楼主: moe1983
[人体存在] 【更新3】无线调试、监控人体存在感应雷达数据(LD2410H)
发表于 2023-6-10 22:14:43 | 显示全部楼层
膜拜一下大佬
发表于 2023-6-10 22:50:40 | 显示全部楼层
shafashafa
发表于 2023-6-12 22:35:55 | 显示全部楼层
感谢感谢感谢感谢感谢
发表于 2023-6-13 00:47:28 | 显示全部楼层
发表于 2023-6-13 17:29:49 | 显示全部楼层
1、支持读取光敏数据
2、增加重启LD2410功能
3、打开
run_RTA
会自动打开DEBUG模式,方便调试
4、tx_pin: GPIO1
   rx_pin: GPIO3
   LD2410输出接: GPIO5  #D1
   SR602输出接: GPIO4  #D2
   总输出接: GPIO0  #D3(红外发现有人开始输出,打开调试模式,LD2410确定没人结束输出,关闭调试模式)
esphome代码
substitutions:
  friendly_name: "杂物间传感器"
esphome:
  friendly_name: ${friendly_name}
  on_boot:
    priority: 700
    then:
      - wait_until:
          api.connected:
      - lambda: id(config_mode).turn_on();
      - script.execute: get_all_params
      - uart.write: [0xFD,0xFC,0xFB,0xFA,0x02,0x00,0x63,0x00,0x04,0x03,0x02,0x01] #默认关闭工程模式
      - delay: 1s
      - lambda: id(config_mode).turn_off();
  includes:
    - ld2410h.h
esp8266:
  board: d1_mini
  restore_from_flash: true
# Enable logging
logger:
  #level: ERROR
  baud_rate: 0 #disable logging over uart
# Enable Home Assistant API
api:
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: ${name}
    password: "huaaiyicheng"
web_server:
  port: 80
  include_internal: true
  ota: false
  version: 2
script:
  - id: get_all_params
    then:
      - uart.write: [0xFD,0xFC,0xFB,0xFA,0x02,0x00,0x61,0x00,0x04,0x03,0x02,0x01]
      - delay: 1s
  - platform: custom
    lambda: |-
      auto s = new ld2410(id(uart_bus1));
      App.register_component(s);
      return {s->mov_distance_sensor, s->mov_energy, s->occ_distance_sensor, s->occ_energy, s->detect_distance_sensor, s->en_mov_0, s->en_mov_1, s->en_mov_2, s->en_mov_3, s->en_mov_4, s->en_mov_5, s->en_mov_6, s->en_mov_7, s->en_mov_8, s->en_occ_0, s->en_occ_1, s->en_occ_2, s->en_occ_3, s->en_occ_4, s->en_occ_5, s->en_occ_6, s->en_occ_7, s->en_occ_8, s->brightness};
    sensors:
      - name: 2410_mov_distance
        #internal: true
        unit_of_measurement: m
        accuracy_decimals: 2
        icon: mdi:tape-measure
        filters:
          - lambda: return x/100;
      - name: 2410_mov_energy
        icon: mdi:run-fast
      - name: 2410_occ_distance
        #internal: true
        filters:
      - name: 2410_occ_energy
        icon: mdi:motion-sensor
      - name: 2410_detect_distance
        #internal: true
        filters:
      # 各个距离门能量值
      - name: en_mov_0
      - name: en_mov_1
      - name: en_mov_2
      - name: en_mov_3
      - name: en_mov_4
      - name: en_mov_5
      - name: en_mov_6
      - name: en_mov_7
      - name: en_mov_8
      - name: en_occ_0
      - name: en_occ_1
      - name: en_occ_2
      - name: en_occ_3
      - name: en_occ_4
      - name: en_occ_5
      - name: en_occ_6
      - name: en_occ_7
      - name: en_occ_8
      - name: 2410_brightness
        icon: mdi:solar-power
text_sensor:
  - platform: template
uart:
  tx_pin: GPIO1
  rx_pin: GPIO3
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
#  debug:
#    direction: BOTH
#    after:
#      delimiter: [0xF8, 0xF7, 0xF6, 0xF5]
binary_sensor:
  - platform: gpio
    pin: GPIO5  #D1
    device_class: presence
    on_release:
      then:
        - switch.turn_off: run_rta
        - light.turn_off: human_presence_light
  - platform: gpio
    pin: GPIO4  #D2
    device_class: motion
    on_press:
      then:
        - switch.turn_on: run_rta
        - light.turn_on: human_presence_light
output:
  - platform: gpio
    pin: GPIO0  #D3
    inverted: true
light:
  - platform: binary
    output: "human_presence"
    name: "human presence light"
switch:
    optimistic: true
    on_turn_on:
      - uart.write: [0xFD, 0xFC, 0xFB, 0xFA, 0x04, 0x00, 0xFF, 0x00, 0x01, 0x00, 0x04, 0x03, 0x02, 0x01]
      - delay: 1s
    on_turn_off:
      - uart.write: [0xFD, 0xFC, 0xFB, 0xFA, 0x02, 0x00, 0xFE, 0x00, 0x04, 0x03, 0x02, 0x01]
      - delay: 1s
    optimistic: true
    on_turn_on:
