楼主: fentensoft
[经验分享] 当贝投影仪通过ESP32接入HA方案,代码已开源
发表于 2024-1-25 10:05:17 | 显示全部楼层
纯小白,楼主能不能分享下代码怎么烧录到ESP32
发表于 2024-1-25 12:05:18 | 显示全部楼层
我觉得坚果投影仪应该也能用
发表于 2024-3-11 22:12:04 | 显示全部楼层
大佬,你好,我现在发送关闭命令的时候显示包是{0x02,0x01,0x2e,0x00,0x0a,0x00,0x04,0x00,0x1b,0x1b,0x00,0x00,0x00,0x66,0x00,0x00,0x00,0x00},0X1B00如何改为0x3600呢
发表于 2024-3-11 22:14:50 | 显示全部楼层
fengqiluoye 发表于 2024-3-11 22:12
大佬,你好,我现在发送关闭命令的时候显示包是{0x02,0x01,0x2e,0x00,0x0a,0x00,0x04,0x00,0x1b,0x1b,0x00, ...
from machine import Pin
from machine import Timer
from time import sleep_ms
import bluetooth
BLE_MSG = ""
KEYBOARD_REPORT = bytes([    # Report Description: describes what we communicate
    0x05, 0x0c, 0x09, 0x01, 0xa1, 0x01, 0x85, 0x01, 0x19, 0x00, 0x2a, 0x9c,
    0x02, 0x15, 0x00, 0x26, 0x9c, 0x02, 0x95, 0x01, 0x75, 0x10, 0x81, 0x00,
    0x09, 0x02, 0xa1, 0x02, 0x05, 0x09, 0x19, 0x01, 0x29, 0x0a, 0x15, 0x01,
    0x25, 0x0a, 0x95, 0x01, 0x75, 0x08, 0x81, 0x40, 0xc0, 0xc0, 0x06, 0x01,
    0xff, 0x09, 0x01, 0xa1, 0x02, 0x85, 0x05, 0x09, 0x14, 0x75, 0x08, 0x95,
    0x14, 0x15, 0x80, 0x25, 0x7f, 0x81, 0x22, 0x85, 0x04, 0x09, 0x04, 0x75,
    0x08, 0x95, 0x01, 0x91, 0x02, 0xc0, 0x05, 0x01, 0x09, 0x06, 0xa1, 0x01,
    0x85, 0x0a, 0x75, 0x01, 0x95, 0x08, 0x05, 0x07, 0x19, 0xe0, 0x29, 0xe7,
    0x15, 0x00, 0x25, 0x01, 0x81, 0x02, 0x95, 0x01, 0x75, 0x08, 0x81, 0x01,
    0x95, 0x05, 0x75, 0x01, 0x05, 0x08, 0x19, 0x01, 0x29, 0x05, 0x91, 0x02,
    0x95, 0x01, 0x75, 0x03, 0x91, 0x01, 0x95, 0x06, 0x75, 0x08, 0x15, 0x00,
    0x26, 0xff, 0x00, 0x05, 0x07, 0x19, 0x00, 0x29, 0xff, 0x81, 0x00, 0xc0,
class ESP32_BLE():
    def __init__(self, name):
        self.led = Pin(2, Pin.OUT)
        self.timer1 = Timer(0)
        self.name = name
        self.ble = bluetooth.BLE()
        self.ble.active(True)
        self.ble.config(gap_name=name)
        self.disconnected()
        self.ble.irq(self.ble_irq)
        self.register()
        self.advertiser()
    def connected(self):
        self.led.value(1)
        self.timer1.deinit()
    def disconnected(self):
        self.timer1.init(period=100, mode=Timer.PERIODIC, callback=lambda t: self.led.value(not self.led.value()))
    def ble_irq(self, event, data):
        global BLE_MSG
        if event == 1: #_IRQ_CENTRAL_CONNECT 手机链接了此设备
            self.connected()
        elif event == 2: #_IRQ_CENTRAL_DISCONNECT 手机断开此设备
            self.advertiser()
            self.disconnected()
        elif event == 3: #_IRQ_GATTS_WRITE 手机发送了数据
            pass
            #buffer = self.ble.gatts_read(self.rx)
            #BLE_MSG = buffer.decode('UTF-8').strip()
    def register(self):
        HIDS = (
