查看: 8601|回复: 20
[技术探讨] Esphome+SmartIR控制格力空调各位大佬有没搭建成功的?
发表于 2023-8-27 21:20:13 | 显示全部楼层 |阅读模式
按照https://github.com/smartHomeHub/SmartIR/搭建捣鼓好多天还是不行,都快放弃了,
1、按哪个按键都无反应,按制冷开机,出现错误如下:
此错误来自自定义集成。
Logger: custom_components.smartir.climate
Source: custom_components/smartir/controller.py:183
Integration: SmartIR (documentation)
First occurred: 20:22:19 (1 occurrences)
Last logged: 20:22:19
Expecting value: line 1 column 1 (char 0)
  File "/config/custom_components/smartir/climate.py", line 382, in send_command
    await self._controller.send(
  File "/config/custom_components/smartir/controller.py", line 183, in send
    service_data = {'command':  json.loads(command)}
  File "/usr/local/lib/python3.11/json/__init__.py", line 346, in loads
    return _default_decoder.decode(s)
  File "/usr/local/lib/python3.11/json/decoder.py", line 337, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/local/lib/python3.11/json/decoder.py", line 355, in raw_decode
    raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
2、ESPHOME yaml 配置如下:
# Enable Home Assistant API
api:
  encryption:
    key: "RZomQkMqCX1mDf8Ig53ts4SDkpHxKN2Xtz74NgcpBiM="
  services:
    - service: send_raw_command
      variables:
        command: int[]
      then:
        - remote_transmitter.transmit_raw:
            code: !lambda 'return command;'
            carrier_frequency: 38k
    - service: send_samsung_command
      variables:
        command: string
      then:
        - remote_transmitter.transmit_samsung:
            data: !lambda 'return strtoll(command.c_str(), NULL, 16);'
remote_transmitter:
  pin: GPIO14
  carrier_duty_percent: 50%
3、configuration yaml文件设置如下:
#万能遥控器
smartir:
climate:
  - platform: smartir
    unique_id: room_ac
    device_code: 1183
    controller_data: my_espir_send_raw_command
    temperature_sensor: sensor.temperature_humidity_sensor_080d_temperature
    humidity_sensor: sensor.temperature_humidity_sensor_080d_humidity
    power_sensor: input_boolean.xu_ni_kai_guan
4、codes红外码:
  "manufacturer": "Gree",
  "supportedModels": [
    "Unknown"
  "supportedController": "ESPHome",
  "commandsEncoding": "Raw",
  "minTemperature": 16.0,
  "maxTemperature": 30.0,
  "precision": 1.0,
  "operationModes": [
    "cool",
    "heat",
    "auto",
    "dry",
    "fan_only"
  "fanModes": [
    "low",
    "mid",
    "high",
    "auto"
  "commands": {
    "off": "Z6UXAVwCAACfBgAArxEAAPkiAAA+TgAAQJwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjAAAQABAQAAAAABAQAAAAAAAAAAAAEAAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAEAAQEBBQIwAAEAAQEAAAAAAQEAAAAAAAAAAAABAAAAAAAAAQEBAAABAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAAAAQABAQAA==",
    "auto": {
      "auto": {
        "16": "Z6WLADcCAAByAgAAdgYAAG8RAADQIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEBIQEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "17": "Z6WLADcCAAByAgAAdgYAAG8RAADQIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEBIQEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "18": "Z6WLADcCAAByAgAAdgYAAG8RAADQIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEBIQEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "19": "Z6WLADcCAAByAgAAdgYAAG8RAADQIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEBIQEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "20": "Z6WLADcCAAByAgAAdgYAAG8RAADQIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEBIQEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "21": "Z6WLADcCAAByAgAAdgYAAG8RAADQIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEBIQEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "22": "Z6WLADcCAAByAgAAdgYAAG8RAADQIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEBIQEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "23": "Z6WLADcCAAByAgAAdgYAAG8RAADQIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEBIQEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "24": "Z6WLADcCAAByAgAAdgYAAG8RAADQIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEBIQEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "25": "Z6WLADcCAAByAgAAdgYAAG8RAADQIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEBIQEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "26": "Z6WLADcCAAByAgAAdgYAAG8RAADQIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEBIQEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "27": "Z6WLADcCAAByAgAAdgYAAG8RAADQIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEBIQEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "28": "Z6WLADcCAAByAgAAdgYAAG8RAADQIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEBIQEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "29": "Z6WLADcCAAByAgAAdgYAAG8RAADQIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEBIQEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "30": "Z6WLADcCAAByAgAAdgYAAG8RAADQIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEBIQEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB"
      "low": {
      "mid": {
      "high": {
    "cool": {
      "low": {
        "16": "Z6WLAFgCAAChBgAAqxEAAOwiAAA2TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAAEAAA",
