查看: 6541|回复: 19
[求助] Terminal & SSH 选项卡如何配置?
发表于 2022-4-5 08:56:29 | 显示全部楼层 |阅读模式
如图,配置不好,就不能用putty登录ssh
 楼主| 发表于 2022-4-5 08:58:59 | 显示全部楼层
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] cli: applying...
[fix-attrs.d] cli: exited 0.
[fix-attrs.d] profile: applying...
[fix-attrs.d] profile: exited 0.
[fix-attrs.d] ssh: applying...
[fix-attrs.d] ssh: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] apks.sh: executing...
[cont-init.d] apks.sh: exited 0.
[cont-init.d] keygen.sh: executing...
[08:57:56] INFO: Restoring host keys...
[cont-init.d] keygen.sh: exited 0.
[cont-init.d] profile.sh: executing...
[cont-init.d] profile.sh: exited 0.
[cont-init.d] ssh.sh: executing...
[08:57:57] FATAL: You need to setup a login!
[cont-init.d] ssh.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
 楼主| 发表于 2022-4-5 09:00:44 | 显示全部楼层
[fix-attrs.d] done.
发表于 2022-4-5 09:11:03 | 显示全部楼层
[s6-init] ensuring use ...
找到你putty的安装目录,里面有一个puttygen.exe,运行后有一个generate,点击后生成一个key,将生成的key填入到SSH的配置authorized_keys:里面,其他不用动。  同时点击SAVE private key,将这个key 保存到一个文件夹内。 运行putty的安装目录下的pageant.exe,点击add key,选择刚才保存的key文件。就能看到电脑右下角状态栏内有个蓝色小电脑的图标了。 这个时候再运行putty,就能连接了。
发表于 2022-4-5 09:12:14 | 显示全部楼层
login as  那里输入 root 然后回车
 楼主| 发表于 2022-4-5 09:24:37 | 显示全部楼层
不行,还是报错
[fix-attrs.d] done.
[09:22:31] INFO: Restoring host keys...
[09:22:32] INFO: Setup authorized_keys
[cont-init.d] ssh.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[09:22:32] INFO: Starting Web Terminal...
[2022/04/05 09:22:32:4876] N: ttyd 1.6.3-3e37e33 (libwebsockets 4.2.1-v4.2.1)
[2022/04/05 09:22:32:4878] N: tty configuration:
[2022/04/05 09:22:32:4878] N:   start command: tmux -u new -A -s homeassistant bash -l
[2022/04/05 09:22:32:4878] N:   close signal: SIGHUP (1)
[2022/04/05 09:22:32:4878] N:   terminal type: xterm-256color
[2022/04/05 09:22:32:4878] N: LWS: 4.2.1-v4.2.1, loglevel 7
[2022/04/05 09:22:32:4878] N: NET CLI SRV H1 H2 WS ConMon IPV6-off
[2022/04/05 09:22:32:4899] N:    /usr/lib/libwebsockets-evlib_uv.so
[2022/04/05 09:22:32:5380] N:  Using foreign event loop...
[2022/04/05 09:22:32:5383] N:  ++ [wsi|0|pipe] (1)
[2022/04/05 09:22:32:5388] N:  ++ [vh|0|netlink] (1)
[2022/04/05 09:22:32:5390] N:  ++ [vh|1|default||8099] (2)
[2022/04/05 09:22:32:5392] N: lws_socket_bind: nowsi: source ads 0.0.0.0
[2022/04/05 09:22:32:5394] N:  ++ [wsi|1|listen|default||8099] (2)
[2022/04/05 09:22:32:5395] N:  Listening on port: 8099
[09:22:32] INFO: Starting the SSH daemon...
Server listening on 0.0.0.0 port 22.
Server listening on :: port 22.
Received disconnect from 192.168.2.40 port 51125:14: No supported authentication methods available [preauth]
Disconnected from authenticating user root 192.168.2.40
发表于 2022-4-5 10:01:09 | 显示全部楼层
发一下你的配置 端口先使用默认的22
 楼主| 发表于 2022-4-5 10:33:51 | 显示全部楼层
water3033 发表于 2022-4-5 09:11
找到你putty的安装目录,里面有一个puttygen.exe,运行后有一个generate,点击后生成一个key,将生成的ke ...
生成key,30分钟了,也没完成
发表于 2022-4-5 10:35:29 | 显示全部楼层
ha168 发表于 2022-4-5 10:33
生成key,30分钟了,也没完成
看绿条上面的说明,鼠标要在绿条下方的空白区域动一动
 楼主| 发表于 2022-4-5 10:37:06 | 显示全部楼层
water3033 发表于 2022-4-5 10:01
发一下你的配置 端口先使用默认的22
端口就是改成22222
其他没变
现在改成22,
GMT+8, 2025-12-20 16:47 , Processed in 1.205943 second(s), 7 queries , MemCached On.
