查看: 3487|回复: 8
[基础教程] ubuntu 20.04 docker 安装后supervisor空白
发表于 2021-10-13 03:24:29 | 显示全部楼层 |阅读模式
安装不太顺利,一路排错,装完之后 supervisor是空白的
查看日志如下,有几个WARNING,找了几圈都没有解决办法
看其他UNSupported也可以运行,也排不出来。。
[cont-finish.d] executing container finish scripts...,
[cont-finish.d] done.,
[s6-finish] waiting for services.,
[s6-finish] sending all processes the TERM signal.,
[s6-finish] sending all processes the KILL signal and exiting.,
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.,
[s6-init] ensuring user provided files have correct perms...exited 0.,
[fix-attrs.d] applying ownership & permissions fixes...,
[fix-attrs.d] done.,
[cont-init.d] executing container initialization scripts...,
[cont-init.d] udev.sh: executing... ,
[19:14:16] INFO: Using udev information from host,
[cont-init.d] udev.sh: exited 0.,
[cont-init.d] done.,
[services.d] starting services,
[services.d] done.,
[19:14:16] INFO: Starting local supervisor watchdog...,
21-10-12 19:14:17 INFO (MainThread) [__main__] Initializing Supervisor setup,
21-10-12 19:14:17 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry,
21-10-13 03:14:17 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64,
21-10-13 03:14:17 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/amd64-hassio-supervisor with version 2021.10.0,
21-10-13 03:14:17 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token,
21-10-13 03:14:17 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE,
21-10-13 03:14:17 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete,
21-10-13 03:14:17 INFO (MainThread) [__main__] Setting up Supervisor,
21-10-13 03:14:17 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2,
21-10-13 03:14:18 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor,
21-10-13 03:14:18 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os,
21-10-13 03:14:23 WARNING (MainThread) [supervisor.dbus.agent] No OS-Agent support on the host. Some Host functions have been disabled.,
21-10-13 03:14:23 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1,
21-10-13 03:14:23 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1,
21-10-13 03:14:23 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1,
21-10-13 03:14:23 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1,
21-10-13 03:14:24 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager,
21-10-13 03:14:24 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc,
21-10-13 03:14:29 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.,
21-10-13 03:14:29 INFO (MainThread) [supervisor.host.info] Updating local host information,
21-10-13 03:14:29 INFO (MainThread) [supervisor.host.services] Updating service information,
21-10-13 03:14:29 INFO (MainThread) [supervisor.host.network] Updating local network information,
21-10-13 03:14:31 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information,
21-10-13 03:14:31 INFO (MainThread) [supervisor.host.manager] Host information reload completed,
21-10-13 03:14:31 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'},
21-10-13 03:14:31 INFO (MainThread) [supervisor.host.services] Reloading local service hassio-apparmor.service,
21-10-13 03:14:31 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2021.09.0,
21-10-13 03:14:31 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2021.06.0,
21-10-13 03:14:31 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf,
21-10-13 03:14:31 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2021.07.0,
21-10-13 03:14:31 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.06.0,
21-10-13 03:14:31 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2021.04.0,
21-10-13 03:14:31 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json,
21-10-13 03:14:31 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version 2021.10.4,
21-10-13 03:14:31 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets,
21-10-13 03:14:31 INFO (MainThread) [supervisor.os.manager] No Home Assistant Operating System found,
21-10-13 03:14:32 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot_exclude' is deprecated, 'backup_exclude' should be used instead. Please report this to the maintainer of AdGuard Home,
21-10-13 03:14:32 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot' is deprecated, 'backup' should be used instead. Please report this to the maintainer of UniFi Controller,