        "17": "Z6WLAFgCAAChBgAArREAAOoiAAA2TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAAAAAQAAAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAQEAAA",
        "18": "Z6WLAFgCAACiBgAArBEAAOkiAAA4TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAAAAAAEAAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAQEAAA",
        "19": "Z6WLAFgCAAChBgAAqxEAAOsiAAA4TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAAAAAQEAAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAABAA",
        "20": "Z6WLAFgCAACiBgAArREAAOgiAAA0TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAAAAAAABAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAAABAA",
        "21": "Z6WLAFkCAACZBgAAqxEAAOwiAAAdTgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAAAAAQABAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAQABAA",
        "22": "Z6WLAFgCAACjBgAArhEAAOkiAAA4TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAAAAAAEBAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAQABAA",
        "23": "Z6WLAFgCAAChBgAArhEAAOgiAAA3TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAAAAAQEBAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAEBAA",
        "24": "Z6WLAFgCAACiBgAArREAAOoiAAA2TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAAAAAAAAAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAAEBAA",
        "25": "Z6WLAFgCAACiBgAAqxEAAOoiAAA2TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAAAAAQAAAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAQEBAA",
        "26": "Z6WLAFgCAACjBgAAsBEAAOkiAAA4TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAAAAAAEAAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAQEBAA",
        "27": "Z6WLAFgCAACjBgAArREAAOkiAAA4TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAAAAAQEAAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAA",
        "28": "Z6WLAFgCAAChBgAArhEAAOoiAAA3TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAAAAAAABAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAAAAAA",
        "29": "Z6WLAFgCAACiBgAArBEAAOsiAAA5TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAAAAAQABAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAQAAAA",
        "30": "Z6WLAFgCAACiBgAArBEAAOsiAAA3TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAAAAAAEBAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAQAAAA"
      "mid": {
        "16": "Z6WLAFkCAACWBgAArREAAOsiAAA3TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAQAAAAAAAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAAEAAA",
        "17": "Z6WLAFkCAACWBgAArREAAOsiAAA3TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAQAAAAAAAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAAEAAA",
        "18": "Z6WLAFsCAABpBgAAkAYAAJARAAAGIwAAHU4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0IAAAIAAQAAAAIAAAAAAAAAAAAAAAICAAAAAAACAAIAAAIABQAAAAAAAAAAAAAAAAACAAAAAAAAAAAAAAAAAAACAgIAAA",
        "19": "Z6WLAFoCAACSBgAAkBEAAAUjAAAcTgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAQAAAQEAAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAABAA",
        "20": "Z6WLAFgCAACiBgAArBEAAOoiAAA3TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAQAAAAABAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAAABAA",
        "21": "Z6WLAFgCAACjBgAArhEAAOkiAAA3TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAQAAAQABAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAQABAA",
        "22": "Z6WLAFgCAACjBgAArREAAOkiAAA4TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAQAAAAEBAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAQABAA",
        "23": "Z6WLAFgCAACjBgAArhEAAOciAAA3TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAQAAAQEBAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAEBAA",
        "24": "Z6WLAFgCAACjBgAArREAAOkiAAA4TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAQAAAAAAAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAAEBAA",
        "25": "Z6WLAFgCAACjBgAArhEAAOkiAAA4TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAQAAAQAAAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAQEBAA",
        "26": "Z6WLAFkCAACdBgAArBEAAOsiAAA1TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAQAAAAEAAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAQEBAA",
        "27": "Z6WLAFsCAACOBgAAkxEAAAQjAAAeTgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAQAAAQEAAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAA",
        "28": "Z6WLAFoCAACMBgAAkBEAAAYjAAA3TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAQAAAAABAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAAAAAA",
        "29": "Z6WLAFoCAACWBgAArBEAAOsiAAAeTgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAQAAAQABAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAQAAAA",
        "30": "Z6WLAFsCAACOBgAAkhEAAAQjAAA1TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAQAAAAEBAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAQAAAA"
      "high": {
        "16": "Z6UXAVwCAACfBgAArBEAAAQjAAA8TgAAQJwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAQAAAAAAAAAAAAAAAAAAAAEAAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAABAQEABQIxAAABAQEAAAAAAAAAAAAAAAAAAAABAAAAAAAAAQEBAAABAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAAAAAEBAAAA==",
