楼主: lannister
[人体存在] 人体存在传感器1115H,可在线调参的配置文件[更新串口显示]
发表于 2022-7-20 16:12:42 | 显示全部楼层
ddddddddddddddd
发表于 2022-7-20 23:03:37 | 显示全部楼层
谢谢分享
发表于 2022-7-21 07:43:06 | 显示全部楼层
支持一下
发表于 2022-7-21 08:52:18 | 显示全部楼层
我来分享下红外。雷达、光照、温湿度和继电器环境下的配置 esp8266 12f1
# GPIO-14 红外 板载D5
# GPIO-5  开关继电器 D1
# GPIO-12 雷达 板载D6
# GPIO-13 温湿度 板载D7
# GPIO-1  SDA 板载D10
# GPIO-3  SCL 板载D9
# SR312红外传感器触发释出高电平3.3V,输入2.7V-12V
# LD1115H雷达传感器触发释出高电平3.2V,输入5V
# BH1750输入3V-5V
# ESP8266-12F输入4.5V-9V
substitutions:
  area: kewei                     #家庭区域
  board: esp8266                     #芯片型号
  devicename: $area-$board-light      #设备名称
  friendly_name: $devicename        #友好名称
# Example configuration entry
esphome:
  includes:
    - uart_read_line_sensor.h
esp8266:
  board: esp01_1m
  restore_from_flash: true
# Enable logging
logger:
  # level: VERBOSE #makes uart stream available in esphome logstream
  # baud_rate: 0 #disable logging over uart
# Enable Home Assistant 接入API
api:
# Enable Home Assistant OTA接入密码
ota:
  password: "angie"
wifi:
  networks:
  - ssid: !secret wifi_ssid             ##设置第一个WiFi;
  - ssid: SmartOS                       ##设置第二个WiFi;
    password: angie
# Optional manual IP
  manual_ip:
    static_ip: 10.10.10.41               ##固定此设备IP地址;
    gateway: 10.10.10.1                 ##路由器、网关地址;
    subnet: 255.255.255.0               ##子网掩码;
  ap:
    ssid: $devicename                  ##设置AP模式热点名称;
    password: "angie"
captive_portal:
web_server:                            ## web控制,添加了这2行,就可以在网页端打开设备ip;
  port: 80
globals:
  - id: my_global_int
    type: int
    restore_value: no
    initial_value: '0'
uart:
  rx_pin: 2
  tx_pin: 4
  baud_rate: 115200
i2c:
  sda: GPIO1                           ##映射TX到GPIO1-SDA;
  scl: GPIO3                           ##映射RX到GPIO3-SCL;
  scan: True
switch:
  - platform: gpio
    name: "客卫传感器 人体存在"      #主开关
    icon: "mdi:electric-switch"
    pin: GPIO5
number:
  - platform: template
    name: "客卫传感器 th1 移动灵敏度"
    mode: box
    optimistic: true
    min_value: 0
    max_value: 500
    step: 1
    restore_value: true
    initial_value: 120
    on_value:
      then:
      - uart.write: !lambda
          int v = (int)x;
          std::string cmd = "th1=" + to_string(v);
          return std::vector<unsigned char>(cmd.begin(), cmd.end());
      - delay: 100ms
      - uart.write: "save"
      - logger.log:
          format: "th1 is %.1f"
          args: [ 'id(motion_th1).state' ]
    name: "客卫传感器 th2 存在灵敏度"
    mode: box
    optimistic: true
    min_value: 0
    max_value: 500
    step: 1
    restore_value: true
    initial_value: 250
    on_value:
      then:
          int v = (int)x;
          std::string cmd = "th2=" + to_string(v);
      - delay: 100ms
      - logger.log:
          format: "th2 is %.1f"
          args: [ 'id(motion_th2).state' ]
    name: "客卫传感器 occ 维持条件"
    disabled_by_default: true
    optimistic: true
    mode: box
    min_value: 1
    max_value: 100
    step: 1
    restore_value: true
    initial_value: 3
    on_value:
      then:
          int v = (int)x;
          std::string cmd = "occ_sn=" + to_string(v);
      - delay: 100ms
      - logger.log:
          format: "occ_sn set %.1f"
          args: [ 'id(occ_sn).state' ]
    name: "客卫传感器 gpio 检测延迟"
    icon: "mdi:clock-time-four"
    mode: box
    optimistic: true
    min_value: 1
