楼主: hudan717
[修仙教程] S1E硬改开启Telnet接入HA,自定义UI
 楼主| 发表于 2023-2-13 12:02:28 | 显示全部楼层
xiaoma5015369 发表于 2023-2-12 23:01
打不开 ftp是哪里的原因?2.04 1042版本
谢谢
看一下集成中ftp server有没有成功打开,如果勾不上的话,检查一下网络
发表于 2023-2-13 12:33:46 | 显示全部楼层
已经是 2.0.5_1044 了,还能搞吗?
发表于 2023-2-13 12:49:02 | 显示全部楼层
厉害了楼主 大神大神
发表于 2023-2-13 12:53:52 | 显示全部楼层
我也是,看github上说是暂时没办法,等待一下吧。
发表于 2023-2-22 23:52:05 | 显示全部楼层
捣鼓了4个小时,机器差点挂了,可算是弄好了
githubusercontent   这个地址正常情况是访问不了的,稍微小白一点尽量别操作
发表于 2023-2-23 15:01:57 | 显示全部楼层
目前只能自定义图片么?
发表于 2023-2-23 15:58:06 | 显示全部楼层
不敢尝试,还是老实用homekit反向接入了
发表于 2023-3-8 15:28:15 | 显示全部楼层
对我来说超纲了
发表于 2023-3-12 16:47:02 | 显示全部楼层
升级之后还有得救吗?
发表于 2023-3-16 00:20:29 | 显示全部楼层
版本 2.0.5_1042  通电一直按enter或者按住enter都无法中断
U-Boot 2015.01 (Aug 25 2022 - 16:38:02)
Version: P3g046f2f2
I2C:   ready
DRAM:
WARNING: Caches not enabled
SPINAND_I:  [FLASH] Found SNI in block 0.
[FLASH] dev_id = 0xee
[FLASH] mfr_id = 0xcd, dev_id= 0xea id_len = 0x3
[SPINAND] RFC ues command 0x6b with 0x08 dummy clock.
[SPINAND] Program load with command 0x32.
[SPINAND] Random load with command 0x34.
[FLASH] Unlock all block.
[FLASH] Use BDMA.
128 MiB
MMC:   MStar SD/MMC: 0
ENV: offset = 0x480000 size = 0x40000
ENV1: offset = 0x4c0000 size = 0x40000
In:    serial
Out:   serial
Err:   serial
NAND read: device 0 offset 0x520000, size 0x2d0000
Time:331857 us, speed:8886 KB/s
 2949120 bytes read: OK
gpio debug MHal_GPIO_Pad_Set: pin=59
gpio[59] is 1
st7701: rst:16, cs:0, clk:1, sdk:2
gpio debug MHal_GPIO_Pad_Set: pin=16
gpio debug MHal_GPIO_Pad_Set: pin=0
gpio debug MHal_GPIO_Pad_Set: pin=2
st7701 init...gpio debug MHal_GPIO_Pad_Set: pin=59
gpio[59] is 0
done
found the partition info of MISC
INI_GET_STR: Get LOGO:m_sPQFile0 error
can't get LOGO:m_sPQFile0
illegal param in _BootLogoSetPq:1668
clk=12M, u16Div=0 u32Duty=0x95f u32Period=0x95f
[halPWMPadSet][106] (pwmId, padId) = (0, 8)
##  Booting kernel from Legacy Image at 22000000 ...
   Image Name:   MVX4##P3##gb00ff7cKL_LX409##[BR:
   Image Type:   ARM Linux Kernel Image (lzma compressed)
   Data Size:    2324988 Bytes = 2.2 MiB
   Load Address: 20008000
   Entry Point:  20008000
   Verifying Checksum ... OK
-usb_stop(USB_PORT0)
-usb_stop(USB_PORT2)
   Uncompressing Kernel Image ...
[XZ] !!!reserved 0x21000000 length=0x 1000000 for xz!!
   XZ: uncompressed size=0x4a5000, ret=7
OK
atags:0x20000000
Starting kernel ...
early_atags_to_fdt() success
net.core.rmem_default = 163840
net.core.rmem_max = 163840
net.core.wmem_default = 524288
net.core.wmem_max = 1048576
net.ipv4.tcp_mem = 924  1232  1848
net.ipv4.tcp_rmem = 4096  87380  325120
net.ipv4.tcp_wmem = 4096  131072  393216
Loading app modules
mount /dev/mtdblock  ok
ubiattach /dev/ubi_ctrl -m 13  -d 1
UBI device number 1, total 436 LEBs (55361536 bytes, 52.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
check mount
3.92 3.21
[WatchDogInit 15] init watch dog, timeout:30s
property server run ok,wait=1
==> Detect invalid clock time, set default
Sat Jan  1 01:01:00 UTC 2022
==> start sysservice
psvr ok,wait=1
fw_manager.sh revision: 2
hostname: Magic-Switch-S1E-4933
type: lumi.switch.acn032, model: AH_M1S
check mount
psvr ok,wait=1
mDNSResponder: mDNSResponder (Engineering Build) (Dec  9 2022 18:49:03) starting
mDNSResponder: Unable to parse DNS server list. Unicast DNS-SD unavailable
mDNSResponder: mDNSPlatformSourceAddrForDest: connect 1.1.1.1 failed errno 101 (Network is unreachable)
a:0, r:0
GMT+8, 2025-12-16 15:44 , Processed in 1.313896 second(s), 14 queries , MemCached On.
