楼主: bugensui
[基础教程] 家庭智能电表方案esp8266
 火.. [复制链接]
发表于 2024-4-3 11:12:00 | 显示全部楼层
 楼主| 发表于 2024-4-3 12:04:45 | 显示全部楼层
fenglou777 发表于 2024-4-3 11:12
我这个数据算准吗?
很准了,我100元不到的电费,就会误差2块
发表于 2024-10-14 18:03:20 | 显示全部楼层
正需要,找哪家买?
 楼主| 发表于 2024-10-14 18:46:18 | 显示全部楼层
cdsinyh 发表于 2024-10-14 18:03
正需要,找哪家买?
咸鱼自己找找
发表于 2025-5-14 10:51:16 | 显示全部楼层
大佬,图片中那个当前阶梯情况百分比是怎么搞的?
发表于 2025-5-14 11:28:45 | 显示全部楼层
如何进入固件代码?
 楼主| 发表于 2025-5-14 11:35:51 | 显示全部楼层
自己写代码计算
{% if states("sensor.jin_nian_dian_liang") | float <= 2760 %}
           {{ (states("sensor.jin_nian_dian_liang") |round/2760*100)|round}}%、0%、0%
          {% elif states("sensor.jin_nian_dian_liang") | float >2760  and states("sensor.jin_nian_dian_liang") | float <= 4800 %}
          100%、{{ ((states("sensor.jin_nian_dian_liang") |round-2760)/2040*100)|round}}%、0%
          {% elif states("sensor.jin_nian_dian_liang") | float > 4800 %}
          100%、100%、{{(states("sensor.jin_nian_dian_liang") |round-4800)}}度
          {% endif %}
 楼主| 发表于 2025-5-14 11:36:24 | 显示全部楼层
cdsinyh 发表于 2025-5-14 11:28
如何进入固件代码?
没有看懂意思
发表于 2025-5-14 11:55:17 | 显示全部楼层
感谢感谢
发表于 2025-5-15 14:34:35 | 显示全部楼层
alias: 电价阶梯自动切换
description: 根据当前月份、用电量阶梯和峰谷时段自动切换电价
triggers:
  - entity_id: sensor.dang_qian_jie_ti
    trigger: state
  - at: "07:00:00"
    trigger: time
  - at: "23:00:00"
    trigger: time
conditions: []
actions:
  - choose:
      - conditions:
          - condition: template
            value_template: "{{ 5 < now().month < 11 }}"
          - condition: state
            state: "1"
          - condition: time
            after: "07:00:00"
            before: "23:00:00"
        sequence:
          - data:
              option: peak
            target:
              entity_id:
                - select.daily_use
                - select.monthly_use
                - select.yearly_use
            action: select.select_option
      - conditions:
          - condition: state
            state: "1"
          - condition: time
            after: "23:00:00"
            before: "07:00:00"
        sequence:
          - data:
              option: offpeak
            target:
              entity_id:
                - select.daily_use
                - select.yearly_use
      - conditions:
          - condition: state
            state: "2"
          - condition: time
            after: "07:00:00"
            before: "23:00:00"
        sequence:
          - data:
              option: peak2
            target:
              entity_id:
                - select.daily_use
                - select.yearly_use
      - conditions:
          - condition: state
            state: "2"
          - condition: time
            after: "23:00:00"
            before: "07:00:00"
        sequence:
          - data:
              option: offpeak2
            target:
              entity_id:
                - select.daily_use
                - select.yearly_use
      - conditions:
          - condition: state
            state: "3"
          - condition: time
            after: "07:00:00"
            before: "23:00:00"
        sequence:
          - data:
              option: peak3
            target:
              entity_id:
                - select.daily_use
                - select.yearly_use
      - conditions:
          - condition: state
            state: "3"
          - condition: time
            after: "23:00:00"
            before: "07:00:00"
        sequence:
          - data:
              option: offpeak3
            target:
              entity_id:
                - select.daily_use
                - select.yearly_use
      - conditions:
            value_template: "{{ not (5 < now().month < 11) }}"
          - condition: state
            state: "4"
          - condition: time
            after: "07:00:00"
            before: "23:00:00"
        sequence:
          - data:
              option: peak4
            target:
              entity_id:
                - select.daily_use
                - select.yearly_use
      - conditions:
          - condition: state
            state: "4"
          - condition: time
            after: "23:00:00"
            before: "07:00:00"
        sequence:
          - data:
              option: offpeak4
            target:
              entity_id:
                - select.daily_use
                - select.yearly_use
      - conditions:
          - condition: state
            state: "5"
          - condition: time
            after: "07:00:00"
            before: "23:00:00"
        sequence:
          - data:
              option: peak5
            target:
              entity_id:
                - select.daily_use
                - select.yearly_use
      - conditions:
          - condition: state
            state: "5"
          - condition: time
            after: "23:00:00"
            before: "07:00:00"
        sequence:
          - data:
              option: offpeak5
            target:
              entity_id:
                - select.daily_use
                - select.yearly_use
      - conditions:
          - condition: state
            state: "6"
          - condition: time
            after: "07:00:00"
            before: "23:00:00"
        sequence:
          - data:
              option: peak6
            target:
              entity_id:
                - select.daily_use
                - select.yearly_use
      - conditions:
          - condition: state
            state: "6"
          - condition: time
            after: "23:00:00"
            before: "07:00:00"
        sequence:
          - data:
              option: offpeak6
            target:
              entity_id:
                - select.daily_use
                - select.yearly_use
    default:
      - data:
          title: 电价切换异常
          message: 未匹配到有效的电价阶梯条件
        action: persistent_notification.create
mode: single
GMT+8, 2025-9-16 03:20 , Processed in 1.122976 second(s), 11 queries , MemCached On.