        "17": "Z6UXAVwCAACfBgAAqxEAAPoiAAAWIwAAO04AAECcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkEAAAEBAQAAAQAAAAAAAAAAAAAAAAEAAAAAAAABAAEAAAEABQAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAABBgIxAAABAQEAAAEAAAAAAAAAAAAAAAABAAAAAAAAAQEBAAABAAUAAAAAAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAAAAQEBAAAA==",
        "18": "Z6UXAVwCAACfBgAArhEAAPsiAAA/TgAAQJwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAQAAAAEAAAAAAAAAAAAAAAEAAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAABAAABBQIxAAABAQEAAAABAAAAAAAAAAAAAAABAAAAAAAAAQEBAAABAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAAAAAAAAQAA==",
        "19": "Z6UXAVwCAACfBgAArxEAAPsiAAA4TgAAQJwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAQAAAQEAAAAAAAAAAAAAAAEAAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAQABBQIxAAABAQEAAAEBAAAAAAAAAAAAAAABAAAAAAAAAQEBAAABAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAAAAQAAAQAA==",
        "20": "Z6UXAVwCAACeBgAAqxEAAPgiAAAWIwAAO04AAECcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkEAAAEBAQAAAAABAAAAAAAAAAAAAAEAAAAAAAABAAEAAAEABQAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAABAQABBgIxAAABAQEAAAAAAQAAAAAAAAAAAAABAAAAAAAAAQEBAAABAAUAAAAAAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAAAAAEAAQAA==",
        "21": "Z6UXAVwCAACeBgAArhEAAPoiAAAYIwAAOk4AAECcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkEAAAEBAQAAAQABAAAAAAAAAAAAAAEAAAAAAAABAAEAAAEABQAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAEBBgIxAAABAQEAAAEAAQAAAAAAAAAAAAABAAAAAAAAAQEBAAABAAUAAAAAAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAAAAQEAAQAA==",
        "22": "Z6UXAVwCAACfBgAArhEAAPgiAAA+TgAAQJwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAQAAAAEBAAAAAAAAAAAAAAEAAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAABAAEBBQIxAAABAQEAAAABAQAAAAAAAAAAAAABAAAAAAAAAQEBAAABAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAAAAAABAQAA==",
        "23": "Z6UXAVwCAACeBgAArBEAAPoiAAA3TgAAQJwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAQAAAQEBAAAAAAAAAAAAAAEAAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAQEBBQIxAAABAQEAAAEBAQAAAAAAAAAAAAABAAAAAAAAAQEBAAABAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAAAAQABAQAA==",
        "24": "Z6UXAV4CAACMBgAAgxEAABIjAAA0IwAALU4AAECcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAQAAAAAAAQAAAAAAAAAAAAEAAAAAAAABAAEAAAEABQAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAABAQEBBgJBAAABAQEAAAAAAAEAAAAAAAAAAAABAAAAAAAAAQEBAAABAAUAAAAAAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAAAAAEBAQAA==",
        "25": "Z6UXAVwCAACcBgAArREAAPoiAAA6TgAAQJwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAQAAAQAAAQAAAAAAAAAAAAEAAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAABQIxAAABAQEAAAEAAAEAAAAAAAAAAAABAAAAAAAAAQEBAAABAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAAAAQEBAQAA==",
        "26": "Z6UXAVwCAACfBgAArxEAAPkiAAAUIwAAO04AAECcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkEAAAEBAQAAAAEAAQAAAAAAAAAAAAEAAAAAAAABAAEAAAEABQAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAABAAAABgIxAAABAQEAAAABAAEAAAAAAAAAAAABAAAAAAAAAQEBAAABAAUAAAAAAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAAAAAAAAAAA==",
        "27": "Z6UXAV0CAACaBgAArREAAPsiAAAiTgAAP04AAECcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAQAAAQEAAQAAAAAAAAAAAAEAAAAAAAABAAEAAAEABQAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAQAABgIxAAABAQEAAAEBAAEAAAAAAAAAAAABAAAAAAAAAQEBAAABAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAAAAQAAAAAA==",
        "28": "Z6UXAVwCAACfBgAAqxEAAPgiAAA7TgAAQJwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAQAAAAABAQAAAAAAAAAAAAEAAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAABAQAABQIxAAABAQEAAAAAAQEAAAAAAAAAAAABAAAAAAAAAQEBAAABAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAAAAAEAAAAA==",
        "29": "Z6UXAVwCAACfBgAArxEAAP0iAAA7TgAAQJwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEBAQAAAQABAQAAAAAAAAAAAAEAAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAEABQIxAAABAQEAAAEAAQEAAAAAAAAAAAABAAAAAAAAAQEBAAABAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAAAAQEAAAAA==",
        "30": "Z6UXAV0CAACYBgAAqxEAAP0iAAAZIwAAO04AAECcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkEAAAEBAQAAAAEBAQAAAAAAAAAAAAEAAAAAAAABAAEAAAEABQAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAABAAEABgIxAAABAQEAAAABAQEAAAAAAAAAAAABAAAAAAAAAQEBAAABAAUAAAAAAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAAAAAABAAAA=="
      "auto": {
        "16": "Z6WLAFkCAACYBgAAkREAAAIjAAA1TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAAAAAAAAAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAAEAAA",
        "17": "Z6WLAFgCAAChBgAAqhEAAOoiAAA1TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAAAAAQAAAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAQEAAA",
        "18": "Z6WLAFgCAACiBgAArREAAOkiAAA1TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAAAAAAEAAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAQEAAA",