21-10-13 03:14:32 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository,
21-10-13 03:14:32 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository,
21-10-13 03:14:32 INFO (MainThread) [supervisor.store] Loading add-ons from store: 63 all - 63 new - 0 remove,
21-10-13 03:14:32 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons,
21-10-13 03:14:32 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files,
21-10-13 03:14:32 INFO (MainThread) [supervisor.discovery] Loaded 0 messages,
21-10-13 03:14:32 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions,
21-10-13 03:14:32 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP,
21-10-13 03:14:32 INFO (MainThread) [supervisor.resolution.check] System checks complete,
21-10-13 03:14:32 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP,
21-10-13 03:14:32 WARNING (MainThread) [supervisor.resolution.evaluations.base] Detected unsupported OS: Ubuntu 20.04.3 LTS (more-info: https://www.home-assistant.io/more-info/unsupported/os),
21-10-13 03:14:32 WARNING (MainThread) [supervisor.resolution.evaluations.base] OS-Agent is not correctly working (more-info: https://www.home-assistant.io/more-info/unsupported/os_agent),
21-10-13 03:14:32 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete,
21-10-13 03:14:32 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP,
21-10-13 03:14:32 INFO (MainThread) [__main__] Running Supervisor,
21-10-13 03:14:32 WARNING (MainThread) [supervisor.core] System running in a unsupported environment!,
21-10-13 03:14:32 INFO (MainThread) [supervisor.jobs] 'OSManager.mark_healthy' blocked from execution, no Home Assistant OS available,
21-10-13 03:14:32 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons,
21-10-13 03:14:32 INFO (MainThread) [supervisor.core] Supervisor reboot detected,
21-10-13 03:14:32 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled,
21-10-13 03:14:32 INFO (MainThread) [supervisor.core] Supervisor is up and running,
21-10-13 03:14:32 INFO (MainThread) [supervisor.host.info] Updating local host information,
21-10-13 03:14:32 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING,
21-10-13 03:14:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.PLUGIN,
21-10-13 03:14:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.CORE,
21-10-13 03:14:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM,
21-10-13 03:14:32 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None,
21-10-13 03:14:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE,
21-10-13 03:14:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON,
21-10-13 03:14:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR,
21-10-13 03:14:32 INFO (MainThread) [supervisor.host.services] Updating service information,
21-10-13 03:14:32 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING,
21-10-13 03:14:32 INFO (MainThread) [supervisor.host.network] Updating local network information,
21-10-13 03:14:32 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING,
21-10-13 03:14:32 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete,
21-10-13 03:14:43 WARNING (MainThread) [supervisor.host.network] Can't update connectivity information: Error: Timeout was reached,
21-10-13 03:14:43 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information,
21-10-13 03:14:43 INFO (MainThread) [supervisor.host.manager] Host information reload completed,
21-10-13 03:15:13 WARNING (MainThread) [supervisor.host.network] Can't update connectivity information: Error: Timeout was reached,
智能家居&单板滑雪痴迷爱好者
发表于 2021-10-13 06:47:37 | 显示全部楼层
参考:https://bbs.hassbian.com/thread-14225-1-1.html
如果自己不是可以分析问题解决问题 、对linux、docker、网络都比较熟悉的高手,真心不建议这种安装方式。
当然,有自虐倾向,或者自己实在愿意折腾的话,随意。
发表于 2021-10-13 11:21:24 | 显示全部楼层
写那么清楚了 自己随便工具哪个翻译翻译的事情
发表于 2021-10-13 11:52:57 | 显示全部楼层
supervisor手动安装的建议Debian,官网有详细的安装文档
发表于 2021-10-13 13:12:09 来自手机 | 显示全部楼层
直接下个hassos吧,难得折腾
发表于 2021-10-13 13:38:07 | 显示全部楼层
不支持ubuntu,ubuntu不要折腾了,支持debian11,我也是刚改成debian11
发表于 2021-10-13 20:41:45 | 显示全部楼层
用Debian吧,唯一支持的操作系统
 楼主| 发表于 2021-10-13 23:22:28 | 显示全部楼层
是不受支持,看了ubuntu很多人的也能出来。。
 楼主| 发表于 2021-10-14 00:14:03 | 显示全部楼层
要改了,之前看的教程是ubuntu,大佬有debian的教程吗
GMT+8, 2025-12-2 18:22 , Processed in 1.369644 second(s), 8 queries , MemCached On.