      - lambda: id(debug_mode).turn_on();
    on_turn_off:
      - lambda: id(debug_mode).turn_off();
    optimistic: true
    on_turn_on:
      - uart.write: [0xFD, 0xFC, 0xFB, 0xFA, 0x02, 0x00, 0x62, 0x00, 0x04, 0x03, 0x02, 0x01]
      - delay: 1s
    on_turn_off:
      - uart.write: [0xFD, 0xFC, 0xFB, 0xFA, 0x02, 0x00, 0x63, 0x00, 0x04, 0x03, 0x02, 0x01]
      - delay: 1s
#  - platform: template
#    name: "BlueTooth"
#    optimistic: true
#    on_turn_on:
#      - lambda: id(config_mode).turn_on();
#      # 蓝牙开
#      - uart.write: [0xFD, 0xFC, 0xFB, 0xFA, 0x04, 0x00, 0xA4, 0x00, 0x01, 0x00, 0x04, 0x03, 0x02, 0x01]
#      - delay: 0.5s
#      # ld2410b 重启
#      - uart.write: [0xFD, 0xFC, 0xFB, 0xFA, 0x02, 0x00, 0xA3, 0x00, 0x04, 0x03, 0x02, 0x01]
#      - delay: 1s
#      - lambda: id(config_mode).turn_off();
#    on_turn_off:
#      # 蓝牙关
#      - uart.write: [0xFD, 0xFC, 0xFB, 0xFA, 0x04, 0x00, 0xA4, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01]
#      - delay: 1s
#      # ld2410b 重启
#      - delay: 1s
button:
    on_press:
  - platform: restart
    on_press:
      # ld2410b 重启
      - delay: 1s
    on_press:
      - uart.write: [0xFD, 0xFC, 0xFB, 0xFA, 0x02, 0x00, 0xA2, 0x00, 0x04, 0x03, 0x02, 0x01]
      - delay: 1s
      - delay: 1s
number:
    min_value: 0.75
    max_value: 6
    initial_value: 6
    step: 0.75
    #restore_value: true
    optimistic: true
    unit_of_measurement: m   #手册没有配置命令??服了
    name: max_mov_distance  #最大移动探测距离
    min_value: 0.75
    max_value: 6
    initial_value: 6
    step: 0.75
    optimistic: true
    set_action:
      - uart.write: !lambda
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x60, 0x00, 0x00, 0x00, (unsigned char)(int)(x/0.75), 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)(int)(id(max_occ_distance).state/0.75), 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(none_duration).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    name: max_occ_distance  #最大静止探测距离
    min_value: 0.75
    max_value: 6
    initial_value: 6
    step: 0.75
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x60, 0x00, 0x00, 0x00, (unsigned char)(int)(id(max_mov_distance).state/0.75), 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)(int)(x/0.75), 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(none_duration).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 120
    initial_value: 5
    step: 1
    optimistic: true
    unit_of_measurement: s
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x60, 0x00, 0x00, 0x00, (unsigned char)(int)(id(max_mov_distance).state/0.75), 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)(int)(id(max_occ_distance).state/0.75), 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)0, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_0).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)1, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_1).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)2, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_2).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)3, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_3).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)4, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_4).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)5, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_5).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)6, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_6).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)7, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_7).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)8, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_8).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)0, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_0).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)1, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_1).