查看: 6426|回复: 7
[技术探讨] 二氧化碳scd30传感器接入esphome问题求助
innx 手机认证
发表于 2021-9-15 11:22:35 | 显示全部楼层 |阅读模式
一开始和这个贴主一样以为是可以支持,但是等到手后才发现有问题
https://bbs.hassbian.com/thread-10248-1-1.html
按贴主的方法,把scd304个文件放到docker的/config/.esphome/components/scd30
docker文件挂在路径
docker/config/:/config/
但是重新编译上传后依然data not ready yet!
不知道是不是文件的位置放错了?
esphome配置如下:
esphome:
  platform: ESP8266
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "5da7488be09bb8f14a5cd079ad8b5ebc"
wifi:
  ssid: "ha"
  password: "mimamima"
  ap:
    ssid: "Scd30 Fallback Hotspot"
    password: "0ATPoWFJh7u6"
captive_portal:
i2c:
  sda: 5
  scl: 4
  scan: true
  frequency: 50kHz
  - platform: scd30
    address: 0x61
    update_interval: 60s
    i2c_id: bus_a
    co2:
     name: ${upper_devicename} scd30 CO2
     accuracy_decimals: 1
    temperature:
     name: ${upper_devicename} scd30 Temperature
     accuracy_decimals: 2
    humidity:
     name: ${upper_devicename} scd30 Humidity
黑名单 icstow昵称朝廷心腹
innx 手机认证
 楼主| 发表于 2021-9-15 13:19:10 | 显示全部楼层
日志如下,看样子是找到了0x61的设备,但是之后数据还是没有获取到
INFO Reading configuration /config/scd30.yaml...
INFO Starting log output from scd30.local using esphome API
INFO Connecting to scd30.local:6053 (192.168.7.112)
INFO Successfully connected to scd30.local
[05:17:15][I][app:106]: ESPHome version 2021.8.2 compiled on Sep 15 2021, 03:01:26
[05:17:15][C][wifi:499]: WiFi:
[05:17:15][C][wifi:359]:   SSID: [redacted]
[05:17:15][C][wifi:360]:   IP Address: 192.168.7.112
[05:17:15][C][wifi:362]:   BSSID: [redacted]
[05:17:15][C][wifi:363]:   Hostname: 'scd30'
[05:17:15][C][wifi:367]:   Signal strength: -35 dB ▂▄▆█
[05:17:15][C][wifi:371]:   Channel: 1
[05:17:15][C][wifi:372]:   Subnet: 255.255.255.0
[05:17:15][C][wifi:373]:   Gateway: 192.168.7.1
[05:17:15][C][wifi:374]:   DNS1: 192.168.7.1
[05:17:15][C][wifi:375]:   DNS2: (IP unset)
[05:17:15][C][i2c:028]: I2C Bus:
[05:17:15][C][i2c:029]:   SDA Pin: GPIO5
[05:17:15][C][i2c:030]:   SCL Pin: GPIO4
[05:17:15][C][i2c:031]:   Frequency: 50000 Hz
[05:17:15][I][i2c:033]: Scanning i2c bus for active devices...
[05:17:15][I][i2c:040]: Found i2c device at address 0x61
[05:17:15][C][logger:189]: Logger:
[05:17:15][C][logger:190]:   Level: DEBUG
[05:17:15][C][logger:191]:   Log Baud Rate: 115200
[05:17:15][C][logger:192]:   Hardware UART: UART0
[05:17:15][C][scd30:100]: scd30:
[05:17:15][C][scd30:101]:   Address: 0x61
[05:17:15][C][scd30:119]:   Altitude compensation: OFF
[05:17:15][C][scd30:123]:   Automatic self calibration: ON
[05:17:15][C][scd30:124]:   Ambient pressure compensation: 0mBar
[05:17:15][C][scd30:125]:   Temperature offset: 0.00 °C
[05:17:15][C][scd30:126]:   Update Interval: 60.0s
[05:17:15][C][scd30:127]:   CO2 '${upper_devicename} scd30 CO2'
[05:17:15][C][scd30:127]:     State Class: 'measurement'
[05:17:15][C][scd30:127]:     Unit of Measurement: 'ppm'
[05:17:15][C][scd30:127]:     Accuracy Decimals: 1
[05:17:15][C][scd30:127]:     Icon: 'mdi:molecule-co2'
[05:17:15][C][scd30:128]:   Temperature '${upper_devicename} scd30 Temperature'
[05:17:15][C][scd30:128]:     Device Class: 'temperature'
[05:17:15][C][scd30:128]:     State Class: 'measurement'
[05:17:15][C][scd30:128]:     Unit of Measurement: '°C'
[05:17:15][C][scd30:128]:     Accuracy Decimals: 2
[05:17:15][C][scd30:129]:   Humidity '${upper_devicename} scd30 Humidity'
[05:17:15][C][scd30:129]:     Device Class: 'humidity'
[05:17:15][C][scd30:129]:     State Class: 'measurement'
[05:17:15][C][scd30:129]:     Unit of Measurement: '%'
[05:17:15][C][scd30:129]:     Accuracy Decimals: 1
[05:17:15][C][captive_portal:148]: Captive Portal:
[05:17:15][C][ota:029]: Over-The-Air Updates:
[05:17:15][C][ota:030]:   Address: scd30.local:8266
[05:17:15][C][ota:032]:   Using Password.
