楼主: iciness
[基础教程] 小米净水机接入HA-----作者:xingkui wang
发表于 2018-9-27 12:31:55 | 显示全部楼层
新建 事件 > 系统 > 收到意图
发表于 2018-9-27 14:21:12 | 显示全部楼层
学习一下
发表于 2018-9-30 03:22:45 来自手机 | 显示全部楼层
这个好啊
发表于 2018-9-30 13:50:17 | 显示全部楼层
牛了,我刚刚收到一个尽水器
发表于 2018-10-5 23:53:13 来自手机 | 显示全部楼层
膜拜大佬,学习一下
发表于 2018-10-6 09:44:17 | 显示全部楼层
好好学习,天天向上!
发表于 2018-10-6 12:15:57 | 显示全部楼层
来学习学习
y169
发表于 2018-10-7 09:59:01 | 显示全部楼层
谢谢分享!
发表于 2018-10-9 13:03:14 | 显示全部楼层
bit3725 发表于 2017-12-21 16:07
我自己升级到 homeassistant 0.60 之后发现了一个问题,https://github.com/bit3725/homeassistant-mi-wate ...
HA 版本
0.77.3
按最新的py接入后,HA“状态”无法看到相关实体,以下是报错信息
2018-10-09 04:48:46 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform mi_water_purifier
  File "/usr/local/lib/python3.6/site-packages/miio/device.py", line 258, in send
    m = Message.parse(data, token=self.token)
  File "/usr/local/lib/python3.6/site-packages/construct/core.py", line 288, in parse
    return self.parse_stream(io.BytesIO(data), **contextkw)
  File "/usr/local/lib/python3.6/site-packages/construct/core.py", line 298, in parse_stream
    return self._parsereport(stream, context, "(parsing)")
  File "/usr/local/lib/python3.6/site-packages/construct/core.py", line 310, in _parsereport
    obj = self._parse(stream, context, path)
  File "/usr/local/lib/python3.6/site-packages/construct/core.py", line 2064, in _parse
    subobj = sc._parsereport(stream, context, path)
  File "/usr/local/lib/python3.6/site-packages/construct/core.py", line 2554, in _parse
    return self.subcon._parsereport(stream, context, path)
  File "/usr/local/lib/python3.6/site-packages/construct/core.py", line 3682, in _parse
    return sc._parsereport(stream, context, path)
  File "/usr/local/lib/python3.6/site-packages/construct/core.py", line 4998, in _parse
    hash2 if not isinstance(hash2,bytestringtype) else binascii.hexlify(hash2), ))
construct.core.ChecksumError: wrong checksum, read b'ffffffffffffffffffffffffffffffff', computed b'3aa44fce79f7ff5d2ee7fb2efc45c626'
The above exception was the direct cause of the following exception:
  File "/config/custom_components/sensor/mi_water_purifier.py", line 159, in parse_data
    status = self._device.send('get_prop', [])
  File "/usr/local/lib/python3.6/site-packages/miio/device.py", line 279, in send
    "Please check your token!") from ex
miio.exceptions.DeviceException: Got checksum error which indicates use of an invalid token. Please check your token!
  File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=hass.loop)
  File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
    return fut.result()
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/config/custom_components/sensor/mi_water_purifier.py", line 34, in setup_platform
    waterPurifier = XiaomiWaterPurifier(device, name)
  File "/config/custom_components/sensor/mi_water_purifier.py", line 116, in __init__
    self.parse_data()
  File "/config/custom_components/sensor/mi_water_purifier.py", line 177, in parse_data
    except DeviceException:
NameError: name 'DeviceException' is not defined
发表于 2018-10-9 13:50:16 | 显示全部楼层
正要入手呢  正需要的东西
GMT+8, 2026-1-16 15:43 , Processed in 0.602746 second(s), 17 queries , MemCached On.