        "19": "Z6WLAFgCAACgBgAArBEAAOoiAAA0TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAAAAAQEAAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAABAA",
        "20": "Z6WLAFgCAACiBgAAqxEAAOsiAAA1TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAAAAAAABAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAAABAA",
        "21": "Z6WLAFgCAACiBgAAqxEAAOoiAAA0TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAAAAAQABAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAQABAA",
        "22": "Z6WLAFgCAAChBgAAqxEAAOsiAAA0TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAAAAAAEBAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAQABAA",
        "23": "Z6WLAFgCAACgBgAAqxEAAOkiAAA2TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAAAAAQEBAAAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAEBAA",
        "24": "Z6WLAFgCAAChBgAArREAAOkiAAA2TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAAAAAAAAAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAAEBAA",
        "25": "Z6WLAFgCAACiBgAArBEAAOkiAAA2TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAAAAAQAAAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAQEBAA",
        "26": "Z6WLAFgCAACiBgAArREAAOkiAAA2TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAAAAAAEAAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAQEBAA",
        "27": "Z6WLAFgCAAChBgAArBEAAOkiAAA3TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAAAAAQEAAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAA",
        "28": "Z6WLAFgCAACjBgAArREAAOgiAAA3TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAAAAAAABAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAAAAAA",
        "29": "Z6WLAFgCAAChBgAArBEAAOoiAAA1TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAAAAAQABAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAQAAAA",
        "30": "Z6WLAFgCAACgBgAAqxEAAOoiAAA1TgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAAEAAAAAAAEBAQAAAAAAAAAAAAEBAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAQAAAA"
    "heat": {
      "low": {
        "16": "Z6WLAD4CAABrAgAAfQYAAHURAADJIgAAmU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEBAQEBAQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBASEB",
        "17": "Z6WLAD8CAABrAgAAfQYAAHYRAADIIgAAmk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEBAQEhAQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBASEB",
        "18": "Z6WLAD8CAABrAgAAiQIAAH0GAAB2EQAAySIAAH5NAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABFAQExMTEBAQEBMQEBAQEBAQEBAQEBMQEBAQEBATEBMQEBMQFhAgEBAQEBAQEBAQEBATEBAQEBAQEBAQEBAQEBAQExATEB",
        "19": "Z6WLAD4CAABrAgAAfQYAAHURAADJIgAAmU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEBAQEhIQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhASEB",
        "20": "Z6WLAD8CAABrAgAAfQYAAHcRAADKIgAAmU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEBAQEBASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBISEB",
        "21": "Z6WLAD4CAABsAgAAfAYAAHcRAADIIgAAmU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEBAQEhASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "22": "Z6WLAD4CAABrAgAAfQYAAHYRAADLIgAAmE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEBAQEBISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhISEB",
        "23": "Z6WLAD4CAABrAgAAfQYAAHYRAADIIgAAmU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEBAQEhISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhISEB",
        "24": "Z6WLAD4CAABrAgAAfQYAAHYRAADJIgAAmk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEBAQEBAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBAQEB",
        "25": "Z6WLAD4CAABrAgAAfQYAAHYRAADJIgAAmk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBAQEB",
        "26": "Z6WLAD4CAABrAgAAfQYAAHYRAADJIgAAm00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEBAQEBIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhAQEB",
        "27": "Z6WLAD4CAABrAgAAfQYAAHYRAADIIgAAm00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEBAQEhIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhAQEB",
        "28": "Z6WLAD4CAABrAgAAfQYAAHURAADKIgAAmE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEBAQEBASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBIQEB",
        "29": "Z6WLAD4CAABrAgAAfQYAAHYRAADJIgAAmk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEBAQEhASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBIQEB",
        "30": "Z6WLAD4CAABrAgAAfQYAAHcRAADIIgAAmU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEBAQEBISEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhIQEB"
      "mid": {
        "16": "Z6WLAD0CAABsAgAAfAYAAHURAADIIgAAmE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEhAQEBAQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBASEB",
        "17": "Z6WLAD0CAABsAgAAfAYAAHURAADJIgAAl00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEhAQEhAQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBASEB",
        "18": "Z6WLAD4CAABsAgAAewYAAHYRAADJIgAAmE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEhAQEBIQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhASEB",
        "19": "Z6WLAD0CAABsAgAAfAYAAHYRAADIIgAAmE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEhAQEhIQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhASEB",