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)2, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_2).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)3, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_3).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)4, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_4).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)5, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_5).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)6, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_6).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)7, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_7).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD, 0xFC, 0xFB, 0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)8, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_8).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    name: update_interval  #实时监控刷新间隔,越大越慢,大概500间隔为1秒
    min_value: 100
    max_value: 5000
    initial_value: 500
    step: 100
    restore_value: true
    optimistic: true
    #mode: box
ld2410h.h代码
#include "esphome.h"
#include <sstream>
class ld2410 : public Component, public UARTDevice
public:
    ld2410(UARTComponent *parent) : UARTDevice(parent) {}
    Sensor *mov_distance_sensor = new Sensor();
    Sensor *mov_energy = new Sensor();
    Sensor *occ_distance_sensor = new Sensor();
    Sensor *occ_energy = new Sensor();
    Sensor *detect_distance_sensor = new Sensor();
    Sensor *en_mov_0 = new Sensor();
    Sensor *en_mov_1 = new Sensor();
    Sensor *en_mov_2 = new Sensor();
    Sensor *en_mov_3 = new Sensor();
    Sensor *en_mov_4 = new Sensor();
    Sensor *en_mov_5 = new Sensor();
    Sensor *en_mov_6 = new Sensor();
    Sensor *en_mov_7 = new Sensor();
    Sensor *en_mov_8 = new Sensor();
    Sensor *en_occ_0 = new Sensor();
    Sensor *en_occ_1 = new Sensor();
    Sensor *en_occ_2 = new Sensor();
    Sensor *en_occ_3 = new Sensor();
    Sensor *en_occ_4 = new Sensor();
    Sensor *en_occ_5 = new Sensor();
    Sensor *en_occ_6 = new Sensor();
    Sensor *en_occ_7 = new Sensor();
    Sensor *en_occ_8 = new Sensor();
    Sensor *brightness = new Sensor();
    std::vector<uint8_t> bytes;
    std::vector<uint8_t> header_parameter = {0xFD, 0xFC, 0xFB, 0xFA, 0x1C, 0x00, 0x61, 0x01, 0x00, 0x00, 0xAA};
    std::vector<uint8_t> header_data = {0xF4, 0xF3, 0xF2, 0xF1, 0x0D, 0x00};
    std::vector<uint8_t> header_data_debug = {0xF4, 0xF3, 0xF2, 0xF1, 0x23, 0x00};
//调试用    std::vector<uint8_t> header_feedback = {0xFD, 0xFC, 0xFB, 0xFA, 0x04, 0x00};
    bool HeaderMatched(std::vector<uint8_t> bytes, std::vector<uint8_t> header)
        if (bytes[0] != header[0] || bytes[1] != header[1] || bytes[2] != header[2] || bytes[3] != header[3])
            return false;
        return bytes[4] == header[4] && bytes[5] == header[5];
    void setup() override
    void loop() override
        static int data_count = 0;
        static bool presence_state = true;  //无人时不监控,节省运算量
        while (available() > 0)  // && (id(run_rta).state || id(config_mode).state)
            bytes.push_back(read());
            if (bytes.size() < 6 + 3)    //多取3位,用于判断是否有人
                continue;
            if ((HeaderMatched(bytes, header_data) || HeaderMatched(bytes, header_data_debug)) && id(run_rta).state)
//                if (bytes[8])
                if (1==1)
                    if (bytes.size() < 6 + bytes[4])
                        continue;
                    data_count++;
                    if (data_count > id(update_interval).state)
                        data_count = 0;
                        LDDATAUnion lddataUnion;
                        std::copy(bytes.begin() + 6, (bytes.begin() + 6 + bytes[4]), lddataUnion.bytes);
                        switch (lddataUnion.lddata.target_state)
