-contrib-home-assistant-websocket:api-call-service : SyntaxError: Unexpected token ...
1 May 15:54:26 - [info]  - node-red-contrib-home-assistant-websocket:ha-entity : SyntaxError: Unexpected token ...
1 May 15:54:26 - [info]  - node-red-contrib-home-assistant-websocket:ha-fire-event : SyntaxError: Unexpected token ...
1 May 15:54:26 - [info]  - node-red-contrib-home-assistant-websocket:api-current-state : SyntaxError: Unexpected token ...
1 May 15:54:26 - [info]  - node-red-contrib-home-assistant-websocket:ha-get-entities : SyntaxError: Unexpected token ...
1 May 15:54:26 - [info]  - node-red-contrib-home-assistant-websocket:api-get-history : SyntaxError: Unexpected token ...
1 May 15:54:26 - [info]  - node-red-contrib-home-assistant-websocket:api-render-template : SyntaxError: Unexpected token ...
1 May 15:54:26 - [info]  - node-red-contrib-home-assistant-websocket:ha-wait-until : SyntaxError: Unexpected token ...
1 May 15:54:26 - [info]  - node-red-contrib-home-assistant-websocket:ha-api : SyntaxError: Unexpected token ...
发表于 2020-5-2 00:44:49 | 显示全部楼层
好东西支持!!!!!!!!!!!!!!!!!!!!!
发表于 2020-5-2 08:03:44 | 显示全部楼层
搞定了,换了个版本的node-red就可以了
发表于 2020-5-3 23:29:10 来自手机 | 显示全部楼层
学习一下,感谢分享
GMT+8, 2026-1-14 11:52 , Processed in 1.296985 second(s), 18 queries , MemCached On.
