楼主: li2244578
[教程系列] 优智云家联网指纹锁接入nodered
 火.. [复制链接]
发表于 2023-6-3 21:11:58 | 显示全部楼层
2个文件也改了,流程还是不正常: 2文件复制.jpg QQ图片20230603211028.png
发表于 2023-6-4 13:05:16 | 显示全部楼层
大佬厉害,正需要
 楼主| 发表于 2023-6-5 22:30:51 | 显示全部楼层
yuejr 发表于 2023-6-3 21:11
2个文件也改了,流程还是不正常:
这个流程看起来正常了啊.
发表于 2023-6-8 23:19:48 | 显示全部楼层
今天又重新折腾了一下,可以使用了,说一下关键点吧,一定要替换文件,否则无法实现功能,这一步做不到可以直接放弃
顺便把几种开门方式获得的json也发出来,免得大家不停测试。
联动方式不一定用mqtt之类的,这个其实自行发挥就行了。
按门铃照片
{"id":"","did":"门锁唯一识别码","name":"REMOTE_UNLOCK","level":"CRITICAL","data":{"image_uri":"https://ims.kwicdn.com/28196fe1c9ec126fd3931b9001d25cf/6481E28/kn1P71PopIm/lin8hvi.jpg"},"created_at":"2023-06-08T14:18:13Z"}
微信开锁并拍照
{"id":"","did":"门锁唯一识别码","name":"UNLOCKED","level":"INFO","data":{"lock_user":{"type":5,"id":0,"alias":"微信远程","user_id":"3cf37bd4"},"image_uri":"https://ims.kwicdn.com/2ac807b9b6a6e1e7819df863986bd/6481E33C/knoP71pIm/li84x3u.jpg"},"created_at":"2023-06-08T14:18:31Z"}
门内开锁
{"id":"","did":"门锁唯一识别码","name":"UNLOCKED","level":"INFO","data":{"lock_user":{"type":0,"id":0,"alias":"门内按钮"}},"created_at":"2023-06-08T14:33:44Z"}
人脸开锁
{"id":"","did":"门锁唯一识别码","name":"UNLOCKED","level":"INFO","data":{"lock_user":{"type":6,"id":1,"alias":"用户A"}},"created_at":"2023-06-08T14:36:22Z"}
密码开锁
{"id":"","did":"门锁唯一识别码","name":"UNLOCKED","level":"INFO","data":{"lock_user":{"type":2,"id":1,"alias":"用户A"}},"created_at":"2023-06-08T14:37:27Z"}
指纹开锁
{"id":"","did":"门锁唯一识别码","name":"UNLOCKED","level":"INFO","data":{"lock_user":{"type":1,"id":1,"alias":"用户A"}},"created_at":"2023-06-08T14:38:15Z"}
验证失败
{"id":"","did":"门锁唯一识别码","name":"LOCK_FINGERPRINT_FRONZEN","level":"CRITICAL","data":{"image_uri":"https://ims.kwicdn.com/6070d07e94e55f33a213610d4dca526/6481E82D/kno71PopIm/lin8w198.jpg"},"created_at":"2023-06-08T14:39:39Z"}
二次上锁
{"id":"","did":"门锁唯一识别码","name":"LOCKED","level":"INFO","data":{},"created_at":"2023-06-09T14:51:38Z"}
发表于 2023-6-13 10:52:06 | 显示全部楼层
li2244578 发表于 2023-6-5 22:30
这个流程看起来正常了啊.
 楼主| 发表于 2023-6-13 21:08:33 | 显示全部楼层
看下联网还有账号 密码对不对啊
发表于 2023-6-13 21:55:26 | 显示全部楼层
li2244578 发表于 2023-6-13 21:08
看下联网还有账号 密码对不对啊
账号密码是登录h5.kiwik.cn这个网站的账号密码对吧?如果是就没错。
发表于 2023-6-13 21:58:04 | 显示全部楼层
 楼主| 发表于 2023-6-13 23:24:25 | 显示全部楼层
你的x-kiwik-client-id这个没填对吧?
发表于 2023-6-14 08:44:13 | 显示全部楼层
根据你这个截图来看,是没有获取到token,排查一下优智云家的账号和密码、还有x-kiwik-client-id是不是输入正确了
GMT+8, 2026-1-12 11:30 , Processed in 0.700104 second(s), 14 queries , MemCached On.