                            case 0:
                                id(target_state).publish_state("none");
                                break;
                            case 1:
                                id(target_state).publish_state("mov");
                                break;
                            case 2:
                                id(target_state).publish_state("occ");
                                break;
                            case 3:
                                id(target_state).publish_state("mov & occ");
                                break;
                        mov_distance_sensor->publish_state(lddataUnion.lddata.mov_distance1 + lddataUnion.lddata.mov_distance2 * 256);
                        mov_energy->publish_state(lddataUnion.lddata.mov_energy);
                        occ_distance_sensor->publish_state(lddataUnion.lddata.occ_distance1 + lddataUnion.lddata.occ_distance2 * 256);
                        occ_energy->publish_state(lddataUnion.lddata.occ_energy);
                        detect_distance_sensor->publish_state(lddataUnion.lddata.detect_distance1 + lddataUnion.lddata.detect_distance2 * 256);
                        if (lddataUnion.lddata.data_mode == 1) //工程模式
                            en_mov_0->publish_state(lddataUnion.lddata.en_mov_0);
                            en_mov_1->publish_state(lddataUnion.lddata.en_mov_1);
                            en_mov_2->publish_state(lddataUnion.lddata.en_mov_2);
                            en_mov_3->publish_state(lddataUnion.lddata.en_mov_3);
                            en_mov_4->publish_state(lddataUnion.lddata.en_mov_4);
                            en_mov_5->publish_state(lddataUnion.lddata.en_mov_5);
                            en_mov_6->publish_state(lddataUnion.lddata.en_mov_6);
                            en_mov_7->publish_state(lddataUnion.lddata.en_mov_7);
                            en_mov_8->publish_state(lddataUnion.lddata.en_mov_8);
                            en_occ_0->publish_state(lddataUnion.lddata.en_occ_0);
                            en_occ_1->publish_state(lddataUnion.lddata.en_occ_1);
                            en_occ_2->publish_state(lddataUnion.lddata.en_occ_2);
                            en_occ_3->publish_state(lddataUnion.lddata.en_occ_3);
                            en_occ_4->publish_state(lddataUnion.lddata.en_occ_4);
                            en_occ_5->publish_state(lddataUnion.lddata.en_occ_5);
                            en_occ_6->publish_state(lddataUnion.lddata.en_occ_6);
                            en_occ_7->publish_state(lddataUnion.lddata.en_occ_7);
                            en_occ_8->publish_state(lddataUnion.lddata.en_occ_8);
                            brightness->publish_state(lddataUnion.lddata.brightness);
                        bytes.clear();
                else if (presence_state)
                    mov_distance_sensor->publish_state(0);
                    mov_energy->publish_state(0);
                    occ_distance_sensor->publish_state(0);
                    occ_energy->publish_state(0);
                    detect_distance_sensor->publish_state(0);
                    en_mov_0->publish_state(0);
                    en_mov_1->publish_state(0);
                    en_mov_2->publish_state(0);
                    en_mov_3->publish_state(0);
                    en_mov_4->publish_state(0);
                    en_mov_5->publish_state(0);
                    en_mov_6->publish_state(0);
                    en_mov_7->publish_state(0);
                    en_mov_8->publish_state(0);
                    en_occ_0->publish_state(0);
                    en_occ_1->publish_state(0);
                    en_occ_2->publish_state(0);
                    en_occ_3->publish_state(0);
                    en_occ_4->publish_state(0);
                    en_occ_5->publish_state(0);
