楼主: diba.qiu
8266+ESPHOME+3xPZEM-004T家庭用電監控
 楼主| 发表于 2021-9-27 09:51:05 | 显示全部楼层
3038922 发表于 2021-9-26 21:13
关键是线咋接?是每个004T各自接两个引脚? 还是全部接D1 D2 ,004T全部并联起来?
單純並聯而已
发表于 2021-10-1 20:23:52 | 显示全部楼层
我改了下 想挂6个.结果读不到数据的.也不知道为啥.
用上位机测试004T正常的.我地址也设置了
我测试时候 是挂了一个.我看您地址是4开始的.我测试的那个是默认地址1.地址1是不是没法用的?
substitutions:
  device_name: energy
esphome:
  platform: ESP8266
  board: nodemcuv2
logger:
  baud_rate: 0 # (UART logging interferes with pzem)
  level: DEBUG
# Enable Home Assistant API
web_server:
  port: 80
captive_portal:
uart:
  - tx_pin: D1
    rx_pin: D2
    baud_rate: 9600
    stop_bits: 1
modbus:
binary_sensor:
  - platform: status
  - platform: pzemac
    energy:
      filters:
        - multiply: 0.002
      unit_of_measurement: kWh
      accuracy_decimals: 1
    current:
    voltage:
      filters:
        - multiply: 2
    frequency:
    power_factor:
    power:
      filters:
        - multiply: 2
      accuracy_decimals: 0
    update_interval: never
    address: 1
  - platform: pzemac
    energy:
      filters:
        - multiply: 0.002
    current:
    voltage:
      filters:
        - multiply: 2
    frequency:
    power_factor:
    power:
      filters:
        - multiply: 2
    address: 2
  - platform: pzemac
    energy:
      filters:
        - multiply: 0.002
    current:
    voltage:
      filters:
        - multiply: 2
    frequency:
    power_factor:
    power:
      filters:
        - multiply: 2
    address: 3
  - platform: total_daily_energy
    power_id: power_ac1
    icon: mdi:counter
    filters:
      - multiply: 0.001
    power_id: power_ac2
    icon: mdi:counter
    filters:
      - multiply: 0.001
    power_id: power_ac3
    icon: mdi:counter
    filters:
      - multiply: 0.001
  - platform: template
    icon: mdi:counter
    device_class: energy
    state_class: measurement
    lambda: |-
      return id(energy_ac1_daily).state + id(energy_ac2_daily).state + id(energy_ac3_daily).state ;
  - platform: pzemac
    energy:
      filters:
        - multiply: 0.002
    current:
    voltage:
      filters:
        - multiply: 2
    frequency:
    power_factor:
    power:
      filters:
        - multiply: 2
    address: 4
  - platform: pzemac
    energy:
      filters:
        - multiply: 0.002
    current:
    voltage:
      filters:
        - multiply: 2
    frequency:
    power_factor:
    power:
      filters:
        - multiply: 2
    address: 5
  - platform: pzemac
    energy:
      filters:
        - multiply: 0.002
    current:
    voltage:
      filters:
        - multiply: 2
    frequency:
    power_factor:
    power:
      filters:
        - multiply: 2
    address: 6
    power_id: power_ac4
    icon: mdi:counter
    filters:
      - multiply: 0.001
    power_id: power_ac5
    icon: mdi:counter
    filters:
      - multiply: 0.001
    power_id: power_ac6
    icon: mdi:counter
    filters:
      - multiply: 0.001
    icon: mdi:counter
    lambda: |-
      return id(energy_ac4_daily).state + id(energy_ac5_daily).state + id(energy_ac6_daily).state ;
  #SLOW SENSORS FOR HOME ASSISTANT#
  - platform: template #########################
    lambda: |-
      if (id(current_ac1).state) {
        return (id(current_ac1).state);
      } else {
        return 0;
    unit_of_measurement: A
    icon: "mdi:alpha-a-circle"
    update_interval: 60s
    lambda: |-
      if (id(current_ac2).state) {
        return (id(current_ac2).state);
      } else {
        return 0;
    lambda: |-
      if (id(current_ac3).state) {
        return (id(current_ac3).state);
      } else {
        return 0;
    lambda: |-
      if (id(current_ac4).state) {
        return (id(current_ac4).state);
      } else {
        return 0;
    lambda: |-
      if (id(current_ac5).state) {
        return (id(current_ac5).state);
      } else {
        return 0;
    lambda: |-
      if (id(current_ac6).state) {
        return (id(current_ac6).state);
      } else {
        return 0;
time:
  - platform: homeassistant
switch:
  - platform: restart
  - platform: uart
    data: [0x01, 0x42, 0x80, 0x11]
interval:
  - interval: 5s
    then:
      - lambda: "id(pzemac1).update();"
      - delay: 150ms
      - lambda: "id(pzemac2).update();"
      - delay: 150ms
      - lambda: "id(pzemac3).update();"
      - delay: 150ms
      - lambda: "id(pzemac4).update();"
      - delay: 150ms
      - lambda: "id(pzemac5).update();"
      - delay: 150ms
      - lambda: "id(pzemac6).update();"
发表于 2021-10-2 11:26:44 | 显示全部楼层
我直接刷您原版也读不出数据.但直接串口是可以刷的.是我只接一个测试的关系?必须三个全接满?然后奇葩的是我D1 D2反插就好了......这啥情况
我设置的D1 TX D2 RX啊
现在我D1接她RX D2 接他TX 有数据....虽然是错的.电压400V什么的....
