楼主: 121665460
[进阶教程] 【魔百盒】(M401A)通过刷入CoreELEC实现安装supervisor,写入EMMC
发表于 2022-12-21 17:39:53 | 显示全部楼层
好家伙,又有新玩法
发表于 2023-1-15 17:49:17 | 显示全部楼层
感谢,目前已经安装成功。但是还在摸索如何安装HACS........ supervisor也不显示
发表于 2023-2-14 22:21:04 | 显示全部楼层
iyonge 发表于 2022-9-13 01:25
按复位键还没看到画面就松开了,没进去系统,后来重启再按复位键怎么按都没反应,一直停在移动开机画面,怎 ...
我也是,U盘引导armbian没问题,但不知道为啥CoreELEC不行。
发表于 2023-2-15 16:54:31 | 显示全部楼层
请教楼主盒子刷的是什么固件,我的m401a线刷了android_tv_m401a_s905l3a固件(解压后是江苏M401A原机官改root线刷当贝桌面.img),能引导U盘里的armbian,但是同一个U盘烧写CoreELEC引导就要么卡在开机画面,要么进了recovery。
发表于 2023-2-15 21:48:47 | 显示全部楼层
XCray 发表于 2022-8-5 15:49
好像比armbian省事多了?我折腾armbian不顺的时候几次想刷成这个
XCray你好,能否告知一下你的M401a盒子刷CoreELEC之前,盒子刷的是哪个固件?我线刷过很多固件,都没法U盘引导CoreELEC,反倒是能引导armbian
发表于 2023-3-25 17:46:41 | 显示全部楼层
请问写入emmc报错如何解决?
Starting CoreELEC eMMC installation tool...
System is not supported: g12a_s905x2_2g!
There is NO official support by Team CoreELEC
if you continue to run this tool!
Continue? [y]: y
eMMC size: 0x0003a4000000 [16GB]
No CoreELEC installation found on eMMC
Install in dual boot mode, CoreELEC and Android on eMMC
  Use CoreELEC data from
    [1] current used SD or USB device
    [2] existing backup on current used SD or USB device
Install in single boot mode not possible!
  No DT partition was found
Please choose one option? [1/2]: 1
Free space of 'partition CE_FLASH': 512MB
mount: mounting /dev/loop2 on /media/CE_STORAGE failed: Invalid argument
Error running pclose on cmd: `mount -o rw,loop /dev/loop2 /media/CE_STORAGE`. Er     ror: 255
Error executing cmd 'mount -o rw,loop /dev/loop2 /media/CE_STORAGE'
Failed to mount 'CE_STORAGE' partition!
Failed to read free space of partition 'CE_STORAGE'!
Failed to create new partition table!
发表于 2023-7-1 22:31:48 | 显示全部楼层
wenming 发表于 2023-3-25 17:46
请问写入emmc报错如何解决?
刚刚刷完。差不多是跟着楼主
我一开始是从coreelec官网上找的20.2的镜像,一样出错。报错代码在下面
然后我又试了一下上面提供的19.5的镜像,成功刷入emmc,并且可以正常更新。
CoreELEC:~ # ceemmc -x
Continue? [y]: y
eMMC size: 0x0003a3e00000 [16GB]
Install in single boot mode, only CoreELEC on eMMC
    [3] current used SD or USB device
    [4] existing backup on current used SD or USB device
Please choose one option? [1/2/3/4]: 3
Warning: Could not find 'dto' partition!
Could not find 'CE_STORAGE' partition!
Failed to read size of partition 'CE_STORAGE'!
GMT+8, 2026-1-16 23:00 , Processed in 0.353085 second(s), 13 queries , MemCached On.
