查看: 5917|回复: 6
[已解决] zigbee2mqtt无法启动,sonoff zbbridge tasmota网关
发表于 2022-2-9 21:56:00 | 显示全部楼层 |阅读模式
zigbee2mqtt设置如下:其中192.168.1.115就是HA主机IP,mqtt是HA的addon,端口是1883.
192.168.1.26是sonoff zbmini tasmota zigbee网关地址,端口也是1883mqtt前面加了 [backcolor=var(--markdown-code-background-color, none)]' 这个符号,点击保存后会自动丢失符号。
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
  base_topic: zigbee2mqtt
  server: mqtt://192.168.1.115:1883
  user: mqtt
  password: mqtt
serial:
  port: tcp://192.168.1.26:1883
  adapter: ezsp
advanced:
  log_level: warn
  pan_id: 6754
  channel: 11
  network_key:
    - 1
    - 3
    - 5
    - 7
    - 9
    - 11
    - 13
    - 15
    - 0
    - 2
    - 4
    - 6
    - 8
    - 10
    - 12
    - 13
  availability_blocklist: []
  availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
  port: 8099
experimental: {}
availability: false
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: '-d -d'
  log: false
zigbee2mqtt错误日志如下:
<pre style="overflow-x: auto; white-space: pre-wrap; color: rgb(33, 33, 33); background-color: rgb(255, 255, 255);">[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] socat.sh: executing...
[19:36:05] INFO: <span class="fg-green" style="color: var(--success-color);">Socat not enabled, marking service as down</span>
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[19:36:07] INFO: <span class="fg-green" style="color: var(--success-color);">MQTT available, fetching server detail ...</span>
[19:36:07] INFO: <span class="fg-green" style="color: var(--success-color);">Previous config file found, checking backup</span>
[19:36:07] INFO: <span class="fg-green" style="color: var(--success-color);">Creating backup config in '/config/zigbee2mqtt/.configuration.yaml.bk'</span>
[19:36:08] INFO: <span class="fg-green" style="color: var(--success-color);">Adjusting Zigbee2mqtt core yaml config with add-on quirks ...</span>
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[19:36:11] INFO: <span class="fg-green" style="color: var(--success-color);">Handing over control to Zigbee2mqtt Core ...</span>
> [email protected] start
> node index.js
<span class="fg-red" style="color: var(--error-color);">Zigbee2MQTT:error</span> 2022-02-09 19:36:29: Error while starting zigbee-herdsman
<span class="fg-red" style="color: var(--error-color);">Zigbee2MQTT:error</span> 2022-02-09 19:36:29: Failed to start zigbee
<span class="fg-red" style="color: var(--error-color);">Zigbee2MQTT:error</span> 2022-02-09 19:36:29: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
<span class="fg-red" style="color: var(--error-color);">Zigbee2MQTT:error</span> 2022-02-09 19:36:29: Exiting...
<span class="fg-red" style="color: var(--error-color);">Zigbee2MQTT:error</span> 2022-02-09 19:36:29: Error: Error while opening socket
    at Socket.<anonymous> (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:257:24)
    at Socket.emit (events.js:412:35)
    at emitErrorNT (internal/streams/destroy.js:106:8)
    at emitErrorCloseNT (internal/streams/destroy.js:74:3)
    at processTicksAndRejections (internal/process/task_queues.js:82:21)
[19:36:29] INFO: <span class="fg-green" style="color: var(--success-color);">Handing over control to Zigbee2mqtt Core ...</span>
> node index.js</pre>
https://community.home-assistant ... up-anymore/336312/2
https://bbs.hassbian.com/forum.php?mod=viewthread&tid=13807
sonoff zbbridge上面的mqtt参数没有修改,不知道这里要不要改
MQTT.fx 1.7.1客户端连接sonoff zbbridge提示unable to connect to server 图像_2022-02-09_235111.png
sonoff zbbrdige刷机参考了这里:
https://www.zigbee2mqtt.io/advan ... sh-tasmota-zbbridge
https://zigbee.blakadder.com/Sonoff_ZBBridge.html
这两个教程看起来挺简单,按部就班照着做,HA的zigbee2mqtt还是无法运行。
发表于 2022-2-9 23:17:44 | 显示全部楼层
mqtt的IP啊。
我不生产技术,我只是技术的搬运工。
 楼主| 发表于 2022-2-9 23:30:11 | 显示全部楼层
mqtt://192.168.1.115:1883   是这个配置不对么?  这个是HA主机自带的 Mosquitto broker MQTT,主机IP是192.168.1.115,MQTT服务IP就也填了相同。 mqtt.JPG
tasmota的MQTT设置里默认Host是空白的,这个选项我也尝试填入 192.168.1.115,还是没能解决问题。
Tasmota设置MQTT的client我也尝试改过,user和password也填入过mqtt,也没用。我的HA主机mqtt对应的用户名和密码都是mqtt。
发表于 2022-2-10 01:24:01 | 显示全部楼层
Clark 发表于 2022-2-9 23:30
mqtt://192.168.1.115:1883   是这个配置不对么?  这个是HA主机自带的 Mosquitto broker MQTT,主机IP是1 ...
那就不晓得了,我的是好的。
我不生产技术,我只是技术的搬运工。
 楼主| 发表于 2022-2-10 02:12:18 来自手机 | 显示全部楼层
zxyny1989 发表于 2022-2-10 01:24
那就不晓得了,我的是好的。
你用的也是sonoff zbbridge tasmota和z2m吗
 楼主| 发表于 2022-2-12 18:52:46 | 显示全部楼层
参考了这个帖子,https://bbs.hassbian.com/thread-10540-1-1.html
在tasmota console输入命令
Backlog Weblog3; so65 1; Module 75
backlog rule1 on system#boot do TCPStart 8888 endon ; rule1 1 ;template {"NAME":"SonoffZHABridge","GPIO":[56,208,0,209,59,58,0,0,0,0,0,0,17],"FLAG":0,"BASE":18}; module 0
重新跑了一个HA,测试通过ZHA可以正常连接,然后将这台HA的ZHA删除以后。
在主HA上配置Z2M
serial:
  port: tcp://192.168.1.26:8888
  adapter: ezsp
按照这个参数配置,终于将Z2M服务跑起来了
发表于 2022-12-28 15:30:06 | 显示全部楼层
要打开重新刷?
GMT+8, 2025-12-18 15:04 , Processed in 1.285219 second(s), 9 queries , MemCached On.