        "20": "Z6WLAD0CAABsAgAAfAYAAHURAADIIgAAl00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEhAQEBASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBISEB",
        "21": "Z6WLAD0CAABsAgAAfAYAAHURAADJIgAAmE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEhAQEhASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "22": "Z6WLAD0CAABsAgAAfAYAAHYRAADIIgAAmU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEhAQEBISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhISEB",
        "23": "Z6WLAD0CAABsAgAAfAYAAHYRAADHIgAAl00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEhAQEhISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhISEB",
        "24": "Z6WLAD0CAABsAgAAfAYAAHYRAADJIgAAmU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEhAQEBAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBAQEB",
        "25": "Z6WLAD0CAABsAgAAfAYAAHURAADJIgAAmU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEhAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBAQEB",
        "26": "Z6WLAD0CAABsAgAAfAYAAHcRAADKIgAAmU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEhAQEBIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhAQEB",
        "27": "Z6WLAD8CAABqAgAAfgYAAHcRAADIIgAAmk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEhAQEhIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhAQEB",
        "28": "Z6WLAD0CAABsAgAAfAYAAHYRAADIIgAAmE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEhAQEBASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBIQEB",
        "29": "Z6WLAEACAABqAgAAfwYAAHcRAADHIgAAnE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEhAQEhASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBIQEB",
        "30": "Z6WLAD8CAABqAgAAfgYAAHcRAADHIgAAm00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEhAQEBISEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhIQEB"
      "high": {
        "16": "Z6WLAD0CAABsAgAAfAYAAHYRAADKIgAAmU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEhAQEBAQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBASEB",
        "17": "Z6WLAD4CAABsAgAAfAYAAHURAADKIgAAmE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEhAQEhAQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBASEB",
        "18": "Z6WLAD0CAABsAgAAfAYAAHYRAADJIgAAmU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEhAQEBIQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhASEB",
        "19": "Z6WLAD0CAABsAgAAfAYAAHQRAADIIgAAmE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEhAQEhIQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhASEB",
        "20": "Z6WLAD0CAABsAgAAfAYAAHURAADIIgAAmU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEhAQEBASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBISEB",
        "21": "Z6WLAD0CAABsAgAAfAYAAHYRAADIIgAAmU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEhAQEhASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "22": "Z6WLAD0CAABsAgAAfAYAAHYRAADIIgAAmE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEhAQEBISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhISEB",
        "23": "Z6WLAD0CAABsAgAAfAYAAHURAADIIgAAl00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEhAQEhISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhISEB",
        "24": "Z6WLAD0CAABsAgAAfAYAAHcRAADJIgAAl00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEhAQEBAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBAQEB",
        "25": "Z6WLAD0CAABsAgAAfAYAAHURAADJIgAAmE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEhAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBAQEB",
        "26": "Z6WLAD0CAABsAgAAfAYAAHURAADJIgAAl00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEhAQEBIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhAQEB",
        "27": "Z6WLAD4CAABsAgAAfAYAAHQRAADKIgAAmE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEhAQEhIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhAQEB",
        "28": "Z6WLAD0CAABsAgAAfAYAAHURAADIIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEhAQEBASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBIQEB",
        "29": "Z6WLAD0CAABsAgAAfAYAAHQRAADKIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEhAQEhASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBIQEB",
        "30": "Z6WLAD4CAABsAgAAfAYAAHURAADIIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhISEhAQEBISEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhIQEB"
      "auto": {
        "16": "Z6WLADkCAABxAgAAeAYAAG8RAADMIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEBAQEBAQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBASEB",
        "17": "Z6WLADkCAABxAgAAdwYAAHERAADNIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEBAQEhAQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBASEB",
        "18": "Z6WLADkCAABxAgAAdwYAAHIRAADLIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEBAQEBIQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhASEB",
        "19": "Z6WLADkCAABxAgAAdwYAAHERAADNIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEBAQEhIQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhASEB",
