楼主: ghdong
[经验分享] 正泰DTSU666三相四线电表RS485 modbus tcp连接使用配置分享
发表于 2024-1-21 23:06:06 | 显示全部楼层
感谢楼主的信息。我用这个信息编写了一个esphome的dtsu666的配置文件。
esphome:
  friendly_name: meter-dtsu666
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "#########"  #需要替换的字段
ota:
  password: "########"  #需要替换的字段
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Meter-Dtsu666 Fallback Hotspot"
    password: "0Ssqzmbjravu"
# Enable Web server
web_server:
  port: 80
captive_portal:
globals:
  - id: chint_energy_cal
    type: std::uint32_t
    restore_value: yes
    initial_value: '0'
uart:
  tx_pin: GPIO13 # connected to tx on modbus converter
  rx_pin: GPIO12 # connected to rx on modbus converter
  baud_rate: 9600
  stop_bits: 1
  data_bits: 8
modbus:
  send_wait_time: 2000ms
#address chint dtsu666
modbus_controller:
    address: 0x1
    modbus_id: modbus1
    update_interval: 1s
    setup_priority: -10
    command_throttle: 20ms
 - platform: modbus_controller
   name: "chint voltage phase 1"
   address: 0x2006
   unit_of_measurement: "V"
   register_type: holding
   value_type: FP32
   accuracy_decimals: 1
   filters:
     - multiply: 0.1
   name: "chint voltage phase 2"
   address: 0x2008
   value_type: FP32
   filters:
     - multiply: 0.1
   name: "chint voltage phase 3"
   address: 0x200A
   value_type: FP32
   filters:
     - multiply: 0.1
   name: "chint current phase 1"
   address: 0x200C
   unit_of_measurement: "A"
   value_type: FP32
   accuracy_decimals: 2
   filters:
     - multiply: 0.01
   name: "chint current phase 2"
   address: 0x200E
   value_type: FP32
   filters:
     - multiply: 0.01
   name: "chint current phase 3"
   address: 0x2010
   value_type: FP32
   filters:
     - multiply: 0.01
   name: "chint frequency"
   address: 0x2044
   unit_of_measurement: "Hz"
   value_type: FP32
   filters:
     - multiply: 0.01
   name: "chint voltage phase 1 to 2"
   address: 0x2000
   value_type: FP32
   filters:
     - multiply: 0.1
   name: "chint voltage phase 2 to 3"
   address: 0x2002
   value_type: FP32
   filters:
     - multiply: 0.1
   name: "chint voltage phase 3 to 1"
   address: 0x2004
   value_type: FP32
   filters:
     - multiply: 0.1
   name: "chint active power total"
   address: 0x2012
   unit_of_measurement: "W"
   value_type: FP32
   accuracy_decimals: 0
   name: "chint active power phase 1"
   address: 0x2014
   value_type: FP32
   name: "chint active power phase 2"
   address: 0x2016
   value_type: FP32
   name: "chint active power phase 3"
   address: 0x2018
   value_type: FP32
   name: "chint reactive power total"
   address: 0x201A
   unit_of_measurement: "VAR"
   value_type: FP32
   name: "chint reactive power phase 1"
   address: 0x201C
   value_type: FP32
   name: "chint reactive power phase 2"
   address: 0x201E
   value_type: FP32
   name: "chint reactive power phase 3"
   address: 0x2020
   value_type: FP32
   force_new_range: true
   name: "chint energy total from grid"
   address: 0x1028
   unit_of_measurement: "kWh"
   value_type: FP32
   filters:
     - multiply: 0.01
     - lambda: |-
            float MAX_DIFFERENCE = 1.0;  // adjust this!
            static float last_value = NAN;
            if (isnan(last_value) || std::abs(x - last_value) < MAX_DIFFERENCE)
              return last_value = x;
            else
              return {};
   name: "chint energy total to grid"
   address: 0x101E
   value_type: FP32
   filters:
     - multiply: 0.01
     - lambda: |-
            else
              return {};
   name: "chint power factor total"
   address: 0x202A
   unit_of_measurement: "cosphi"
   value_type: FP32
   accuracy_decimals: 3
   filters:
     - multiply: 0.001
   name: "chint power factor phase 1"
   address: 0x202C
   value_type: FP32
   filters:
     - multiply: 0.001
   name: "chint power factor phase 2"
   address: 0x202E
   value_type: FP32
   filters:
     - multiply: 0.001
   name: "chint power factor phase 3"
   address: 0x2030
   value_type: FP32
   filters:
     - multiply: 0.001
# Todo: use correct sensor name and mark the original sensor as internal
 - platform: template
   device_class: energy
   state_class: measurement
   icon: mdi:total_increasing
   lambda: |-
       return (id(chint_forward_energy_total).state - id(chint_reversing_energy_total));
#   update_interval: 15s
# Todo: Test lambda!
button:
    name: "Chin Chin reset total energy"
    entity_category: "config"
    on_press:
      then:
        - lambda: |-
            id(chint_energy_cal) = id(chint_forward_energy_total).state;
  - platform: safe_mode
    name: "Chin Chin Restart (Safe Mode)"
  - platform: restart
    name: "Chin Chin Restart"
参与人数 1金钱 +16 收起 理由
sorrypqa + 16 高手,这是高手!
发表于 2024-2-26 21:39:07 | 显示全部楼层
谢谢。我发现两个问题:
- 新版本的HA, 需要把’count: 2‘删除。
- 有功总电能" 的地址应该是 101E, 正向有功总电能。
附DTSU666说明书。
DTSU666昆仑系列新国标的说明书 (11).pdf
1.39 MB, 下载次数: 61
发表于 2024-3-20 22:17:30 | 显示全部楼层
tcp模式下,多个电表用手拉手方式串联起来的话,配置应该怎么写。现在只接一个电表正常读书,接多个读数就出错或者“不再可用”
发表于 2025-8-28 15:01:29 | 显示全部楼层
666666666666
发表于 2025-9-3 20:50:53 | 显示全部楼层
chenquanhao 发表于 2024-3-20 22:17
tcp模式下,多个电表用手拉手方式串联起来的话,配置应该怎么写。现在只接一个电表正常读书,接多个读数就 ...
lz解决了吗
发表于 2025-9-8 22:20:26 | 显示全部楼层
解决了,是slave寄存器地址的问题,不同电表要配置不同的寄存器地址,在电表上操作,具体操作我现在忘了。配置时(按你实际配置)第一个电表slave:1,第二个电表slave:2……第十一个电表slave:11
电表数量多的话,建议先自己整理一份实际电表和寄存器地址对应表,然后在电表上对着对应表来配置,这样配置完之后,在ha配置文件上也是对着配置,就不会搞乱了。
GMT+8, 2026-1-16 06:17 , Processed in 1.615154 second(s), 18 queries , MemCached On.
