楼主: lichao622
[技术探讨] 非米家人体传感器如何接入米家联动场景?
发表于 2024-3-26 12:34:37 | 显示全部楼层
mrjc0331 发表于 2024-3-26 00:02
大佬,请问你用的是多模网关1还是2,我买了一个6500pro,打开中枢网关后,加上多模网关1在getway3里只能 ...
多模1  多模2都有
发表于 2024-3-26 18:20:00 | 显示全部楼层
mars.z 发表于 2024-3-26 12:34
多模1  多模2都有
昨天折腾了一晚上,今天买了个多模2,结果HA重启下就行了。。。
发表于 2024-4-21 15:01:02 | 显示全部楼层
mars.z 发表于 2024-1-18 16:20
米家型号是 https://home.miot-spec.com/s/linju.switch.sw0a01 卖家店里卖的叫什么灵动增强款。
Ha这边 ...
改了下可以在最新的版本上用
from custom_components.xiaomi_gateway3.core.devices import *
DEVICES = [{
    12261: ["linju", "Lingju Bluetooth Mesh Switch", "(linju.switch.sw0a01)"],
    "spec": [
        BaseConv("switch", "switch", mi="2.p.1"),  # bool
        BoolConv("指示灯开关", "switch", mi="3.p.2"),
        BoolConv("R脚辅助开关", "switch", mi="3.p.6"),
        MapConv("灵动模式", "select", mi="3.p.4", map={
            0: "关闭", 1: "开启"
        MapConv("通电后默认状态", "select", mi="2.p.2", map={
            0: "恢复断电前状态", 1: "开启", 2: "关闭"
        MapConv("互控功能", "select", mi="3.p.3", map={
            1: "互控", 2: "解控"
        MapConv("icon-style", "select", mi="3.p.5", map={
            0: "灯泡", 1: "射灯", 2: "吸顶灯", 3: "吊灯", 4: "灯带", 5: "小家电", 6: "插座", 7: "阀门", 8: "电机"
}] + DEVICES
aska 手机认证
发表于 2024-11-23 02:59:21 | 显示全部楼层
感谢,正好需要
发表于 2024-12-21 08:01:24 | 显示全部楼层
mark一下
GMT+8, 2026-1-14 14:36 , Processed in 0.778651 second(s), 11 queries , MemCached On.
