楼主: wuxin0912
[技术探讨] 再开新坑,华为手机定位接入(华为云)
发表于 2022-9-11 20:56:11 | 显示全部楼层
binghun9806 发表于 2022-8-19 18:48
谢谢了,启动成功,
命令如下,有需要的可以参考:
sudo apt-get update
请问您运行成功了吗,我这里能输入邮箱什么的,但是没法加载,会报错:
此错误来自自定义集成。
Logger: root
Source: custom_components/huawei_cloud/__init__.py:184
Integration: 华为云服务 (documentation, issues)
First occurred: 16:13:40 (2 occurrences)
Last logged: 16:16:06
Uncaught thread exception
  File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 174, in _new_conn
    conn = connection.create_connection(
  File "/usr/local/lib/python3.9/site-packages/urllib3/util/connection.py", line 95, in create_connection
    raise err
  File "/usr/local/lib/python3.9/site-packages/urllib3/util/connection.py", line 85, in create_connection
    sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
  File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 703, in urlopen
    httplib_response = self._make_request(
  File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 398, in _make_request
    conn.request(method, url, **httplib_request_kw)
  File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 239, in request
    super(HTTPConnection, self).request(method, url, body=body, headers=headers)
  File "/usr/local/lib/python3.9/http/client.py", line 1285, in request
    self._send_request(method, url, body, headers, encode_chunked)
  File "/usr/local/lib/python3.9/http/client.py", line 1331, in _send_request
    self.endheaders(body, encode_chunked=encode_chunked)
  File "/usr/local/lib/python3.9/http/client.py", line 1280, in endheaders
    self._send_output(message_body, encode_chunked=encode_chunked)
  File "/usr/local/lib/python3.9/http/client.py", line 1040, in _send_output
    self.send(msg)
  File "/usr/local/lib/python3.9/http/client.py", line 980, in send
    self.connect()
  File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 205, in connect
    conn = self._new_conn()
  File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 186, in _new_conn
    raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0xffff91a99a00>: Failed to establish a new connection: [Errno 111] Connection refused
  File "/config/custom_components/huawei_cloud/__init__.py", line 197, in start_driver
    self._driver = webdriver.Remote(command_executor=self._selenium_host, options=chrome_options,
  File "/usr/local/lib/python3.9/site-packages/selenium/webdriver/remote/webdriver.py", line 270, in __init__
    self.start_session(capabilities, browser_profile)
  File "/usr/local/lib/python3.9/site-packages/selenium/webdriver/remote/webdriver.py", line 363, in start_session
    response = self.execute(Command.NEW_SESSION, parameters)
  File "/usr/local/lib/python3.9/site-packages/selenium/webdriver/remote/webdriver.py", line 426, in execute
    response = self.command_executor.execute(driver_command, params)
  File "/usr/local/lib/python3.9/site-packages/selenium/webdriver/remote/remote_connection.py", line 344, in execute
    return self._request(command_info[0], url, body=data)
  File "/usr/local/lib/python3.9/site-packages/selenium/webdriver/remote/remote_connection.py", line 366, in _request
    response = self._conn.request(method, url, body=body, headers=headers)
  File "/usr/local/lib/python3.9/site-packages/urllib3/request.py", line 78, in request
    return self.request_encode_body(
  File "/usr/local/lib/python3.9/site-packages/urllib3/request.py", line 170, in request_encode_body
    return self.urlopen(method, url, **extra_kw)
  File "/usr/local/lib/python3.9/site-packages/urllib3/poolmanager.py", line 376, in urlopen
    response = conn.urlopen(method, u.request_uri, **kw)
  File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 813, in urlopen
