楼主: xuzuxiong
[智能传感] ESP32人体计数VL53L1x固件-esphome接入HA
 楼主| 发表于 2022-1-2 23:18:40 | 显示全部楼层
zeze247 发表于 2021-12-31 14:17
楼主连上roode8266这个SSID 打不开web配置界面,怎么配置
192.168.4.1      admin  admin
 楼主| 发表于 2022-1-2 23:16:42 | 显示全部楼层
源码发上来了
 楼主| 发表于 2022-1-2 23:15:32 | 显示全部楼层
substitutions:
  devicename: roode8266
  friendly_name: $devicename
external_components:
  refresh: always
  source:
    type: git
    url: https://github.com/Lyr3x/Roode
    ref: master
esphome:
  platform: ESP8266
  board: d1_mini
wifi:
  ssid: "HIKVISION"
  password: "12345678"
  ap:
    ssid: "roode8266"
# Enable Home Assistant API
ota:
api:
  reboot_timeout: 60min
  services:
    - service: set_counter
      variables:
        newCount: int
      then:
        - lambda: "id(roode_platform)->sendCounter(newCount);"
    - service: reset_counter
      then:
        - lambda: "id(roode_platform)->sendCounter(0);"
    - service: recalibrate
      then:
        - lambda: "id(roode_platform)->recalibration();"
    - service: set_max_threshold
      variables:
        newThreshold: int
      then:
        - lambda: "id(roode_platform)->set_max_threshold_percentage(newThreshold);id(roode_platform)->recalibration();"
    - service: set_min_threshold
      variables:
        newThreshold: int
      then:
        - lambda: "id(roode_platform)->set_min_threshold_percentage(newThreshold);id(roode_platform)->recalibration();"
web_server:
  port: 80
  auth:
    username: admin
    password: admin
# Enable logging
logger:
  level: INFO
i2c:
  sda: 0
  scl: 2
roode:
  i2c_address: 0x29
  update_interval: 100ms
  calibration:
    max_threshold_percentage: 85
    min_threshold_percentage: 5
    roi_calibration: true
  # manual:
  #   sensor_mode: 2
  #   roi_height: 16
  #   roi_width: 6
  #   manual_threshold: 1300
  #   timing_budget: 100
  invert_direction: false
  restore_values: false
switch:
  - platform: restart
binary_sensor:
  - platform: status
  - platform: roode
    presence_sensor:
  - platform: roode
    people_counter_sensor:
      name: $friendly_name people counter
    distance_sensor:
      filters:
        - delta: 10.0
    max_threshold_zone0:
      name: $friendly_name max zone 0
    max_threshold_zone1:
      name: $friendly_name max zone 1
    min_threshold_zone0:
      name: $friendly_name min zone 0
    min_threshold_zone1:
      name: $friendly_name min zone 1
    roi_height:
      name: $friendly_name ROI height
    roi_width:
      name: $friendly_name ROI width
  - platform: wifi_signal
    update_interval: 60s
  - platform: uptime
    internal: true
    on_raw_value:
      then:
        - text_sensor.template.publish:
            state: !lambda |-
              int seconds = round(id(uptime_sensor).raw_state);
              int days = seconds / (24 * 3600);
              seconds = seconds % (24 * 3600);
              int hours = seconds / 3600;
              seconds = seconds % 3600;
              int minutes = seconds /  60;
              seconds = seconds % 60;
              return (
                (days ? String(days) + "d " : "") +
                (hours ? String(hours) + "h " : "") +
                (minutes ? String(minutes) + "m " : "") +
                (String(seconds) + "s")
              ).c_str();
text_sensor:
  - platform: roode
    version:
  - platform: roode
    entry_exit_event:
      name: $friendly_name last direction
  - platform: template
    name: $friendly_name Uptime Human Readable
    icon: mdi:clock-start
 楼主| 发表于 2022-1-2 23:14:15 | 显示全部楼层
substitutions:
  devicename: roodedev
  refresh: always
  source: components
esphome:
esp32:
  board: wemos_d1_mini32
  framework:
    type: arduino
wifi:
  ssid: "你的SSID"
  password: "你的密码"
  ap:
    ssid: "roodedev"#ap名称
    password: "12345678"#ap密码
captive_portal:
api:
  password: "12345678"#api密码
  services:
      variables:
        newCount: int
      then:
      then:
      then:
ota:
web_server:
  port: 80
  auth:
    username: admin
    password: admin
# Enable logging
logger:
  level: DEBUG
i2c:
  sda: 21
  scl: 22
roode:
  i2c_address: 0x29
  calibration:
# manual:
   # sensor_mode: 2
   # roi_height: 16
   # roi_width: 6
    #manual_threshold: 1300
    #timing_budget: 100
  restore_values: true
switch:
  - platform: restart
binary_sensor:
  - platform: status
  - platform: roode
    presence_sensor:
  - platform: roode
    distance_sensor:
      filters:
        - delta: 100.0
    roi_height:
    roi_width:
  - platform: uptime
    internal: true
    on_raw_value:
      then:
            state: !lambda |-
              return (
              ).c_str();
text_sensor:
  - platform: roode
    version:
  - platform: roode
    entry_exit_event:
发表于 2022-1-2 17:34:38 | 显示全部楼层
大佬,这个有源代码吗?
发表于 2021-12-31 14:17:04 | 显示全部楼层
发表于 2021-12-30 16:40:46 | 显示全部楼层
牛啊,正在寻找此类的解决方案
发表于 2021-12-30 13:38:58 | 显示全部楼层
厉害,感谢分享
发表于 2021-12-30 11:02:26 | 显示全部楼层
回帖奖励 +1 金钱
编译好的 esphome???
发表于 2021-12-29 18:08:35 | 显示全部楼层
谢谢大佬分享。
我不生产技术,我只是技术的搬运工。
GMT+8, 2026-1-14 08:12 , Processed in 1.586951 second(s), 11 queries , MemCached On.
