查看: 6919|回复: 20
[求助] 401a安装ha报错,求大佬指导
发表于 2023-6-27 02:49:47 | 显示全部楼层 |阅读模式
信息如下。对应的安装缺少的依赖 又会报其他的错。。
root@armbian:~# dpkg -i homeassistant-supervised.deb
Selecting previously unselected package homeassistant-supervised.
(Reading database ... 39480 files and directories currently installed.)
Preparing to unpack homeassistant-supervised.deb ...
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
Adding 'diversion of /etc/NetworkManager/NetworkManager.conf to /etc/NetworkManager/NetworkManager.conf.real by homeassistant-supervised'
Adding 'diversion of /etc/NetworkManager/system-connections/default to /etc/NetworkManager/system-connections/default.real by homeassistant-supervised'
Adding 'diversion of /etc/docker/daemon.json to /etc/docker/daemon.json.real by homeassistant-supervised'
Adding 'diversion of /etc/network/interfaces to /etc/network/interfaces.real by homeassistant-supervised'
Unpacking homeassistant-supervised (1.5.0) ...
dpkg: dependency problems prevent configuration of homeassistant-supervised:
homeassistant-supervised depends on systemd-resolved; however:
  Package systemd-resolved is not installed.
dpkg: error processing package homeassistant-supervised (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
已解决, 我是UNT403的盒子,刷的armbian,换了个引导文件重新安装就好了。也不不知道啥原因
目前已安装上hass,但是又遇到个新问题。盒子会经常自己死机。。每次要重新断电然后上电。。还在摸索解决中
发表于 2023-6-27 08:44:41 | 显示全部楼层
我的报错和你的一样,不知道怎么解决
发表于 2023-6-27 09:51:04 | 显示全部楼层
感觉是安装问题。你要列出你安装的硬件环境,和安装hass命令。
发表于 2023-6-27 10:45:43 | 显示全部楼层
没有安装依赖,具体的你到github上查
发表于 2023-6-27 14:10:59 | 显示全部楼层
apt purge homeassistant-supervised
wget https://github.com/home-assistant/supervised-installer/releases/download/1.4.3/homeassistant-supervised.deb
如果没有梯子,可以把第二句改为
wget https://ghproxy.com/https://github.com/home-assistant/supervised-installer/releases/download/1.4.3/homeassistant-supervised.deb
拿走,不谢!
 楼主| 发表于 2023-6-27 23:16:24 | 显示全部楼层
Roger 发表于 2023-6-27 14:10
如果没有梯子,可以把第二句改为
拿走,不谢!
感谢,但我用了梯子的
发表于 2023-6-27 23:45:50 | 显示全部楼层
发表于 2023-6-28 08:46:02 | 显示全部楼层
不是专业真的不建议玩盒子,半桶水的教程太多了,出问题自己解决不到,也没文案能参考,我半年前也是这样折腾过,一个手贱点个大更新,环境不对又启动不到了 折腾好久很难受,最后直接换小主机X86直装了HAOS版了
发表于 2023-6-28 12:28:29 | 显示全部楼层
360341024 发表于 2023-6-28 08:46
不是专业真的不建议玩盒子,半桶水的教程太多了,出问题自己解决不到,也没文案能参考,我半年前也是这样折 ...
没出现这个问题,盒子也能玩HAO版本,性能杠杠的
发表于 2023-6-28 14:48:56 | 显示全部楼层
我的已经解决,不安装最新的,换成1.3.1的homeassistant-supervised.deb。之前的代理虽然能访问外网,能打开谷歌,但是不知道为啥打不开home-assistant.io,换了个能打开home-assistant.io网址的代理。成功安装。具体是不是这样解决的就不太懂了,反正是成功安装了
GMT+8, 2025-12-18 17:48 , Processed in 0.850178 second(s), 12 queries , MemCached On.
