查看: 3342|回复: 0
红外热像仪传感器模块 AMG88XX ESPHome 组件开发实践
发表于 2022-6-20 21:53:42 | 显示全部楼层 |阅读模式
前文见这里: 尝试利用红外热像仪传感器模块作人体存在检测
目前勉强可用,仅包括最基本的功能, 但是还有问题没有解决:
  • 传递红外温度矩阵数组还是用的临时解决方案: text sensor, 这个最多传递255个字符,而且还要base64编码,十分不爽
代码地址:  https://github.com/snowyu/esphome-components
使用方法
substitutions:
  # Name the device and it's entities
  device: amg8833
  device_name: amg8833_1
esphome:
  platform: ESP32
  board: esp32doit-devkit-v1
external_components:
  - source: github://snowyu/esphome-components
wifi:
  ssid: !secret wifi_ssid
  reboot_timeout: 20min
  # Enable fallback hotspot in case wifi connection fails
  ap:
    ssid: "$device_name Fallback Hotspot"
    password: !secret ap_password
logger:
api:
ota:
  password: !secret ota_password
  reboot_timeout: 2min
i2c:
#   sda: 21
#   scl: 22
#   scan: true
amg88xx:
  ir_camera:
    name: $device_name ir camera
  device_temperature:
    name: $device_name device temperature
如果使用 IR_Camera 需要安装  Thermal Vison 集成
然后修改HA configuration.yaml:
camera:
  - platform: thermal_vision
    name: Prototype Thermal Camera
    overlay: true
    pixel_sensor: sensor.amg8833_1_ir_camera
    auto_range: true
参与人数 2金钱 +10 收起 理由
sorrypqa + 5 大神666!
xuchida + 5 膜拜大神!
GMT+8, 2025-12-15 16:36 , Processed in 0.084845 second(s), 9 queries , MemCached On.