                    en_occ_6->publish_state(0);
                    en_occ_7->publish_state(0);
                    en_occ_8->publish_state(0);
                    brightness->publish_state(0);
                    presence_state = false;
                    bytes.clear();
                else
                    bytes.clear();
            else if (HeaderMatched(bytes, header_parameter))
                if (bytes.size() < 11 + sizeof(PARAMETER))
                    continue;
                PARAMETERUnion parameterUnion;
                std::copy(bytes.begin() + 11, (bytes.begin() + 11 + sizeof(PARAMETER)), parameterUnion.bytes);
                // ESP_LOGI("custom", "Sending Parameters");
                                id(max_distance).publish_state(parameterUnion.parameter.max_distance * 0.75 );            // 最大距离门
                                id(max_mov_distance).publish_state(parameterUnion.parameter.max_mov_distance * 0.75 );    // 配置最大运动距离门
                                id(max_occ_distance).publish_state(parameterUnion.parameter.max_occ_distance * 0.75 );    // 配置最大静止距离门
                                id(mov_sn_distance_0).publish_state(parameterUnion.parameter.mov_sn_distance_0);          // 距离门0运动灵敏度,下同
                                id(mov_sn_distance_1).publish_state(parameterUnion.parameter.mov_sn_distance_1);
                                id(mov_sn_distance_2).publish_state(parameterUnion.parameter.mov_sn_distance_2);
                                id(mov_sn_distance_3).publish_state(parameterUnion.parameter.mov_sn_distance_3);
                                id(mov_sn_distance_4).publish_state(parameterUnion.parameter.mov_sn_distance_4);
                                id(mov_sn_distance_5).publish_state(parameterUnion.parameter.mov_sn_distance_5);
                                id(mov_sn_distance_6).publish_state(parameterUnion.parameter.mov_sn_distance_6);
                                id(mov_sn_distance_7).publish_state(parameterUnion.parameter.mov_sn_distance_7);
                                id(mov_sn_distance_8).publish_state(parameterUnion.parameter.mov_sn_distance_8);
                                id(occ_sn_distance_0).publish_state(parameterUnion.parameter.occ_sn_distance_0);           // 距离门0静止灵敏度,下同
                                id(occ_sn_distance_1).publish_state(parameterUnion.parameter.occ_sn_distance_1);
                                id(occ_sn_distance_2).publish_state(parameterUnion.parameter.occ_sn_distance_2);
                                id(occ_sn_distance_3).publish_state(parameterUnion.parameter.occ_sn_distance_3);
                                id(occ_sn_distance_4).publish_state(parameterUnion.parameter.occ_sn_distance_4);
                                id(occ_sn_distance_5).publish_state(parameterUnion.parameter.occ_sn_distance_5);
                                id(occ_sn_distance_6).publish_state(parameterUnion.parameter.occ_sn_distance_6);
                                id(occ_sn_distance_7).publish_state(parameterUnion.parameter.occ_sn_distance_7);
                                id(occ_sn_distance_8).publish_state(parameterUnion.parameter.occ_sn_distance_8);
                                id(none_duration).publish_state(parameterUnion.parameter.none_duration);
                bytes.clear();
/*       调试反馈用
            else if (HeaderMatched(bytes, header_feedback))
                if (bytes.size() < 6 + sizeof(FEEDBACK))
                    continue;
                FEEDBACKUnion feedbackUnion;
                std::copy(bytes.begin() + 6, (bytes.begin() + 6 + sizeof(FEEDBACK)), feedbackUnion.bytes);
                switch (feedbackUnion.feedback.command1)
                    case 254: //0xFE-配置结束
                        if (!feedbackUnion.feedback.result) ESP_LOGD("custom", "Config successed.");
                        else ESP_LOGI("custom", "!!!Config Failed!!!");
