楼主: taida
[教程系列] 串口屏收nodered发送的数据,求助?
Waer
陈二狗
发表于 2023-7-31 11:12:00 | 显示全部楼层
taida 发表于 2023-7-31 10:59
终于搞定了,谢谢Waer和cjnt007,用Buffer 做的,先将字符转成Buffer,然后将文本(FFFFFF),也转成Buffer ...
哈哈哈 在上班 所以来迟了
其实把你上一个节点输出payload的时候格式改成文本就可以
[{"id":"bc7f85cc82713bed","type":"tab","label":"流程 2","disabled":false,"info":"","env":[]},{"id":"43b82491eb19fc5a","type":"inject","z":"bc7f85cc82713bed","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"123456","payloadType":"str","x":470,"y":360,"wires":[["5dedf802bfc1d293"]]},{"id":"8771cd2730dd7fbb","type":"debug","z":"bc7f85cc82713bed","name":"debug 5","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":840,"y":360,"wires":[]},{"id":"5dedf802bfc1d293","type":"function","z":"bc7f85cc82713bed","name":"","func":"var q = Buffer.from((msg.payload),'hex')\nvar a = Buffer.from('ffffffff', 'hex')\nvar c = Buffer.concat([q,a])\nmsg.payload = c\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":650,"y":360,"wires":[["8771cd2730dd7fbb"]]}]
二狗如何解决玄学bug:
1:重烧一次程序      2:插紧电线      3:吹一下灰尘
4:玩一会手机         5:放弃
 楼主| 发表于 2023-7-31 11:33:18 | 显示全部楼层
再次感谢!
 楼主| 发表于 2023-8-3 18:07:50 | 显示全部楼层
Waer 发表于 2023-7-31 11:12
哈哈哈 在上班 所以来迟了
不好意思,在问一个问题,怎么将字符串相加呢?但是要得到这样的一个格式:
如:
需要的结果 b0.txt = "29.8"
msg.payload 的值是29.8,如果用var a = "b0.txt="+msg.payload,得出的结果是“bo.txt=29.8”,而不是
b0.txt = "29.8",用String(msg.payload)也是一样的,也就是payload的值上要加“”谢谢!帮忙看看可以怎么实现
Waer
陈二狗
发表于 2023-8-3 21:30:01 | 显示全部楼层
如:
你是希望
最初是msg.payload=29.8
最后是msg.payload=b0.txt="29.8"
这样吗
二狗如何解决玄学bug:
4:玩一会手机         5:放弃
Waer
陈二狗
发表于 2023-8-3 21:56:20 | 显示全部楼层
如:
我还是不确定你具体的使用场景  你说的输出结果是“bo.txt=29.8”
前后的双引号应该只是代表这个内容属于字符串格式  在接收方读取就是bo.txt=29.8
所以不要太纠结这部分
至少我目前学的就到这部分
如果你是为了接收方收到的信号是bo.txt="29.8”
那你可以提前给输入的msg.payload值加上双引号
[{"id":"a56d2dc6bd46c271","type":"inject","z":"bc7f85cc82713bed","name":"已增加双引号的字符串","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"“29.8”","payloadType":"str","x":240,"y":480,"wires":[["88575553e714e43a"]]},{"id":"53be71bd312291bf","type":"debug","z":"bc7f85cc82713bed","name":"debug 8","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":720,"y":480,"wires":[]},{"id":"88575553e714e43a","type":"function","z":"bc7f85cc82713bed","name":"两段字符串拼合输出","func":"var a = "b0.txt=" + msg.payload;\nmsg.payload = a\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":480,"y":480,"wires":[["53be71bd312291bf"]]}]
二狗如何解决玄学bug:
4:玩一会手机         5:放弃
 楼主| 发表于 2023-8-3 22:34:54 | 显示全部楼层
我找了一张淘晶驰的显示屏,现在需要在文本框填入温度,t0是文本框名称,他要求的格式就是t0.text=“文本”,所以必须这个格式,谢谢
 楼主| 发表于 2023-8-4 09:38:14 | 显示全部楼层
写好了,谢谢各位
参与人数 1金钱 +5 收起 理由
Waer + 5 墙都不扶,就服楼主!
GMT+8, 2025-12-3 07:39 , Processed in 1.225380 second(s), 11 queries , MemCached On.
