楼主: louis_lee
[经验分享] Deprecated
发表于 2022-11-10 15:22:58 | 显示全部楼层
使用方法二部署的,长期访问令牌申请了,看日志登录成功了,但api调用提示未授权,该如何解决,谢谢!
2022-11-10 14:32:27  [INFO    ] ---- state-refresh task run successfully!
2022-11-10 15:08:23  [INFO    ] ---- Service start!
2022-11-10 15:08:24  [INFO    ] ---- Webdriver initialized.
2022-11-10 15:08:41  [INFO    ] ---- Login successfully on https://www.95598.cn/osgweb/login
2022-11-10 15:08:47  [INFO    ] ---- Get electricity charge balance successfully, balance is 541.44 CNY.
2022-11-10 15:08:52  [INFO    ] ---- Get yesterday power consumption successfully, usage is 0.0 kwh.
2022-11-10 15:08:58  [INFO    ] ---- Homeassistant REST API invoke, POST on http://IP:8123/api/states/sensor.electricity_charge_balance. response[401]: b'401: Unauthorized'
2022-11-10 15:09:03  [INFO    ] ---- Homeassistant REST API invoke, POST on http://IP:8123/api/states/sensor.last_electricity_usage. response[401]: b'401: Unauthorized'
发表于 2022-11-10 15:28:51 | 显示全部楼层
牛的牛的牛的牛的牛的牛的牛的牛的牛的牛的
发表于 2022-11-10 15:39:15 | 显示全部楼层
2022 ...
请忽略,令牌填错了
发表于 2022-11-10 16:06:02 | 显示全部楼层
谢谢大神分享
发表于 2022-11-10 16:08:37 | 显示全部楼层
试一下,一直想要弄
发表于 2022-11-10 17:41:43 | 显示全部楼层
dalao 666
发表于 2022-11-10 17:46:17 | 显示全部楼层
有点意思
发表于 2022-11-10 18:08:09 | 显示全部楼层
这可太厉害了
发表于 2022-11-10 21:39:43 | 显示全部楼层
楼主真乃大神也。用Docker部署成功了。能成功登陆国家电网获取用电数据。但是无法上传到homeassistant。
我的sgcc_electricity Docker镜像是部署在Oracle VPS上的,与家里的homeassistant之间的通讯只能通过IPV6网络。
想问一下大神,目前是不是不支持IPV6协议啊。
root@duan:~/sgcc_electricity# docker logs sgcc
2022-11-10 21:13:59  [INFO    ] ---- Service start!
2022-11-10 21:14:03  [INFO    ] ---- patching driver executable /usr/bin/chromedriver
2022-11-10 21:14:07  [INFO    ] ---- Webdriver initialized.
2022-11-10 21:19:03  [INFO    ] ---- Login successfully on https://www.95598.cn/osgweb/login
2022-11-10 21:19:11  [INFO    ] ---- get all user id: ['210XXXX600']
2022-11-10 21:21:35  [INFO    ] ---- Get electricity charge balance for 210XXXX600 successfully, balance is 804.74 CNY.
2022-11-10 21:24:02  [INFO    ] ---- Get year power consumption for 210XXXX600 successfully, usage is 3669 kwh, yealrly charge is 1831.03 CNY
2022-11-10 21:24:02  [INFO    ] ---- Get daily power consumption for 210XXXX600 successfully, usage is 6.62 kwh.
2022-11-10 21:24:03  [INFO    ] ---- Webdriver quit after fetching data successfully.
2022-11-10 21:24:04  [ERROR   ] ---- state-refresh task failed, reason is Sensor update failed, please check the network
补充说明:估计是不支持IPV6通讯协议,我用socat作了一个IPV4到IPV6的网络转发,URL重新改成IPV4地址,这下全通了。
给楼主发一朵小红花
 楼主| 发表于 2022-11-10 22:28:09 | 显示全部楼层
我 ...
没测过,不过我觉得python requests库应该是支持IPV6的。
我记得docker IPV6 默认是关闭的,请确定docker IPV6是否打开。
如果打开了还不行,请直接使用IPV6地址而非指向IPV6的域名,避免DNS解析过程,或许会好一些。
GMT+8, 2026-1-16 09:07 , Processed in 1.451602 second(s), 12 queries , MemCached On.
