楼主: ryanh7
[经验分享]
3万
发表于 2023-3-20 12:37:18 | 显示全部楼层
trz0332 发表于 2023-3-20 11:35
这种方式貌似不能用web,也不支持captive_portal模式了。另外我尝试使用蓝牙代理貌似也不成功。 ...
captive_portal和web_server 提示 this feature is only available with frameworks ['arduino']
后面再加了一行:
esp32_ble_tracker:
#  scan_parameters:
#    interval: 1100ms
#    window: 1100ms
#    active: true
bluetooth_proxy:
  active: true
Linking .pioenvs/mijia-bule-plug/firmware.elf
RAM:   [==        ]  15.8% (used 51904 bytes from 327680 bytes)
Flash: [=======   ]  72.3% (used 1327445 bytes from 1835008 bytes)
Building .pioenvs/mijia-bule-plug/firmware.bin
Creating esp32 image...
Successfully created esp32 image.
esp32_create_combined_bin([".pioenvs/mijia-bule-plug/firmware.bin"], [".pioenvs/mijia-bule-plug/firmware.elf"])
Wrote 0x1557d0 bytes to file /config/.esphome/build/mijia-bule-plug/.pioenvs/mijia-bule-plug/firmware-factory.bin, ready to flash to offset 0x0
======================== [SUCCESS] Took 660.29 seconds ========================
INFO Successfully compiled program.
也可以编译成功,但没有实物刷机测试。
 楼主| 发表于 2023-3-20 13:20:50 | 显示全部楼层
trz0332 发表于 2023-3-20 11:36
魔改sdk也用过,但是貌似也是不能开蓝牙,跟楼主的差不多
哪个魔改sdk,有源码地址吗
发表于 2023-3-20 16:57:28 | 显示全部楼层
可以刷机成功,但是wifi会连不上
GMT+8, 2025-12-15 23:57 , Processed in 0.375930 second(s), 5 queries , MemCached On.
