楼主: itisbig
[基础教程] 运营商送的海思机顶盒刷Homeassistant Supervisor 教程
发表于 2024-3-21 18:05:16 | 显示全部楼层
wfx 发表于 2024-1-15 10:27
2023.12.1: Pulling from home-assistant/armv7-hassio-supervisor
Digest: sha256:df86b18f9933f22e233e6e ...
启动代码中去掉 docker pull
docker run -d --name hassio_supervisor --privileged \
--restart unless-stopped \
-v /var/run/docker.sock:/var/run/docker.sock \
-v /var/run/dbus:/var/run/dbus \
-v /opt/hassio:/data \
-e SUPERVISOR_SHARE=/opt/hassio \
-e SUPERVISOR_NAME=hassio_supervisor \
-e HOMEASSISTANT_REPOSITORY=homeassistant/armv7-homeassistant \
ghcr.io/home-assistant/armv7-hassio-supervisor:2023.08.1
发表于 2024-3-21 18:11:18 | 显示全部楼层
953f7806c9eff29c150cfce92e04514.png 手头刚好有 魔百盒cm101s,
wfx 手机认证
发表于 2024-3-23 21:31:10 | 显示全部楼层
使用df -h命令查看开发板是root@armbian:~# df -h
Filesystem      Size  Used Avail Use% Mounted on
tmpfs           197M   22M  176M  11% /run
/dev/mmcblk1p1   29G  5.4G   23G  20% /
tmpfs           984M     0  984M   0% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           984M     0  984M   0% /tmp
/dev/zram1       47M   11M   33M  24% /var/log
overlay          29G  5.4G   23G  20% /var/lib/docker/overlay2/c8d9c2a4e20b2ae996b357a59a44f3be95d133b5707a16f6786db1272f53826d/merged
overlay          29G  5.4G   23G  20% /var/lib/docker/overlay2/9783536a85daa4905e8dd8025ff806906d181f011a59a9e26a9cbbc5f16e306a/merged
tmpfs           197M     0  197M   0% /run/user/0
overlay          29G  5.4G   23G  20% /var/lib/docker/overlay2/c061c44b20b458320bf26bd6a9eddb8c57e84f867876339e32e924a092ccd14a/merged
请问我要怎么修改挂载路径?
发表于 2024-10-14 15:31:38 | 显示全部楼层
安装后 提示系统不健康 加载项也无法安装 新建了json文件 重启盒子  各种操作都无法安装加载项
GMT+8, 2026-1-14 06:19 , Processed in 0.326462 second(s), 13 queries , MemCached On.