 楼主| 发表于 2021-10-4 15:41:27 | 显示全部楼层
3038922 发表于 2021-10-2 11:26
我直接刷您原版也读不出数据.但直接串口是可以刷的.是我只接一个测试的关系?必须三个全接满?然后奇葩的是我 ...
我的代碼設置address456是因為我用esphome方案的有六顆pzem004t v3,分接兩顆nodemcu,另一顆就設定123,如此而已。(這六顆以外的pzem我則還留在tasmota,沒有轉)
我自己的測試心得: 同時接超過三顆就容易漏資料,所以我之前在另一篇回文中建議同時接三顆就好; 而D1D2反插的問題我好像也遇過,沒有太深究就是。
发表于 2021-10-4 23:50:42 | 显示全部楼层
diba.qiu 发表于 2021-10-4 15:41
我的代碼設置address456是因為我用esphome方案的有六顆pzem004t v3,分接兩顆nodemcu,另一顆就設定123, ...
我已经买了32了.就芯片类型改下,其他都不改么?8266 被我正负极反插烧了....
那个004T也被我反插过.也不晓得有没啥问题
发表于 2021-10-5 21:06:15 | 显示全部楼层
我已经换成ESP32了
似乎一切正常了
楼主可以备注下 如果并联 必须三个都通上220V电
不然是没数据的.
就没看懂为啥电压要 multiply :2
三相不是380V么
 楼主| 发表于 2021-10-6 17:23:42 | 显示全部楼层
3038922 发表于 2021-10-5 21:06
我已经换成ESP32了
似乎一切正常了
感謝提醒,電壓x2是因為台灣的家庭用電電壓是110V(單相三線),而我這個是用來監控220V空調的所以x2,已經備註上了
发表于 2021-10-6 19:48:02 | 显示全部楼层
diba.qiu 发表于 2021-10-6 17:23
感謝提醒,電壓x2是因為台灣的家庭用電電壓是110V(單相三線),而我這個是用來監控220V空調的所以x2,已經 ...
我测试了6路 ESP32.完全没数据.
然后我拔掉了三路.全部正常.都开始正常工作了.我不确定是我一二三路是不是有线没接好的关系.还是电源不能支持那么多设备的关系.
但感觉上是他底层轮询只能支持四路的样子.
顺便问下SLOW SENSORS这个东西干嘛用的?
减轻服务器负载么?我更新喜欢看实时信息.这个能删掉么?我是标准X64服务器 性能还行.
 楼主| 发表于 2021-10-7 11:19:17 | 显示全部楼层
3038922 发表于 2021-10-6 19:48
我测试了6路 ESP32.完全没数据.
然后我拔掉了三路.全部正常.都开始正常工作了.我不确定是我一二三路是不是 ...
超過四路建議用1A以上的供電,並設定不同的uart、modbus
slow sensor是為了減輕資料庫負擔,當然可以刪掉沒問題!
发表于 2021-10-7 13:04:59 | 显示全部楼层
slow sensor是為了減輕資料庫負擔,當然可以刪 ...
要怎么做才能让HOMEASSISTAN 的 能源 里,自动识别能耗选项?
我目前是直接导入 energy_acxxx_daily
但是 server 端无法识别,如何修改才能让server端识别?```
    icon: mdi:counter
    lambda: |-
      return id(energy_ac3_daily).state - id(energy_ac4_daily).state - id(energy_ac5_daily).state - id(energy_ac6_daily).state ;
GMT+8, 2026-1-16 12:22 , Processed in 1.133209 second(s), 9 queries , MemCached On.