    max_value: 300
    step: 1
    restore_value: true
    initial_value: 5
    on_value:
      then:
          int v = (int)x;
          std::string cmd = "dtime=" + to_string(v);
      - delay: 100ms
      - logger.log:
          format: "dtime set %.1f"
          args: [ 'id(motion_dtime).state' ]
    name: "客卫传感器 mov 触发条件"
    optimistic: true
    min_value: 1
    max_value: 100
    step: 1
    restore_value: true
    mode: box
    initial_value: 5
    on_value:
      then:
          int v = (int)x;
          std::string cmd = "mov_sn=" + to_string(v);
      - delay: 100ms
      - logger.log:
          format: "mov_sn set %.1f"
          args: [ 'id(mov_sn).state' ]
button:
  - platform: restart
    name: "客卫传感器 重启ESP 8266"
    on_press:
      - uart.write: "get_all"
  - platform: bh1750
    name: "客卫传感器 光强度illuminance"
    address: 0x23
    update_interval: 15s
  - platform: wifi_signal
    update_interval: 300s
  - platform: dht
    pin: GPIO13
    model: DHT11
    update_interval: 60s
    temperature:
      name: 客卫传感器 温度Temperature
      filters:
        - sliding_window_moving_average:
            window_size: 15
            send_every: 15
            send_first_at: 3
    humidity:
      name: 客卫传感器 湿度Humidity
      filters:
            window_size: 15
            send_every: 15
            send_first_at: 3
binary_sensor:
  - platform: gpio
    pin:
      number: 14                 #io1接人体感应器
      inverted: TRUE
      mode: INPUT
    device_class: motion
    filters:
      - invert:
      - delayed_on_off: 300ms
  - platform: gpio
    pin:
      number: 12
      mode: INPUT
      inverted: TRUE
    filters:
      - invert:
    on_press:                           #按下(有人),打开开关
      then:
        - if:
           condition:
            and:
              - sensor.in_range:
                  below: 10.0          #above超过  below低于
              - binary_sensor.is_on: pir312                   #同时满足红外人体感应器感应到人,和光强度低,才会打开开关
              - switch.is_off: relay
           then:
             - logger.log: "Detected somebody activity"
             - switch.turn_on: relay
           else:
             - logger.log: "There is no one around"
             - switch.turn_off: relay
    on_release:                         #松开(雷达检测不到人),关闭开关.
      then:
text_sensor:
- platform: custom
  lambda: |-
    auto my_custom_sensor = new UartReadLineSensor(id(uart_bus));
    App.register_component(my_custom_sensor);
    return {my_custom_sensor};
  text_sensors:
- platform: wifi_info
  ip_address:
    icon: "mdi:ip-network"
  ssid:
    icon: "mdi:network-pos"
  bssid:
    name: 客卫传感器 Router MAC地址
    icon: "mdi:router-network"
  mac_address:
- platform: version
  hide_timestamp: true
发表于 2022-7-21 10:30:07 | 显示全部楼层
请教大佬:“4、建议参数调好后就可以禁用 Rx 了” 是指把“串口输出”给禁用?
 楼主| 发表于 2022-7-21 10:59:52 来自手机 | 显示全部楼层
sxrcm 发表于 2022-7-21 10:30
请教大佬:“4、建议参数调好后就可以禁用 Rx 了” 是指把“串口输出”给禁用? ...
直接在UART中把 RX: 2 注释掉就好,这样就可以只写不读了。
主要是hass每秒接受一次消息没必要,日志全都是消息变更。其次上面配置8266用的是软UART,一直接收影响性能(虽然也没啥性能需求)
发表于 2022-7-21 11:07:28 | 显示全部楼层
主要是hass每秒接受一次消息没必要,日志全 ...
用的是Esp32板上的TX和RX,有必要关吗?
 楼主| 发表于 2022-7-21 11:32:19 | 显示全部楼层
如果不纠结 hass 里的日志一直变更,不关也可以
发表于 2022-7-21 12:01:36 | 显示全部楼层
明白了,谢谢楼主
发表于 2022-7-21 12:55:33 | 显示全部楼层
请问楼主,这个#include "esphome.h......."具体怎么用啊?
GMT+8, 2026-1-14 15:02 , Processed in 0.108272 second(s), 11 queries , MemCached On.
