查看: 13593|回复: 32
[求助] Supervisor设置失败
sunn 手机认证
发表于 2023-4-6 20:25:08 | 显示全部楼层 |阅读模式
Supervisor一直显示设置失败重启也没用 Screenshot_20230406_195826_io.homeassistant.companion.android.jpg
Logger: homeassistant.config_entries
Source: components/hassio/handler.py:472
First occurred: 下午8:33:24 (1 occurrences)
Last logged: 下午8:33:24
Error setting up entry Supervisor for hassio
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 383, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 625, in async_setup_entry
    await coordinator.async_config_entry_first_refresh()
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 215, in async_config_entry_first_refresh
    await self._async_refresh(
  File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 933, in _async_refresh
    await self.hassio.refresh_updates()
  File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 35, in _wrapper
    data = await funct(*argv, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 472, in send_command
    request = await self.websession.request(
  File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 560, in _request
    await resp.start(conn)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/client_reqrep.py", line 899, in start
    message, payload = await protocol.read()  # type: ignore[union-attr]
  File "/usr/local/lib/python3.10/site-packages/aiohttp/streams.py", line 616, in read
    await self._waiter
asyncio.exceptions.CancelledError
发表于 2023-4-6 21:12:05 | 显示全部楼层
进容器把一句话注释掉,如下:
sudo docker exec -it hassio_supervisor /bin/bash
vi /usr/src/supervisor/supervisor/api/os.py
教程狂人论坛风云人物
发表于 2023-4-6 23:12:13 | 显示全部楼层
# 进入 hassio_supervisor 容器
sudo docker exec -it hassio_supervisor bash
# 备份原始文件
cp /usr/src/supervisor/supervisor/api/os.py /usr/src/supervisor/supervisor/api/os.py.bak
# 使用 sed 命令注释掉目标行
sed -i 's/ATTR_DATA_DISK: self.sys_os.datadisk.disk_used_id/# ATTR_DATA_DISK: self.sys_os.datadisk.disk_used_id/g' /usr/src/supervisor/supervisor/api/os.py
# 退出容器
exit
docker restart hassio_supervisor
docker restart homeasistant
尝试过萝卜,我想你一定会忘记青瓜
发表于 2023-4-7 16:37:54 | 显示全部楼层
重启  还是一样
发表于 2023-4-9 18:55:34 | 显示全部楼层
注释了还是设置失败
发表于 2023-4-10 10:26:14 | 显示全部楼层
相同的问题 试了都没用
发表于 2023-4-10 11:17:44 | 显示全部楼层
所以楼主解决了嘛
发表于 2023-4-10 14:02:02 | 显示全部楼层
尝试让设备连接科学上网,然后就正常了,但是断开科学是不是这样我没试过
发表于 2023-4-10 15:47:38 | 显示全部楼层
gw886 发表于 2023-4-10 14:02
尝试让设备连接科学上网,然后就正常了,但是断开科学是不是这样我没试过 ...
对的,设备在科学上网环境重启就正常,不在科学上网环境重启就会出现设置失败
发表于 2023-4-12 11:22:06 | 显示全部楼层
断开重启就马上恢复“设置失败”
GMT+8, 2026-1-21 19:55 , Processed in 0.421644 second(s), 13 queries , MemCached On.
