- 积分
- 251
- 金钱
- 195
- 威望
- 0
- 贡献
- 0
- HASS币
- 0
- 积分
- 251
- 金钱
- 195
- HASS币
- 0
发表于 2024-7-30 08:36:57
显示全部楼层
冬瓜大神,我用irtualbox安装冬瓜haos,启动后,提示这个画面,请帮忙看看,我不知道如何上传图片,只能复制提示内容
Kernel driver not installed (rc=-1908)
The VirtualBox Linux kernel driver is either not loaded or not set up correctly. Please try setting it up again by executing
'/sbin/vboxconfig'
as root.
If your system has EFI Secure Boot enabled you may also need to sign the kernel modules (vboxdrv, vboxnetflt, vboxnetadp, vboxpci) before you can load them. Please see your Linux system's documentation for more information.
where: suplibOsInit what: 3 VERR_VM_DRIVER_NOT_INSTALLED (-1908) - The support driver is not installed. On linux, open returned ENOENT. |
