楼主: fentensoft
[经验分享] 当贝投影仪通过ESP32接入HA方案,代码已开源
发表于 2023-12-19 19:34:33 | 显示全部楼层
shenmirenQUQ 发表于 2023-12-19 18:12
极米z6x,看大佬的帖子,https://bbs.hassbian.com/thread-16308-1-1.html,
实现了抓包用 安卓手机发送蓝 ...
我的刚好也是极米,ESP32用esphome是实现不了蓝牙广播的,只有用Arduino刷,以下是代码,开机就发送一次广播,收到MQTT消息为22也发送一次,可以整合进HA里
#include <Arduino.h>
#include <NimBLEDevice.h>
#include <NimBLEAdvertisedDevice.h>
#include "NimBLEEddystoneURL.h"
#include "NimBLEEddystoneTLM.h"
#include "NimBLEBeacon.h"
#include <WiFi.h>
#include <PubSubClient.h>
const char *ssid = "k";
const char *password = "passwd";
const char *mqtt_server = "192.168.1.62";
const char *topic = "ble/open";
const char *mqtt_username = "idummy";
const char *mqtt_password = "passwd";
WiFiClient espClient;
PubSubClient client(espClient);
const int blueLedPin = 2;
BLEAdvertising *pAdvertising;
bool mqttMessageReceived = false;
void callback(char *topic, byte *payload, unsigned int length)
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  // Print payload
  for (int i = 0; i < length; i++)
    Serial.print((char)payload[i]);
  Serial.println();
  // 将 payload 转换为字符串
  String receivedMessage = "";
    receivedMessage += (char)payload[i];
  // 检查 payload 内容是否为 "22"
  if (receivedMessage == "22") {
    Serial.println("Received message is '22'. Sending BLE broadcast.");
    publishBLE();
void onBLEDataReceived(const char *data)
  Serial.print("Received BLE data: ");
  Serial.println(data);
void setup()
  Serial.begin(115200);
  connectWiFi();
  setupBLE();
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
void loop()
  if (WiFi.status() != WL_CONNECTED)
    connectWiFi();
  if (!client.connected())
    reconnect();
  client.loop();
  delay(1000);
void connectWiFi()
  Serial.println("Connecting to WiFi");
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    delay(1000);
    Serial.println("Connecting...");
  Serial.println("Connected to WiFi");
void setupBLE()
  NimBLEDevice::init("MyESP32");
  NimBLEServer *pServer = NimBLEDevice::createServer();
  pAdvertising = pServer->getAdvertising();
  NimBLEAdvertisementData advertisementData;
  advertisementData.setFlags(0x06);
  advertisementData.setManufacturerData({0x46, 0x00, 0x08, 0x36, 0xc9, 0x54, 0xa4, 0x23, 0x60, 0xFF, 0xFF, 0xFF, 0x30, 0x43, 0x52, 0x4B, 0x54, 0x4D});
  pAdvertising->setAdvertisementData(advertisementData);
  pAdvertising->start();
  delay(1000);
  pAdvertising->stop();
void reconnect()
  while (!client.connected())
    Serial.print("Attempting MQTT connection...");
    if (client.connect("ESP32Client", mqtt_username, mqtt_password))
      Serial.println("connected");
      client.subscribe(topic);
      mqttMessageReceived = false; // Reset the flag when reconnecting
    else
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      delay(5000);
void publishBLE()
  Serial.println("publishBLE: " + String(mqttMessageReceived));
  String bleData = "okokokok6";
  NimBLEAdvertising *pAdvertising = NimBLEDevice::getAdvertising();
  delay(1000);
  client.publish(topic, bleData.c_str());
发表于 2023-12-19 20:17:45 | 显示全部楼层
idummy 发表于 2023-12-19 19:34
我的刚好也是极米,ESP32用esphome是实现不了蓝牙广播的,只有用Arduino刷,以下是代码,开机就发送一次 ...
我也是极米,能不能步骤稍微写下,
发表于 2023-12-19 21:41:24 来自手机 | 显示全部楼层
参照https://bbs.hassbian.com/thread-16308-1-1.html拿到广播数据,有二处,在我的代码内相应按照格式更改你的广播数据,比如我的极米rs pro广播数据<46000836 c954a423 60ffffff 3043524b 544d>,更改wifi 及mqtt设置,mqtt订阅/ble/open 数据22,用arduino刷进esp32即可
发表于 2023-12-20 01:14:50 | 显示全部楼层
我修改你的代码 适用于当贝就  关闭使用adb命令关机
#include <WiFi.h>
const char *ssid = "JDCwifi_404";
const char *password = "adminadmin";
const char *mqtt_server = "192.168.68.149";
const char *mqtt_username = "mqtt";
const char *mqtt_password = "mqttt";
  Serial.print("] ");
  // Print payload
  Serial.println();
  // 将 payload 转换为字符串
    publishBLE();
void setup()
  connectWiFi();
  setupBLE();
void loop()
    connectWiFi();
    reconnect();
  client.loop();
  delay(1000);
void connectWiFi()
    delay(1000);
void setupBLE()
  advertisementData.setManufacturerData({0x46, 0x00, 0x7c, 0x9f, 0x73, 0x3d, 0x04, 0xc8, 0x38, 0xff, 0xff, 0xff, 0xff});
  delay(1000);
void reconnect()
    else
      delay(5000);
void publishBLE()
  delay(1000);
发表于 2023-12-20 01:18:59 | 显示全部楼层
adb关机 adb shell reboot -p
发表于 2023-12-25 15:58:06 | 显示全部楼层
我的明基来电开机,关机用的是红外
发表于 2024-1-16 17:07:59 | 显示全部楼层
ManufacturerData 这串实际上是投影仪的蓝牙地址 大小端反转下
发表于 2024-1-17 13:01:44 | 显示全部楼层
有esp32 yaml抄作业吗?想蓝牙控制电视盒子开关机
发表于 2024-1-18 15:38:59 | 显示全部楼层
真是个好文章,解开了我长久以来的疑问,当贝投影的遥控器是怎么开机的,没发觉它的遥控器有红外发射装置
不知道纯靠python能不能发Manufacturer Data包让投影开机
发表于 2024-1-18 15:56:06 | 显示全部楼层
我也是当贝F3 AIR  眼睛看懂了 脑子还没懂
GMT+8, 2026-2-1 15:40 , Processed in 0.780333 second(s), 11 queries , MemCached On.
