查看: 8739|回复: 18
[技术探讨] esphome控制12v-pwm风扇后,如何在homeassistant读取滑块的数值
发表于 2023-3-3 17:05:43 | 显示全部楼层 |阅读模式
各位大神,麻烦帮帮忙,在esphome文档没有找到所需的
如上图所示,如何将滑块速度变成一个可控实体,我在日志上,只能看到开关状态,谢谢
esphome部分代码:
fan:
  - platform: speed
    output: pwmfan
    name: ${device_name} Fan_speed
    #oscillation_output: pwmfan
    #speed_count: 100
    on_speed_set:
     - logger.log: "Fan Speed was changed!"
    on_turn_on:
     - logger.log: "Fan Turned On!"
cmsj 手机认证
发表于 2023-3-4 19:12:20 | 显示全部楼层
进开发者工具状态选项卡里看看
发表于 2023-3-4 21:13:40 | 显示全部楼层
output:
  - platform: esp8266_pwm
    pin: GPIO2    #D4
    frequency: 15000 Hz
fan:
  - platform: speed
    output: pwm_output
    speed_count: 100
number:
  - platform: template
    icon: "mdi:fan"
    lambda: |-
      return id(fan_speed).speed;
    step: 1
    min_value: 30
    max_value: 100
    unit_of_measurement: "%"
    update_interval: 1s
    set_action:
      then:
        - fan.turn_on:
            speed: !lambda "return x;"
        - component.update: fanmode
        - component.update: sensor_fanspeed
select:
    icon: "mdi:fan"
    update_interval: 1s
    lambda: |-
      if(id(fan_speed).speed <= ${speed_low})
        return std::string("Low");
      else if(id(fan_speed).speed == ${speed_med})
        return std::string("Medium");
      else if(id(fan_speed).speed >= ${speed_full})
        return std::string("Full");
      else
        return std::string("Custom");
    set_action:
      then:
        - lambda: |-
            auto call = id(fan_speed).turn_on();
            if(x == "Low")
              call.set_speed(${speed_low});
            else if(x == "Medium")
              call.set_speed(${speed_med});
            else if(x == "Full")
              call.set_speed(${speed_full});
            else
              call.set_speed(id(speed_input).state);
            call.perform();
        - component.update: speed_input
    options:
      - Low
      - Medium
      - Full
      - Custom
button:
    icon: "mdi:fan-speed-1"
    on_press:
      - fan.turn_on:
          speed: "${speed_low}"
    icon: "mdi:fan-speed-2"
    on_press:
      - fan.turn_on:
          speed: "${speed_med}"
    icon: "mdi:fan-speed-3"
    on_press:
      - fan.turn_on:
          speed: "${speed_full}"
  - platform: restart
    icon: "mdi:fan"
    lambda: |-
    update_interval: 1s
    accuracy_decimals: 0
  - platform: dht
    pin: GPIO4    #D2
    temperature:
      name: "${device_name} Temperature"
    humidity:
      name: "${device_name} Humidity"
    model: AUTO_DETECT
    update_interval: 5s #获取频率
可以显示挡位
参与人数 1金钱 +10 收起 理由
sorrypqa + 10 大神666!
 楼主| 发表于 2023-3-6 14:55:00 | 显示全部楼层
感谢,我测试一下
 楼主| 发表于 2023-3-6 15:12:45 | 显示全部楼层
cmsj 发表于 2023-3-4 19:12
进开发者工具状态选项卡里看看
已经尝试过,想吧fan开关下面的进度条,暴露出来,单独控制
 楼主| 发表于 2023-3-6 15:20:49 | 显示全部楼层
可以了,感谢大神,学习到了
发表于 2023-5-10 08:57:48 | 显示全部楼层
老哥请教一下,esphome怎么控制pwm风扇啊,要怎么接线
我的pwm风扇的供电是单独用了个12v的电源供电,第三个引脚空着,esphome的GPIO16和pwm风扇的pwm引脚对接的,在hass里面调整风扇的速度,风扇的速度没有变化,但是8266的蓝灯亮度会变化
 楼主| 发表于 2023-5-10 09:31:49 | 显示全部楼层
我的pwm风扇的供电是单独用了个12v的电源供电,第三 ...
三楼大哥已经说得挺清楚了,代码方面,接线的话,好像要共地
发表于 2023-5-10 09:34:46 | 显示全部楼层
D4接PWM 另外一个接地  vin 接电源   vout接风扇
发表于 2023-5-10 10:35:23 | 显示全部楼层
我是小白,老哥再请教一下,vin是指8266的vin脚吗,这个是给8266供电的?我是用usb供电的。没找到vout脚,能不能详细的说说,非常感谢
GMT+8, 2026-1-16 14:09 , Processed in 0.338162 second(s), 11 queries , MemCached On.