            bluetooth.UUID(0x1812),                     # Human Interface Device
                (bluetooth.UUID(0x2A4A), bluetooth.FLAG_READ),       # HID information
                (bluetooth.UUID(0x2A4B), bluetooth.FLAG_READ),       # HID report map
                (bluetooth.UUID(0x2A4C), bluetooth.FLAG_WRITE),      # HID control point
                (bluetooth.UUID(0x2A4D), bluetooth.FLAG_READ | bluetooth.FLAG_NOTIFY, ((bluetooth.UUID(0x2908), 1),)),  # HID report / reference
                (bluetooth.UUID(0x2A4D), bluetooth.FLAG_READ | bluetooth.FLAG_WRITE,  ((bluetooth.UUID(0x2908), 1),)),  # HID report / reference
                (bluetooth.UUID(0x2A4E), bluetooth.FLAG_READ | bluetooth.FLAG_WRITE), # HID protocol mode
       self.services = (HIDS,)
       self.handles = self.ble.gatts_register_services(self.services)
    def send(self, data):
        self.ble.gatts_notify(0, self.h_repin, data)
    def advertiser(self):
           #设置BLE广播数据并开始广播
        self.ble.gap_advertise(100, adv_data = b'\x02\x01\x06'
                                        + b'\x03\x03\x12\x18' #HID UUID
                                        + b'\x03\x19\xC1\x03' #设备外观为键盘
                                        + b'\x0D\x09' + "ESP Keyboard".encode("UTF-8"))
        (self.h_info, self.h_map, _, self.h_repin, self.h_d1, self.h_repout, self.h_d2, self.h_model,) = self.handles[0]
        # Write service characteristics
        self.ble.gatts_write(self.h_info, b"\x11\x01\x00\x01")     # HID info: ver=1.1, country=0, flags=normal
        self.ble.gatts_write(self.h_map, KEYBOARD_REPORT)    # HID input report map
        self.ble.gatts_write(self.h_d1, b"\x01\x01")  # HID reference: id=1, type=input
        self.ble.gatts_write(self.h_d2, b"\x01\x01")  # HID reference: id=1, type=output
        self.ble.gatts_write(self.h_model, b"\x01")   # HID Protocol Model: 0=Boot Model, 1=Report Model
if __name__ == "__main__":
    ble = ESP32_BLE("ESP32BLE")
    key = Pin(0,Pin.IN)#IO 0 用作按键
    while True:
        if key.value() == 0:
            while key.value() == 0:
              pass
            print("11111")
            ble.send(b'\x00\x00\x66\x00\x00\x00\x00')
            sleep_ms(750)
            ble.send(b'\x00\x00\x00\x00\x00\x00\x00')
这是我使用thony编写的代码,感觉都一样的,但是抓到的数据确实有问题的
发表于 2024-3-26 18:30:56 | 显示全部楼层
66666看看
发表于 2024-10-23 11:26:07 | 显示全部楼层
测试当贝F3能抓到Manufactor Data,报文格式   :  | 4600(供应商) | XX(每次自增1)  |    MAC地址倒序  | FFFFFFFF  ,ESP写入,监听的报文和遥控器是完全一致的, 但是广播就是无法开机, 手机蓝牙模拟也是无法开机, 不知道是不是还有条件
发表于 2025-10-16 10:12:32 | 显示全部楼层
你的Manufactor Data这个报文是固定的吗?没有加密吗
GMT+8, 2026-1-16 09:29 , Processed in 0.490619 second(s), 10 queries , MemCached On.
