查看: 4245|回复: 9
[插件集成] 斐讯DC1插件for HomeAssistant 报错 求助
piww
发表于 2022-7-16 19:12:42 | 显示全部楼层 |阅读模式
谁能帮忙看看吗?
报错是这样的,到底是啥问题啊。。
Platform error switch.phicomm_dc1 - cannot import name 'SwitchDevice' from 'homeassistant.components.switch' (/usr/src/homeassistant/homeassistant/components/switch/__init__.py)
piww
 楼主| 发表于 2022-7-16 20:04:33 | 显示全部楼层
此错误来自自定义集成。
Logger: homeassistant.config
Source: custom_components/phicomm_dc1_switch/switch.py:16
Integration: phicomm_dc1_switch
First occurred: 19:55:58 (3 occurrences)
Last logged: 19:55:58
Platform error: switch
  File "/usr/src/homeassistant/homeassistant/config.py", line 877, in async_process_component_config
    platform = p_integration.get_platform(domain)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 618, in get_platform
    cache[full_name] = self._import_platform(platform_name)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 635, in _import_platform
    return importlib.import_module(f"{self.pkg_path}.{platform_name}")
  File "/usr/local/lib/python3.9/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 850, in exec_module
  File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
  File "/config/custom_components/phicomm_dc1_switch/switch.py", line 16, in <module>
    from homeassistant.components.switch import (SwitchDevice, PLATFORM_SCHEMA)
ImportError: cannot import name 'SwitchDevice' from 'homeassistant.components.switch' (/usr/src/homeassistant/homeassistant/components/switch/__init__.py)
发表于 2022-7-16 20:10:01 来自手机 | 显示全部楼层
建议用nodered吧 稳定多了 homekit还可以直接显示为一个插座
发表于 2022-7-16 20:59:23 | 显示全部楼层
我直接刷机的,稳定好用
3万
发表于 2022-7-16 21:30:21 | 显示全部楼层
新版ha中已经弃用: SwitchDevice 这个了,需要修改,参考:
https://bbs.hassbian.com/thread-15285-1-1.html
piww
 楼主| 发表于 2022-7-18 10:10:24 | 显示全部楼层
有链接吗?我网上找了几个,不稳定啊。。。。我不是很想刷机,主要是要拆机,拆了就不帅了....
发表于 2022-7-18 10:13:11 | 显示全部楼层
刷机吧,一劳永逸,我5个都刷了
piww
 楼主| 发表于 2022-7-18 10:58:26 | 显示全部楼层
意思域名劫持的方案(非node)非常不稳定?
发表于 2022-9-8 11:41:43 | 显示全部楼层
楼主的问题解决了吗?我最近也在折腾DC1、M1,跟你一样不像刷机接入HA,如果已经解决,麻烦分享一下
piww
 楼主| 发表于 2023-2-6 15:43:58 | 显示全部楼层
FrankLiang 发表于 2022-9-8 11:41
楼主的问题解决了吗?我最近也在折腾DC1、M1,跟你一样不像刷机接入HA,如果已经解决,麻烦分享一下 ...
M1
DNS劫持:
方法可参考原插件。
劫持aircat.phicomm.com到ha地址。
DC1.zip
10.99 KB, 下载次数: 15
M1配置文件.zip
15.01 KB, 下载次数: 9
GMT+8, 2026-1-17 15:50 , Processed in 0.245148 second(s), 14 queries , MemCached On.
