查看: 3468|回复: 3
[技术探讨] 为何不显示曲线呢?
发表于 2023-1-29 11:32:23 | 显示全部楼层 |阅读模式
参照论坛大神帖子【填坑】完美展示体重变化曲线https://bbs.hassbian.com/thread-18842-1-1.html
(出处: 『瀚思彼岸』» 智能家居技术论坛)
将S7体重秤成功接入HA并创建卡片,我的卡片没有体重变化曲线,报错日志
Logger: frontend.js.latest.202203011
Source: components/system_log/__init__.py:190
First occurred: 10:04:09 (5 occurrences)
Last logged: 10:43:05
  • https://xxxxxx.xyz:10000/lovelace/default_view:0:0 Uncaught TypeError: Failed to resolve module specifier "@rollup/plugin-node-resolve". Relative references must start with either "/", "./", or "../".
  • https://xxxxxx.xyz:10000/frontend_latest/ce9904bd.js:2:307 Uncaught TypeError: Cannot convert undefined or null to object
type: vertical-stack
cards:
  - type: entities
    entities:
      - entity: input_select.whose_weight
  - type: custom:apexcharts-card
    experimental:
      brush: true
    header:
      show: true
      show_states: true
      colorize_states: true
    all_series_config:
      stroke_width: 3
    graph_span: 365d
    now:
      show: true
    brush:
      selection_span: 30d
    series:
      - entity: sensor.weight_liangliang_history
        float_precision: 2
        curve: straight
        data_generator: |
          return entity.attributes.mesure.map((entry) => {
            return [new Date(entry.C), entry.D];
        show:
          in_brush: true
          in_chart: true
      - entity: sensor.weight_ningning_history
        float_precision: 2
        curve: straight
        data_generator: |
        show:
          in_brush: true
          in_chart: true
发表于 2023-1-30 06:38:45 来自手机 | 显示全部楼层
哦,原来还能这么玩
发表于 2023-1-30 08:11:38 | 显示全部楼层
老哥把log里的域名处理一下吧,摆出来是让人攻击的吗
 楼主| 发表于 2023-1-30 15:13:14 | 显示全部楼层
好的,修改了 感谢提醒
GMT+8, 2026-1-17 17:46 , Processed in 0.342928 second(s), 13 queries , MemCached On.