        "20": "Z6WLADkCAABxAgAAdwYAAHERAADNIgAAlE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEBAQEBASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBISEB",
        "21": "Z6WLADgCAABxAgAAdwYAAHERAADNIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEBAQEhASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "22": "Z6WLADkCAABxAgAAeAYAAHERAADNIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEBAQEBISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhISEB",
        "23": "Z6WLAD0CAABtAgAAewYAAHQRAADIIgAAmE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEBAQEhISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhISEB",
        "24": "Z6WLAD0CAABtAgAAewYAAHURAADJIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEBAQEBAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBAQEB",
        "25": "Z6WLAD0CAABtAgAAewYAAHQRAADJIgAAl00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBAQEB",
        "26": "Z6WLAD0CAABtAgAAewYAAHQRAADJIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEBAQEBIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhAQEB",
        "27": "Z6WLAD0CAABtAgAAewYAAHYRAADHIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEBAQEhIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhAQEB",
        "28": "Z6WLAD0CAABtAgAAewYAAHURAADKIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEBAQEBASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBIQEB",
        "29": "Z6WLAD0CAABtAgAAewYAAHURAADJIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEBAQEhASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBIQEB",
        "30": "Z6WLAD0CAABtAgAAewYAAHMRAADJIgAAl00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AQEhIQEBAQEBISEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhIQEB"
    "fan_only": {
      "low": {
        "16": "Z6WLADcCAAByAgAAdgYAAHERAADRIgAAlE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEBAQEBAQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhIQEB",
        "17": "Z6WLADcCAAByAgAAdgYAAHARAADQIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEBAQEhAQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBASEB",
        "18": "Z6WLADgCAAByAgAAdgYAAHERAADQIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEBAQEBIQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBASEB",
        "19": "Z6WLADcCAAByAgAAdgYAAG4RAADPIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEBAQEhIQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhASEB",
        "20": "Z6WLADcCAAByAgAAdgYAAG8RAADQIgAAlE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEBAQEBASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhASEB",
        "21": "Z6WLADcCAAByAgAAdwYAAHERAADPIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEBAQEhASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBISEB",
        "22": "Z6WLADgCAAByAgAAdgYAAHERAADPIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEBAQEBISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "23": "Z6WLADcCAAByAgAAdgYAAHERAADOIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEBAQEhISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhISEB",
        "24": "Z6WLADgCAAByAgAAdgYAAHERAADRIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEBAQEBAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhISEB",
        "25": "Z6WLADcCAAByAgAAdgYAAHERAADPIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBAQEB",
        "26": "Z6WLADcCAAByAgAAdgYAAHERAADPIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEBAQEBIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBAQEB",
        "27": "Z6WLADgCAAByAgAAdwYAAHERAADOIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEBAQEhIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhAQEB",
        "28": "Z6WLADgCAAByAgAAdgYAAHERAADPIgAAlE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEBAQEBASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhAQEB",
        "29": "Z6WLADgCAAByAgAAdgYAAHERAADQIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEBAQEhASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBIQEB",
        "30": "Z6WLADgCAAByAgAAdgYAAHERAADOIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEBAQEBISEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBIQEB"
      "mid": {
        "16": "Z6WLADgCAAByAgAAdgYAAHARAADQIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEhAQEBAQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhIQEB",
        "17": "Z6WLAFUCAACWBgAAjhEAALMiAAC0TQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEBAAEAAQAAAQAAAAAAAAAAAAAAAAEAAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAABAA",
        "18": "Z6WLADcCAAByAgAAdgYAAHIRAADQIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEhAQEBIQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBASEB",
        "19": "Z6WLADcCAAByAgAAdgYAAHERAADPIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEhAQEhIQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhASEB",
        "20": "Z6WLADcCAAByAgAAdgYAAHARAADPIgAAlE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEhAQEBASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhASEB",
