查看: 16022|回复: 31
[技术探讨] 【求助】小米人脸识别智能门锁X如何通过gateway3接入HA
发表于 2022-7-17 08:33:05 | 显示全部楼层 |阅读模式
求助下大家有没有用这个锁的: 小米人脸识别智能门锁 X (lumi.lock.bmcn05)https://home.miot-spec.com/s/3685以前发过帖子问大家有没有接入方法,大家给我出谋划策十分感谢,但是无奈我挺笨的一直没接进去,@hackyjso 给了个思路说是自己编写yaml文件将门锁加入gateway3但是我根据大佬给的连接(https://github.com/AlexxIT/XiaomiGateway3/wiki/Converters)尝试接入了一下,还是发现没有接进去,所以想问问大家有没有尝试过自己编写下xiaomi_gateway3.py文件将本来不支持的设备添加进gateway3插件的?
我看gateway一共官方支持3款BLE小米的门锁,
XiaomiDoor LockMJZNMS02LM
XiaomiDoor LockMJZNMS03LM
XiaomiDoor LockXMZNMST02YD
其中 MJZNMS02LMMJZNMS03LM 都是lumi的,所以我想是否也可以简单的编写xiaomi_gateway3.py文件将这个锁接入呢?
以下是我根据gateway3的devices.py里面关于门锁的代码粘贴进自己编写的xiaomi_gateway3.py文件代码
from custom_components.xiaomi_gateway3.core.converters.devices import *
DEVICES = [{
    3685: ["Xiaomi", "Mi Smart Door Lock with Face Unlock X", "lumi.lock.bmcn05"],
    "spec": [
        MiBeacon,
        # sensors:
        Converter("action", "sensor", enabled=None),
        Converter("battery", "sensor", enabled=None),
        Converter("conductivity", "sensor", enabled=None),
        Converter("formaldehyde", "sensor", enabled=None),
        Converter("humidity", "sensor", enabled=None),
        Converter("idle_time", "sensor", enabled=None),
        Converter("illuminance", "sensor", enabled=None),
        Converter("moisture", "sensor", enabled=None),
        Converter("rssi", "sensor", enabled=None),
        Converter("supply", "sensor", enabled=None),
        Converter("temperature", "sensor", enabled=None),
        # binary_sensors:
        Converter("contact", "binary_sensor", enabled=None),
        Converter("gas", "binary_sensor", enabled=None),
        Converter("light", "binary_sensor", enabled=None),
        Converter("lock", "binary_sensor", enabled=None),
        Converter("motion", "binary_sensor", enabled=None),
        Converter("opening", "binary_sensor", enabled=None),
        Converter("sleep", "binary_sensor", enabled=None),
        Converter("smoke", "binary_sensor", enabled=None),
        Converter("water_leak", "binary_sensor", enabled=None),
}] + DEVICES
但是接入之后,还是只有一个空的action和门锁电量和BLE状态
发表于 2022-7-24 18:04:17 | 显示全部楼层
我也在愁这个问题,顶一下
 楼主| 发表于 2022-7-24 23:06:36 | 显示全部楼层
jasongin 发表于 2022-7-24 18:04
我也在愁这个问题,顶一下
已经解决了,一个群里的大佬说的,你直接在这个action里面点开属性,就可以看到门和锁的状态,只不过需要在接入gateway3后手动开关一下门,因为是蓝牙广播信号,所以需要有动作,才会显示属性值 微信截图_20220724230610.png
发表于 2022-8-28 20:37:21 | 显示全部楼层
过来排一下队,买了这个门锁一直没能接进去~好烦恼
 楼主| 发表于 2022-9-2 21:21:16 | 显示全部楼层
看我上你一条恢复,需要gateway3接入
发表于 2022-9-4 08:12:51 | 显示全部楼层
同样的问题
发表于 2022-10-13 00:41:34 | 显示全部楼层
大佬你解决了吗 我也是这种情况!
发表于 2022-11-19 10:40:32 | 显示全部楼层
啊 同样问题,
只是 我这啥也看不见呢。。。完全没反应
docker 环境,
xiaomi_gateway3.py   放在 根目录  和  configuration.yaml 同级目录
发表于 2022-12-5 10:24:45 | 显示全部楼层
应该把所有信息都放进来。和小米app里一样
发表于 2022-12-6 16:50:59 | 显示全部楼层
DEVICES = [{
    "spec": [
        MiBeacon,
你试试这个,我看着修改了一下,不过我没设备,没调试,看着大差不差的
GMT+8, 2026-2-2 04:31 , Processed in 0.174189 second(s), 13 queries , MemCached On.
