楼主: itisbig
[基础教程] 运营商送的海思机顶盒刷Homeassistant Supervisor 教程
发表于 2023-10-9 09:39:14 | 显示全部楼层
你好,mv300这个64位的怎样拉镜像和建器
发表于 2023-11-28 13:31:07 | 显示全部楼层
谢谢分享!
E5-2650L-V2+华南X79+16GB*2
wfx 手机认证
发表于 2024-1-15 10:27:55 | 显示全部楼层
2023.12.1: Pulling from home-assistant/armv7-hassio-supervisor
Digest: sha256:df86b18f9933f22e233e6e07fd9ffe519af514705879e7ba514448977c984d0a
Status: Image is up to date for ghcr.io/home-assistant/armv7-hassio-supervisor:2023.12.1
一直报这个错误?
wfx 手机认证
发表于 2024-1-15 10:29:45 | 显示全部楼层
这个是怎么运行的?有端口可以打开的吗?它是怎么加载进home assistant的?在HA的界面如何添加?谢谢大佬!
发表于 2024-3-3 12:43:43 | 显示全部楼层
按照操作后访问8123打不开啊
发表于 2024-3-8 11:26:34 | 显示全部楼层
谢谢分享
发表于 2024-3-15 20:21:08 | 显示全部楼层
安装好了用ip:8123访问不到
用docker logs -f hassio_supervisor 看日志
root@hi3798mv100:~# docker logs -f hassio_supervisor
2023.08.1: Pulling from home-assistant/armv7-hassio-supervisor
Digest: sha256:c9d89055b5674b5c08d84bccaa111da4701443252e6672930308d2a508339ac0
Status: Image is up to date for ghcr.io/home-assistant/armv7-hassio-supervisor:2023.08.1
Error response from daemon: Head "https://ghcr.io/v2/home-assistant/armv7-hassio-supervisor/manifests/2023.08.1": Get "https://ghcr.io/token?scope=repository%3Ahome-assistant%2Farmv7-hassio-supervisor%3Apull&service=ghcr.io": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
Error response from daemon: Get "https://ghcr.io/v2/": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
Error response from daemon: Head "https://ghcr.io/v2/home-assistant/armv7-hassio-supervisor/manifests/2023.08.1": read tcp 192.168.1.109:33334->20.205.243.164:443: read: connection timed out
root@hi3798mv100:~#
发表于 2024-3-15 22:02:26 | 显示全部楼层
大神安装完无法访问,docker里没有IP和端口跟这些报错有关系吗?有什么办法解决吗
Error response from daemon: Head "https://ghcr.io/v2/home-assistant/armv7-hassio-supervisor/manifests/2023.08.1": read tcp 192.168.1.109:34012->20.205.243.164:443: read: connection timed out
Error response from daemon: Head "https://ghcr.io/v2/home-assistant/armv7-hassio-supervisor/manifests/2023.08.1": read tcp 192.168.1.109:34278->20.205.243.164:443: read: connection timed out
Error response from daemon: Head "https://ghcr.io/v2/home-assistant/armv7-hassio-supervisor/manifests/2023.08.1": read tcp 192.168.1.109:34312->20.205.243.164:443: read: connection timed out
Error response from daemon: Head "https://ghcr.io/v2/home-assistant/armv7-hassio-supervisor/manifests/2023.08.1": Get "https://ghcr.io/token?scope=repository%3Ahome-assistant%2Farmv7-hassio-supervisor%3Apull&service=ghcr.io": net/http: TLS handshake timeout
Error response from daemon: Head "https://ghcr.io/v2/home-assistant/armv7-hassio-supervisor/manifests/2023.08.1": net/http: TLS handshake timeout
Error response from daemon: Head "https://ghcr.io/v2/home-assistant/armv7-hassio-supervisor/manifests/2023.08.1": Get "https://ghcr.io/token?scope=repository%3Ahome-assistant%2Farmv7-hassio-supervisor%3Apull&service=ghcr.io": net/http: request canceled (Client.Timeout exceeded while awaiting headers)
Error response from daemon: Head "https://ghcr.io/v2/home-assistant/armv7-hassio-supervisor/manifests/2023.08.1": read tcp 192.168.1.109:38094->20.205.243.164:443: read: connection timed out
Error response from daemon: Get "https://ghcr.io/v2/": net/http: request canceled (Client.Timeout exceeded while awaiting headers)
lse 手机认证
发表于 2024-3-15 22:12:36 | 显示全部楼层
厉害厉害厉害
发表于 2024-3-16 10:50:00 | 显示全部楼层
容器启动了就是8123访问不到
GMT+8, 2026-1-14 06:18 , Processed in 0.885322 second(s), 15 queries , MemCached On.