        "21": "Z6WLADcCAAByAgAAdgYAAHERAADPIgAAk00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEhAQEhASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBISEB",
        "22": "Z6WLADcCAAByAgAAdgYAAHERAADQIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEhAQEBISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "23": "Z6WLADcCAAByAgAAdgYAAHARAADQIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEhAQEhISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhISEB",
        "24": "Z6WLADcCAAByAgAAdgYAAHARAADPIgAAlE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEhAQEBAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhISEB",
        "25": "Z6WLADgCAAByAgAAdgYAAHERAADQIgAAlE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEhAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBAQEB",
        "26": "Z6WLADcCAAByAgAAdgYAAHERAADQIgAAlE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEhAQEBIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBAQEB",
        "27": "Z6WLADcCAAByAgAAdgYAAHARAADQIgAAlE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEhAQEhIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhAQEB",
        "28": "Z6WLADgCAAByAgAAdgYAAHERAADQIgAAlE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEhAQEBASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhAQEB",
        "29": "Z6WLADcCAAByAgAAdgYAAHERAADPIgAAlE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEhAQEhASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBIQEB",
        "30": "Z6WLADcCAAByAgAAdgYAAHERAADQIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEhAQEBISEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBIQEB"
      "high": {
        "16": "Z6WLADgCAABxAgAAdwYAAHERAADQIgAAl00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEhAQEBAQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhIQEB",
        "17": "Z6WLADgCAABxAgAAdgYAAHARAADQIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEhAQEhAQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBASEB",
        "18": "Z6WLAFgCAAB3BgAAchEAAM8iAACVTQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEBAAEBAQAAAAEAAAAAAAAAAAAAAAEAAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAAABAA",
        "19": "Z6WLADgCAABxAgAAdwYAAHARAADPIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEhAQEhIQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhASEB",
        "20": "Z6WLADgCAAByAgAAdwYAAHMRAADOIgAAlE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEhAQEBASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhASEB",
        "21": "Z6WLADkCAABxAgAAdgYAAHERAADPIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEhAQEhASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBISEB",
        "22": "Z6WLADgCAABxAgAAdwYAAHARAADPIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEhAQEBISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "23": "Z6WLADgCAABxAgAAdwYAAHERAADPIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEhAQEhISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhISEB",
        "24": "Z6WLAFkCAAB2BgAAchEAAM8iAACVTQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEBAAEBAQAAAAAAAQAAAAAAAAAAAAEAAAAAAAABAAEAAAEABAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAABAQEBAA",
        "25": "Z6WLADgCAAByAgAAdgYAAHIRAADQIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEhAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBAQEB",
        "26": "Z6WLADgCAAByAgAAdwYAAHERAADPIgAAlE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEhAQEBIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBAQEB",
        "27": "Z6WLADgCAABxAgAAdwYAAHARAADPIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEhAQEhIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhAQEB",
        "28": "Z6WLADkCAABxAgAAdwYAAHIRAADOIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEhAQEBASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhAQEB",
        "29": "Z6WLADgCAAByAgAAdwYAAHIRAADQIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEhAQEhASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBIQEB",
        "30": "Z6WLADgCAABxAgAAdwYAAHIRAADQIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBISEhAQEBISEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBIQEB"
      "auto": {
        "16": "Z6WLAEICAABoAgAAgQYAAHkRAADHIgAAnU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEBAQEBAQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhIQEB",
        "17": "Z6WLAEECAABoAgAAgAYAAHoRAADIIgAAoE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEBAQEhAQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBASEB",
        "18": "Z6WLAEICAABoAgAAgQYAAHkRAADHIgAAn00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEBAQEBIQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBASEB",
        "19": "Z6WLAEICAABoAgAAgQYAAHkRAADHIgAAn00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEBAQEhIQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhASEB",
        "20": "Z6WLAEECAABoAgAAgAYAAHkRAADIIgAAnU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEBAQEBASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhASEB",