                        break;
                    case 96: //0x60-最大距离门与无人持续时间
                        if (!feedbackUnion.feedback.result) ESP_LOGD("custom", "Max distance setup successed.");
                        else ESP_LOGI("custom", "!!!Max distance setup Failed!!!");
                        break;
                    case 100: //0x64-距离灵敏度配置
                        if (!feedbackUnion.feedback.result) ESP_LOGD("custom", "Sensitivity setup successed.");
                        else ESP_LOGI("custom", "!!!Sensitivity setup Failed!!!");
                        break;
                    case 162: //0xA2-恢复出厂设置  旧版本无用
                        if (!feedbackUnion.feedback.result) ESP_LOGD("custom", "Set default successed.");
                        else ESP_LOGI("custom", "!!!Set default Failed!!!");
                        break;
                bytes.clear();
            else
                bytes.erase(bytes.begin());
                continue;
    typedef struct
        uint8_t max_distance;            // 最大距离门
                uint8_t max_mov_distance;        // 配置最大运动距离门
                uint8_t max_occ_distance;        // 配置最大静止距离门
                uint8_t mov_sn_distance_0;       // 距离门0运动灵敏度,下同
                uint8_t mov_sn_distance_1;
                uint8_t mov_sn_distance_2;
                uint8_t mov_sn_distance_3;
                uint8_t mov_sn_distance_4;
                uint8_t mov_sn_distance_5;
                uint8_t mov_sn_distance_6;
                uint8_t mov_sn_distance_7;
                uint8_t mov_sn_distance_8;
                uint8_t occ_sn_distance_0;       // 距离门0静止灵敏度,下同
                uint8_t occ_sn_distance_1;
                uint8_t occ_sn_distance_2;
                uint8_t occ_sn_distance_3;
                uint8_t occ_sn_distance_4;
                uint8_t occ_sn_distance_5;
                uint8_t occ_sn_distance_6;
                uint8_t occ_sn_distance_7;
                uint8_t occ_sn_distance_8;
                uint8_t none_duration;            // 无人持续时间
    } PARAMETER        ; // 参数
    typedef union
        PARAMETER parameter;
        uint8_t bytes[sizeof(PARAMETER)];
    } PARAMETERUnion;
    typedef struct
        uint8_t data_mode;     //数据类型 01-工程模式,02-基本
        uint8_t data_header;     //头部
        uint8_t target_state;     //目标状态
        uint8_t mov_distance1;   //运动目标距离
        uint8_t mov_distance2;
        uint8_t mov_energy;      //运动目标能量
        uint8_t occ_distance1;   //静止目标距离
        uint8_t occ_distance2;
        uint8_t occ_energy;      //静止目标能量
        uint8_t detect_distance1;     //探测距离
        uint8_t detect_distance2;
        //能量数据 工程模式下有效
        uint8_t en_mov_0;
        uint8_t en_mov_1;
        uint8_t en_mov_2;
        uint8_t en_mov_3;
        uint8_t en_mov_4;
        uint8_t en_mov_5;
        uint8_t en_mov_6;
        uint8_t en_mov_7;
        uint8_t en_mov_8;
        uint8_t en_occ_0;
        uint8_t en_occ_1;
        uint8_t en_occ_2;
        uint8_t en_occ_3;
        uint8_t en_occ_4;
        uint8_t en_occ_5;
        uint8_t en_occ_6;
        uint8_t en_occ_7;
        uint8_t en_occ_8;
        uint8_t brightness;
    } LDDATA;    //雷达探测数据
    typedef union
        LDDATA lddata;
        uint8_t bytes[sizeof(LDDATA)];
    } LDDATAUnion;
/*    调试用
    typedef struct
        uint8_t command1;     //指令
        uint8_t command2;     //指令
        uint8_t result;       //反馈
    } FEEDBACK;
    typedef union
        FEEDBACK feedback;
        uint8_t bytes[sizeof(FEEDBACK)];
    } FEEDBACKUnion;
参与人数 1金钱 +12 收起 理由
zxyny1989 + 12 高手,这是高手!
发表于 2023-6-13 19:55:50 | 显示全部楼层
厉害啊 太强了
cscs
发表于 2023-6-15 16:59:05 | 显示全部楼层
学习一下
发表于 2023-6-21 16:48:23 | 显示全部楼层
看看牛批
发表于 2023-6-28 18:01:59 | 显示全部楼层
学习学习!
发表于 2023-7-5 18:49:59 | 显示全部楼层
真好啊 这感觉非常的给力
GMT+8, 2025-9-14 03:09 , Processed in 0.948391 second(s), 12 queries , MemCached On.