  File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 785, in urlopen
    retries = retries.increment(
  File "/usr/local/lib/python3.9/site-packages/urllib3/util/retry.py", line 592, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='localhost', port=4444): Max retries exceeded with url: /session (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0xffff91a99a00>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0xffff84e7e670>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='localhost', port=4444): Max retries exceeded with url: /session (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0xffff84e7e670>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0xffff871e63a0>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='localhost', port=4444): Max retries exceeded with url: /session (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0xffff871e63a0>: Failed to establish a new connection: [Errno 111] Connection refused'))
    raise err
    sock.connect(sa)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0xffff85fe4f40>: Failed to establish a new connection: [Errno 111] Connection refused
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='localhost', port=4444): Max retries exceeded with url: /session (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0xffff85fe4f40>: Failed to establish a new connection: [Errno 111] Connection refused'))
  File "/usr/local/lib/python3.9/threading.py", line 973, in _bootstrap_inner
    self.run()
  File "/usr/local/lib/python3.9/threading.py", line 910, in run
    self._target(*self._args, **self._kwargs)
  File "/config/custom_components/huawei_cloud/__init__.py", line 226, in start_driver
    self.start_driver(num+1)
  [Previous line repeated 1 more time]
  File "/config/custom_components/huawei_cloud/__init__.py", line 184, in start_driver
    raise TypeError('重试3次还未加载')
TypeError: 重试3次还未加载
发表于 2022-9-17 18:24:03 | 显示全部楼层
安装成功以后,正常运行一段时间就开始报错了。
File "/srv/homeassistant/homeassistant_venv/lib/python3.9/site-packages/homeassistant/helpers/update_coordinator.py", line 205, in _async_refresh
    self.data = await self._async_update_data()
  File "/home/homeassistant/.homeassistant/custom_components/huawei_cloud/__init__.py", line 394, in _async_update_data
    await self.check_active()
  File "/home/homeassistant/.homeassistant/custom_components/huawei_cloud/__init__.py", line 236, in check_active
    raise TypeError('正在登录,当前更新取消')
TypeError: 正在登录,当前更新取消
2022-09-17 18:16:57.001 ERROR (MainThread) [custom_components.huawei_cloud] Unexpected error fetching huawei_cloud data: 正在登录,当前更新取消
 楼主| 发表于 2022-9-17 21:47:06 来自手机 | 显示全部楼层
此错误来自自定义集成。
你应该是驱动没装好,驱动访问不了
 楼主| 发表于 2022-9-17 21:49:20 来自手机 | 显示全部楼层
File "/srv/homeassistant/homeassistant_venv/lib/pytho ...
实例生成成功了没,是否有定位消息 ,这个日志应该不影响,可能是启动多次导致,重启下应该就可以了
 楼主| 发表于 2022-9-17 21:50:53 来自手机 | 显示全部楼层
wuxin0912 发表于 2022-9-17 21:47
你应该是驱动没装好,驱动访问不了
你应该是驱动没装好,驱动访问不了
发表于 2022-9-21 22:15:56 | 显示全部楼层
此错误来自自定义集成。
不清楚你的问题的原因,但是ubuntu20以上版本安装驱动成功之后驱动chromium仍不能启动,导致插件登录上了,但是没有实体出现,可以按照下面步骤试一下:
vi /usr/share/applications/chromium.desktop
#或者
vi /usr/share/applications/lxde-x-www-browser.desktop
将Exec=/usr/bin/chromium %U
#修改为
Exec=/usr/bin/chromium %U --no-sandbox
然后重启,
发表于 2022-9-25 18:29:13 | 显示全部楼层
wuxin0912 发表于 2022-9-17 21:49
实例生成成功了没,是否有定位消息 ,这个日志应该不影响,可能是启动多次导致,重启下应该就可以了 ...
运行正常,只是运行一段时间,就不更新了,一直报错。重启HA也是。但小米云没问题。
 楼主| 发表于 2022-9-26 04:02:22 来自手机 | 显示全部楼层
yunyangx 发表于 2022-9-25 18:29
运行正常,只是运行一段时间,就不更新了,一直报错。重启HA也是。但小米云没问题。 ...
错误日志看一下
发表于 2022-11-8 11:07:21 | 显示全部楼层
终于有华为云的爬虫了,爬的我一脸懵逼
发表于 2022-11-26 01:54:40 | 显示全部楼层
虚拟机怎么安装驱动
GMT+8, 2026-1-15 18:18 , Processed in 1.225060 second(s), 12 queries , MemCached On.
