楼主: newmean
[插件集成] 给大家共享一个途强车载GPS接入HA的集成吧
发表于 2023-6-28 21:33:51 | 显示全部楼层
newmean 发表于 2022-11-7 15:57
name,就是随便填的标识符
username,就是涂强平台的账号
大神:
可以加微请教不?
发表于 2023-10-26 18:17:32 | 显示全部楼层
2023-10-26 18:09:12.230 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform legacy hatuqiangol
  File "/usr/src/homeassistant/homeassistant/components/device_tracker/legacy.py", line 303, in async_setup_legacy
    setup = await hass.async_add_executor_job(
  File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/config/custom_components/hatuqiangol/device_tracker.py", line 31, in setup_scanner
    TuQiangTrackDeviceTracker(hass, config, see)
  File "/config/custom_components/hatuqiangol/device_tracker.py", line 49, in __init__
    self._update_info()
  File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 190, in wrapper
    result = method(*args, **kwargs)
  File "/config/custom_components/hatuqiangol/device_tracker.py", line 118, in _update_info
    lat = float(data['lat'])
ValueError: could not convert string to float: ''
这个是什么问题呀
发表于 2023-11-8 21:20:13 | 显示全部楼层
同上报错,找不到实体
发表于 2023-11-24 21:40:48 | 显示全部楼层
又加了一次qq
发表于 2023-11-28 16:03:38 | 显示全部楼层
513448188美元看到你啊
发表于 2024-4-3 04:30:38 | 显示全部楼层
途强的定位器能不能同时使用途强在线和途强物流APP双平台一起使用
发表于 2024-7-16 17:31:02 | 显示全部楼层
现在这个插件还能使用吗?
GMT+8, 2026-1-14 06:22 , Processed in 0.520842 second(s), 12 queries , MemCached On.
