楼主: 冬瓜HA
X96机顶盒改HASSOS打造小巧经济的HASS服务主机 os16.3.2
发表于 2023-10-18 21:12:33 | 显示全部楼层
hassos 文件两个G,是不是有问题啊
 楼主| 发表于 2023-10-18 22:37:10 | 显示全部楼层
是的。官方分区就有这么大。
发表于 2023-10-18 22:43:58 | 显示全部楼层
冬瓜HA 发表于 2023-10-18 22:37
是的。官方分区就有这么大。
好吧,我刚用usb2.0的U盘,rootfs分区只有2.5G 复制不过去,换了一个3.0的U盘可以了
发表于 2023-10-19 09:26:25 | 显示全部楼层
升级失败,这是日志,看着是没找到资源
23-10-19 09:15:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-10-19 09:15:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-10-19 09:15:08 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-10-19 09:15:08 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-10-19 09:15:09 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-10-19 09:15:09 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
23-10-19 09:15:09 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-10-19 09:15:58 INFO (MainThread) [supervisor.os.manager] Fetch OTA update from https://github.com/home-assistan ... max-plus-10.5.raucb
23-10-19 09:15:58 ERROR (MainThread) [supervisor.os.manager] Error raised from OTA Webserver: 404
23-10-19 09:16:20 INFO (MainThread) [supervisor.os.manager] Fetch OTA update from https://github.com/home-assistan ... max-plus-10.5.raucb
23-10-19 09:18:20 ERROR (MainThread) [supervisor.os.manager] Can't fetch OTA update from https://github.com/home-assistan ... ax-plus-10.5.raucb: Server disconnected
23-10-19 09:18:41 INFO (MainThread) [supervisor.os.manager] Fetch OTA update from https://github.com/home-assistan ... max-plus-10.5.raucb
23-10-19 09:19:47 ERROR (MainThread) [supervisor.os.manager] Error raised from OTA Webserver: 404
23-10-19 09:24:16 INFO (MainThread) [supervisor.os.manager] Fetch OTA update from https://github.com/home-assistan ... max-plus-10.5.raucb
23-10-19 09:24:17 ERROR (MainThread) [supervisor.os.manager] Error raised from OTA Webserver: 404
23-10-19 09:24:22 INFO (MainThread) [supervisor.os.manager] Fetch OTA update from https://github.com/home-assistan ... max-plus-10.5.raucb
23-10-19 09:24:22 ERROR (MainThread) [supervisor.os.manager] Error raised from OTA Webserver: 404
U盘升级是用通用那个?
 楼主| 发表于 2023-10-19 12:07:30 | 显示全部楼层
xugeno1 发表于 2023-10-19 09:26
升级失败,这是日志,看着是没找到资源
23-10-19 09:15:08 INFO (MainThread) [supervisor.resolution.che ...
不通用的,是U盘升级。过段时间我放出来。
发表于 2023-10-19 13:41:17 | 显示全部楼层
好的
发表于 2023-10-26 16:03:18 | 显示全部楼层
坐等火贴
发表于 2023-10-27 14:41:31 | 显示全部楼层
大佬的链接失效了,哪位朋友能否再分享一下,谢谢?
 楼主| 发表于 2023-10-28 16:31:49 | 显示全部楼层
收到,己更新
发表于 2023-11-1 09:10:41 | 显示全部楼层
HASSOS的功能
GMT+8, 2026-1-20 08:26 , Processed in 1.649553 second(s), 13 queries , MemCached On.