        "21": "Z6WLAEICAABoAgAAgQYAAHkRAADGIgAAoE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEBAQEhASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBISEB",
        "22": "Z6WLAD8CAABrAgAAfgYAAHcRAADIIgAAm00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEBAQEBISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "23": "Z6WLAEICAABoAgAAgQYAAHoRAADIIgAAoE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEBAQEhISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhISEB",
        "24": "Z6WLADcCAAByAgAAdgYAAG8RAADQIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEBAQEBAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhISEB",
        "25": "Z6WLADgCAAByAgAAdgYAAHERAADQIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBAQEB",
        "26": "Z6WLADcCAAByAgAAdgYAAHARAADQIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEBAQEBIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBAQEB",
        "27": "Z6WLADgCAAByAgAAdwYAAHARAADPIgAAlE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEBAQEhIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhAQEB",
        "28": "Z6WLADgCAAByAgAAdgYAAHARAADPIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEBAQEBASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhAQEB",
        "29": "Z6WLADgCAAByAgAAdgYAAHERAADPIgAAlE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEBAQEhASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBIQEB",
        "30": "Z6WLADcCAAByAgAAdwYAAHARAADQIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ISEBIQEBAQEBISEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBIQEB"
    "dry": {
      "low": {
        "16": "Z6WLADoCAABvAgAAeAYAAHMRAADNIgAAl00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ASEBISEBAQEBAQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhIQEB",
        "17": "Z6WLADsCAABvAgAAeQYAAHMRAADOIgAAl00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ASEBISEBAQEhAQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhIQEB",
        "18": "Z6WLADoCAABvAgAAeQYAAHMRAADNIgAAl00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ASEBISEBAQEBIQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBASEB",
        "19": "Z6WLADoCAABvAgAAeQYAAHIRAADMIgAAl00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ASEBISEBAQEhIQEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBASEB",
        "20": "Z6WLADoCAABwAgAAeAYAAHMRAADNIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ASEBISEBAQEBASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhASEB",
        "21": "Z6WLADoCAABwAgAAeQYAAHIRAADOIgAAl00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ASEBISEBAQEhASEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhASEB",
        "22": "Z6WLADoCAABvAgAAeQYAAHMRAADOIgAAl00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ASEBISEBAQEBISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBISEB",
        "23": "Z6WLADoCAABvAgAAeQYAAHMRAADNIgAAl00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ASEBISEBAQEhISEBAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
        "24": "Z6WLADoCAABvAgAAeAYAAHQRAADNIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ASEBISEBAQEBAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhISEB",
        "25": "Z6WLADoCAABwAgAAeAYAAHIRAADOIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ASEBISEBAQEhAQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhISEB",
        "26": "Z6WLADoCAABwAgAAeAYAAHQRAADMIgAAlk0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ASEBISEBAQEBIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBAQEB",
        "27": "Z6WLADoCAABwAgAAeAYAAHIRAADMIgAAlE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ASEBISEBAQEhIQEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBAQEB",
        "28": "Z6WLADoCAABwAgAAeAYAAHMRAADNIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ASEBISEBAQEBASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhAQEB",
        "29": "Z6WLADoCAABwAgAAeAYAAHIRAADOIgAAlE0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ASEBISEBAQEhASEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhAQEB",
        "30": "Z6WLADoCAABwAgAAeAYAAHMRAADNIgAAlU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ASEBISEBAQEBISEhAQEBAQEBAQEBIQEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBIQEB"
      "mid": {
      "high": {
      "auto": {
望跪求哪位大佬指点一下,折腾得都快要放弃了。
发表于 2023-8-27 21:35:30 | 显示全部楼层
换博联搭配smartir吧,以前也折腾过esphome红外,经常出问题
发表于 2023-8-27 21:47:42 | 显示全部楼层
试试irbaby
 楼主| 发表于 2023-8-27 21:58:22 | 显示全部楼层
博联有点贵,不想一个ESP就红外功能,esphome硬件可以把多余接口利用起来,还想在尝试一下
发表于 2023-8-27 23:46:15 | 显示全部楼层
我也没有成功。我觉得应该是代码格式的问题,博联很好弄,因为他的代码都是base64的
发表于 2023-8-28 08:40:43 | 显示全部楼层
美的空调,用smartAC结合esphome,以及只用esphome都测试成功。
楼主可以试试smartAC。
发表于 2023-8-28 09:23:18 | 显示全部楼层
发表于 2023-8-31 01:18:11 | 显示全部楼层
码不对,建议smartac比较容易
发表于 2023-8-31 02:17:46 | 显示全部楼层
smartir:
climate:
  - platform: smartir
    unique_id: room_ac
    device_code: 1183
    controller_data: my_espir_send_raw_command   #这一段你修改为自己的发射实体没? 正确的应该是   (esphome里这个红外遥控器的名字)_send_raw_command
 楼主| 发表于 2023-9-2 20:56:03 | 显示全部楼层
这个没错,你试过这种方案吗
GMT+8, 2026-1-16 15:44 , Processed in 1.204263 second(s), 11 queries , MemCached On.
