楼主: iciness
[基础教程] 小米净水机接入HA-----作者:xingkui wang
发表于 2018-11-29 22:46:39 来自手机 | 显示全部楼层
谢谢分享!
发表于 2018-11-29 23:02:03 | 显示全部楼层
发表于 2018-12-1 21:42:34 来自手机 | 显示全部楼层
看看,學習、學習⋯
xiee
发表于 2018-12-2 01:38:33 | 显示全部楼层
回复 下载 看看
发表于 2018-12-2 14:54:46 | 显示全部楼层
bit3725 发表于 2017-12-21 16:07
我自己升级到 homeassistant 0.60 之后发现了一个问题,https://github.com/bit3725/homeassistant-mi-wate ...
HASS 0.83.2会报错,能否指点下,谢谢哈。
Sun Dec 02 2018 14:28:17 GMT+0800 (CST)
Error while setting up platform mi_water_purifier
  File "/config/custom_components/sensor/mi_water_purifier.py", line 159, in parse_data
    status = self._device.send('get_prop', [])
  File "/usr/local/lib/python3.6/site-packages/miio/device.py", line 263, in send
    self.__id = m.data.value["id"]
TypeError: 'NoneType' object is not subscriptable
  File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=hass.loop)
  File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
    return fut.result()
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/config/custom_components/sensor/mi_water_purifier.py", line 34, in setup_platform
    waterPurifier = XiaomiWaterPurifier(device, name)
  File "/config/custom_components/sensor/mi_water_purifier.py", line 116, in __init__
    self.parse_data()
  File "/config/custom_components/sensor/mi_water_purifier.py", line 177, in parse_data
    except DeviceException:
NameError: name 'DeviceException' is not defined
unable to parse json '{"result":[net],"id":1}': Expecting value: line 1 column 12 (char 11)
发表于 2018-12-2 15:40:06 | 显示全部楼层
  File "/config ...
我也和你一样,解决了吗?怎么处理的。
发表于 2018-12-2 21:35:24 | 显示全部楼层
谢谢分享!!!
发表于 2018-12-4 16:42:53 | 显示全部楼层
    return fut.result()
    self.parse_data()
发表于 2018-12-4 17:30:02 来自手机 | 显示全部楼层
谢谢分享
发表于 2018-12-5 13:02:47 | 显示全部楼层
学习学习
GMT+8, 2026-1-16 17:09 , Processed in 0.895721 second(s), 11 queries , MemCached On.
