楼主: 冬瓜HA
树莓派3、4、5之冬瓜HAOS的16.3.2版推出
 火.. [复制链接]
 楼主| 发表于 2024-3-9 17:49:11 | 显示全部楼层
mychenfeng 发表于 2024-3-9 16:06
左侧没看见有hacs商店啊
添加集成———hacs
要激活才能显示出来的
 楼主| 发表于 2024-3-9 18:28:44 | 显示全部楼层
左侧没看见有hacs商店啊
这样操作
发表于 2024-3-9 22:43:47 | 显示全部楼层
找到hacs了
发表于 2024-3-9 23:44:28 | 显示全部楼层
装完xiaomi miot插件后出现错误,日志如下
日志: homeassistant.loader
来源: loader.py:1025
首次发生: 22:44:33 (36 全部发生)
上次记录: 23:39:45
Unexpected exception importing platform custom_components.xiaomi_miot_raw.sensor
Unexpected exception importing platform custom_components.xiaomi_miot_raw.binary_sensor
Unexpected exception importing platform custom_components.xiaomi_miot_raw.number
Unexpected exception importing platform custom_components.xiaomi_miot_raw.select
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1025, in _load_platform
    cache[full_name] = self._import_platform(platform_name)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1058, in _import_platform
    return importlib.import_module(f"{self.pkg_path}.{platform_name}")
  File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 995, in exec_module
  File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
  File "/config/custom_components/xiaomi_miot_raw/sensor.py", line 20, in <module>
    from .basic_dev_class import (
  File "/config/custom_components/xiaomi_miot_raw/basic_dev_class.py", line 63, in <module>
    class GenericMiotDevice(Entity):
  File "/config/custom_components/xiaomi_miot_raw/basic_dev_class.py", line 684, in GenericMiotDevice
    @asyncio.coroutine
AttributeError: module 'asyncio' has no attribute 'coroutine'. Did you mean: 'coroutines'?
第二个错误如下:
日志: homeassistant.setup
来源: setup.py:466
上次记录: 23:39:45
Unable to prepare setup for platform 'xiaomi_miot_raw.sensor': Platform not found (Exception importing custom_components.xiaomi_miot_raw.sensor).
Unable to prepare setup for platform 'xiaomi_miot_raw.binary_sensor': Platform not found (Exception importing custom_components.xiaomi_miot_raw.binary_sensor).
Unable to prepare setup for platform 'xiaomi_miot_raw.number': Platform not found (Exception importing custom_components.xiaomi_miot_raw.number).
Unable to prepare setup for platform 'xiaomi_miot_raw.select': Platform not found (Exception importing custom_components.xiaomi_miot_raw.select).
 楼主| 发表于 2024-3-10 09:34:55 | 显示全部楼层
这是xiaomi_miot_raw的。你用hacs装吧,或者删掉不用
还有,你安装时,最好开启加速器后下。
发表于 2024-3-10 16:19:57 | 显示全部楼层
我问个问题,树莓派4的系统是不是没做视频输出?启动到安装过程就虚像,字体明显错位。
 楼主| 发表于 2024-3-10 17:12:21 | 显示全部楼层
是标准的hdmi输出,虚像是显示器的兼容问题
发表于 2024-3-10 20:47:27 | 显示全部楼层
问题解决了,预备安装完毕后能正常显示,就很迷。。。
发表于 2024-3-11 14:58:08 | 显示全部楼层
还有,你安装时,最好开启加速器后下。
用HACS装xiaomimiot会自动安装xiaomimiotraw,这是什么原因
 楼主| 发表于 2024-3-11 16:07:34 | 显示全部楼层
这个就是raw
一般建议装xiaomi miot auto
GMT+8, 2026-1-13 00:28 , Processed in 0.383870 second(s), 9 queries , MemCached On.
