楼主: 冬瓜HA
冬瓜HAOS:panther-x2刷(支持NPU版)haos16.3.1版正式上线!
发表于 2024-6-27 17:01:47 | 显示全部楼层
wangyiyuan 发表于 2024-6-26 17:41
我感觉自己的已经刷砖了 你搞定的话教教我
你怎么感觉砖的? 我这个情况是不是也砖了
发表于 2024-6-27 19:42:50 | 显示全部楼层
我的好了
发表于 2024-6-28 09:41:18 | 显示全部楼层
厉害了 , 你怎么好的?
发表于 2024-7-1 01:54:53 | 显示全部楼层
Waiting for the Home Assistant CLI to be ready...
       ▄██▄           _   _
     ▄██████▄        | | | | ___  _ __ ___   ___
   ▄████▀▀████▄      | |_| |/ _ \| '_ ` _ \ / _ \
▄█████    █████▄    |  _  | (_) | | | | | |  __/
▄██████▄  ▄██████▄   |_| |_|\___/|_| |_| |_|\___|          _
████████  ██▀  ▀██      / \   ___ ___(_)___| |_ __ _ _ __ | |_
███▀▀███  ██   ▄██     / _ \ / __/ __| / __| __/ _` | '_ \| __|
██    ██  ▀ ▄█████    / ___ \\__ \__ \ \__ \ || (_| | | | | |_
███▄▄ ▀█  ▄███████   /_/   \_\___/___/_|___/\__\__,_|_| |_|\__|
Welcome to the Home Assistant command line.
System information
  IPv4 addresses for end0:  192.168.2.213/24
  IPv6 addresses for end0:  fe80::4bc5:f194:3a82:e5f6/64
  IPv4 addresses for wlan0:
  OS Version:               Home Assistant OS 12.3.3
  Home Assistant Core:      2024.6.4
  Home Assistant URL:       http://homeassistant.local:8123
  Observer URL:             http://homeassistant.local:4357
ha > login
root@homeassistant:/ # ha-install -t
  check package xiaomi_gateway3
    install package xiaomi_gateway3 (1/5)
patch begin.
    install package xiaomi_gateway3 (2/5)
  patch:true
patch end.
    install package xiaomi_gateway3 (3/5)
    install package xiaomi_gateway3 (4/5)
    install package xiaomi_gateway3 (5/5)
    install package xiaomi_gateway3 (5/5) failed
我这种怎么办没看到task end   执行了ha host reboot   用起来正常  但是心里有个病
发表于 2024-7-1 13:01:52 | 显示全部楼层
ha > login
  check addons core_configurator
    install addons core_configurator once. not install.
  check addons core_mosquitto
    install addons core_mosquitto once. not install.
  check addons fb59d657_nodered
    install addons fb59d657_nodered once. not install.
  check addons fb59d657_ssh
    install addons fb59d657_ssh once. not install.
addons end.
task end.
^C
过了半天 查询变这样了  好多没安装成功的  怎么让他再次安装? 但是我感觉使用是正常的
 楼主| 发表于 2024-7-1 18:52:01 | 显示全部楼层
sparkha 发表于 2024-7-1 13:01
ha > login
不影响你的使用的。
发表于 2024-7-2 09:44:55 | 显示全部楼层
今天Supervisor界面 一堆报错 奇怪了
 楼主| 发表于 2024-7-4 10:42:28 | 显示全部楼层
没出现这个问题,你重启一下以后呢?
发表于 2024-7-4 17:35:31 | 显示全部楼层
冬瓜HA 发表于 2024-7-4 10:42
没出现这个问题,你重启一下以后呢?
重启之后也不行  我自己尝试解决过了   还用了代理排除网络问题
 楼主| 发表于 2024-7-6 09:48:21 | 显示全部楼层
我联系你,我来看看。
GMT+8, 2026-1-11 05:30 , Processed in 0.168959 second(s), 15 queries , MemCached On.
