楼主: nyhx2013
[插件集成] 大佬们我的Xiaomi MIoT 集成连不上网怎么解决呢?
 楼主| 发表于 2022-4-2 17:41:40 | 显示全部楼层
gl695133087 发表于 2022-4-1 20:29
是不是开了类似AdGuard之类的广告过滤系统,会把小米的域名过滤掉。我之前就是这样,后来关闭ad了都还不行 ...
是的,我之前配置了一下,结果后续也是链接不上了
经过努力现在又正常了,解决方法是重装了个新的,结果旧的那个也可以了,就是这么神奇
发表于 2022-6-6 16:12:31 | 显示全部楼层
经过努力现在又正常了,解决方法是重装了个新的,结果 ...
我重装了也不行
发表于 2022-6-27 17:08:26 | 显示全部楼层
neroxps 发表于 2022-3-31 12:18
1 从淘宝api 拿下时间和本地时间到底对不对
2 就看看容器内能不能访问小米 api
然后截图 curl 的错误。
bash-5.1# curl http://api.m.taobao.com/rest/api3.do?api=mtop.common.getTimestamp | jq -r '.data.t' | awk '{print substr($0,1,9)}'
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   109  100   109    0     0    658      0 --:--:-- --:--:-- --:--:--   660
165632063
bash-5.1# curl -i -v https://api.io.mi.com
*   Trying 0.0.0.0:443...
* Connected to api.io.mi.com (127.0.0.1) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
*  CAfile: /etc/ssl/certs/ca-certificates.crt
*  CApath: none
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (OUT), TLS alert, unknown CA (560):
* SSL certificate problem: unable to get local issuer certificate
* Closing connection 0
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: https://curl.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
这是什么问题?
GMT+8, 2026-1-18 23:24 , Processed in 0.050048 second(s), 7 queries , MemCached On.
