楼主: ekingfan
[已解决] MicroPython ESP32开发板 V1.0.0 Rev1 应该刷ESPHOME 哪一个文件?
 楼主| 发表于 2021-10-21 22:50:08 | 显示全部楼层
XCray 发表于 2021-10-21 17:30
自己试试喽,信不信由你!
谁说得8266也要几个文件的?我反正是没听说过。 ...
按你的帖子已经成功刷入,https://bbs.hassbian.com/thread-12842-1-1.html
下载ESP32工具在这里下载
https://www.espressif.com/en/support/download/other-tools
智能家居&单板滑雪痴迷爱好者
发表于 2021-10-21 23:29:19 来自手机 | 显示全部楼层
我那个帖子,曾帮助不止一个人解决了这个问题,说得也够清晰明了,却还是被你质疑,难啊!
 楼主| 发表于 2021-10-23 14:36:39 | 显示全部楼层
XCray 发表于 2021-10-21 23:29
我那个帖子,曾帮助不止一个人解决了这个问题,说得也够清晰明了,却还是被你质疑,难啊! ...
你要在标题里加上 权威 二字
另一个问题  我按ESP8266的代码方便加 PIR  DH11 但都不成功  就是不能检查, 5V 供电, 电池供电
  - platform: dht
    pin: 4
    temperature:
      name: "119 Living Room Temperature"
    humidity:
      name: "119 Living Room Humidity"
    update_interval: 5s
DH11 这样显示
[06:36:14][W][dht:162]: Requesting data from DHT failed!
[06:36:14][W][dht:060]: Invalid readings! Please check your wiring (pull-up resistor, pin number) and consider manually specifying the DHT model using the model option.
[06:36:14][D][sensor:092]: '119 Living Room Temperature': Sending state nan °C with 1 decimals of accuracy
[06:36:14][D][sensor:092]: '119 Living Room Humidity': Sending state nan % with 0 decimals of accuracy
[06:36:19][W][dht:162]: Requesting data from DHT failed!
[06:36:19][W][dht:060]: Invalid readings! Please check your wiring (pull-up resistor, pin number) and consider manually specifying the DHT model using the model option.
[06:36:19][D][sensor:092]: '119 Living Room Temperature': Sending state nan °C with 1 decimals of accuracy
[06:36:19][D][sensor:092]: '119 Living Room Humidity': Sending state nan % with 0 decimals of accuracy
[06:36:24][W][dht:162]: Requesting data from DHT failed!
[06:36:24][W][dht:060]: Invalid readings! Please check your wiring (pull-up resistor, pin number) and consider manually specifying the DHT model using the model option.
[06:36:24][D][sensor:092]: '119 Living Room Temperature': Sending state nan °C with 1 decimals of accuracy
[06:36:24][D][sensor:092]: '119 Living Room Humidity': Sending state nan % with 0 decimals of accuracy
智能家居&单板滑雪痴迷爱好者
发表于 2021-10-23 16:16:45 | 显示全部楼层
ekingfan 发表于 2021-10-23 14:36
你要在标题里加上 权威 二字
另一个问题  我按ESP8266的代码方便加 PIR  DH11 但都不成功  就是不能 ...
我不能那么不要脸吧?自己给自己加封“权威”???
pir和dht11我都用过,没见过你这个错误提示,建议换个引脚试试
 楼主| 发表于 2021-10-23 21:41:40 | 显示全部楼层
pir和dht11我都用过,没见过你这个错误提示,建议换 ...
不加权威 可以加 推荐 或者强烈推荐 ,
对了 大神,请问能不能贴出 你的ESP32 的pir 或者DH11 代码?
我换了好几个GPIO 都不行,一样不能得到数据 ,是不是刷的固件有问题? 要再刷一次对应该ESP32芯片型号?ESPHOME 中你是选择哪一种芯片的?
智能家居&单板滑雪痴迷爱好者
发表于 2021-10-23 21:57:19 | 显示全部楼层
没用!说的再苦口婆心,有人照样听不进去、或即使得到了帮助也不领情!
有些人对自己蜜汁自信
有些人瞎听瞎信
有些人玻璃心巨婴
有些人缺少感恩之心甚至基本礼貌
有些人素质低下一言不合就翻脸乃至飙脏话
论坛大了,真的是啥鸟都有
不扯了~~~回到主题。
就是照文档来的基本配置,没啥特别需要注意的。
我怀疑你的gpio号没搞对,每种板子上的丝印和芯片内部的实际编号对应关系并不都是一样的,比如板子上印的20可能是gpio18,这得看具体数据。
要不就是传感器模块是坏的,换开发板、换传感器,多试试吧。
 楼主| 发表于 2021-10-24 17:45:33 | 显示全部楼层
有些人对自己蜜汁自信
最后我花了好多时间, 一个一个GIPO 地去验证,,居然只有一个GPIO 0 才能用DHT11,
我最后测试结果  PIR 接GPIO12 ,DHT11 接GPIO 0 ,能正常使用,貌似 不同GPIO接不同的设备会对 另一个设备有影响。我没有单独一个DHT11去试,我是两个设备同时使用的。
智能家居&单板滑雪痴迷爱好者
发表于 2021-10-24 18:35:27 | 显示全部楼层
我最后测试结果  PIR  ...
一般建议先把每个模块都测通了再组合。
另外你一直没说你的模块是什么样的,是只有一个dht11还是有个小电路板带着配套外围电路的。
gpio有复用的,有要求启动时低电平或高电平的,有要求下拉或上拉的,闹不清的时候只能用笨法子试
 楼主| 发表于 2021-10-24 21:51:13 | 显示全部楼层
XCray 发表于 2021-10-24 18:35
一般建议先把每个模块都测通了再组合。
另外你一直没说你的模块是什么样的,是只有一个dht11还是有个小 ...
1楼已经上图啊。。我一直就是这个模块啊。
PIR
PIR
智能家居&单板滑雪痴迷爱好者
发表于 2021-10-24 21:54:48 | 显示全部楼层
我说的明明是你的dht模块,你又把esp32模块贴了一遍
GMT+8, 2025-12-16 19:54 , Processed in 1.160533 second(s), 8 queries , MemCached On.