[05:17:15][C][api:095]: API Server:
[05:17:15][C][api:096]:   Address: scd30.local:6053
[05:17:22][W][scd30:142]: Data not ready yet!
黑名单 icstow昵称朝廷心腹
发表于 2021-9-15 14:01:33 | 显示全部楼层
是四十多入手的那个模块吗
innx 手机认证
 楼主| 发表于 2021-9-15 18:49:27 | 显示全部楼层
dizherui 发表于 2021-9-15 14:01
是四十多入手的那个模块吗
是的,有什么特别吗
黑名单 icstow昵称朝廷心腹
发表于 2021-9-15 18:55:22 | 显示全部楼层
innx 发表于 2021-9-15 18:49
是的,有什么特别吗
那个没有温湿度芯片的
innx 手机认证
 楼主| 发表于 2021-9-15 19:46:14 | 显示全部楼层
dizherui 发表于 2021-9-15 18:55
那个没有温湿度芯片的
感谢回复,我试着把co2后面的删除还是获取不到数据,求教
配置文件:
  - platform: scd30
    address: 0x61
    update_interval: 5s
    i2c_id: bus_a
    co2:
黑名单 icstow昵称朝廷心腹
innx 手机认证
 楼主| 发表于 2021-9-15 20:02:31 | 显示全部楼层
那个没有温湿度芯片的
对了  现在模块的SEL是接地的,看日志是扫描到地址的,但是就是没有数据很奇怪
黑名单 icstow昵称朝廷心腹
innx 手机认证
 楼主| 发表于 2021-9-15 20:31:44 | 显示全部楼层
INFO Generating C++ source...
INFO Compiling app...
INFO Running:  platformio run -d /config/scd30
Processing scd30 (board: esp01_1m; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
PACKAGES:
 - framework-arduinoespressif8266 3.20704.0 (2.7.4)
 - tool-esptool 1.413.0 (4.13)
 - tool-esptoolpy 1.20800.0 (2.8.0)
 - toolchain-xtensa 2.40802.200502 (4.8.2)
Library Manager: Installing Update
Library Manager: Already installed, built-in library
Dependency Graph
|-- <ESPAsyncTCP-esphome> 1.2.3
|   |-- <ESP8266WiFi> 1.0
|-- <ESPAsyncWebServer-esphome> 1.3.0
|   |-- <Hash> 1.0
|-- <ESP8266mDNS> 1.2
|-- <Wire> 1.0
|-- <DNSServer> 1.1.1
Compiling .pioenvs/scd30/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/api/api_pb2_service.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/api/list_entities.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/api/subscribe_state.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/api/user_services.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/api/util.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/i2c/i2c.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/logger/logger.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/ota/ota_component.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/scd30/scd30.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/sensor/automation.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/sensor/filter.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/sensor/sensor.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/wifi/wifi_component.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/wifi/wifi_component_esp32.cpp.o
Compiling .pioenvs/scd30/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling .pioenvs/scd30/src/esphome/core/application.cpp.o
Compiling .pioenvs/scd30/src/esphome/core/application_esp32.cpp.o
Compiling .pioenvs/scd30/src/esphome/core/application_esp8266.cpp.o
Compiling .pioenvs/scd30/src/esphome/core/color.cpp.o
Compiling .pioenvs/scd30/src/esphome/core/component.cpp.o
Compiling .pioenvs/scd30/src/esphome/core/controller.cpp.o
Compiling .pioenvs/scd30/src/esphome/core/esphal.cpp.o
Compiling .pioenvs/scd30/src/esphome/core/helpers.cpp.o
Compiling .pioenvs/scd30/src/esphome/core/log.cpp.o
Compiling .pioenvs/scd30/src/esphome/core/preferences.cpp.o
Compiling .pioenvs/scd30/src/esphome/core/scheduler.cpp.o
Compiling .pioenvs/scd30/src/esphome/core/util.cpp.o
Compiling .pioenvs/scd30/src/main.cpp.o
Generating LD script .pioenvs/scd30/ld/local.eagle.app.v6.common.ld
Compiling .pioenvs/scd30/lib4d9/ESP8266WiFi/BearSSLHelpers.cpp.o
Compiling .pioenvs/scd30/lib4d9/ESP8266WiFi/CertStoreBearSSL.cpp.o
Compiling .pioenvs/scd30/lib4d9/ESP8266WiFi/ESP8266WiFi.cpp.o
Compiling .pioenvs/scd30/lib4d9/ESP8266WiFi/ESP8266WiFiAP.cpp.o
Compiling .pioenvs/scd30/lib4d9/ESP8266WiFi/ESP8266WiFiGeneric.cpp.o
Compiling .pioenvs/scd30/lib4d9/ESP8266WiFi/ESP8266WiFiGratuitous.cpp.o
Compiling .pioenvs/scd30/lib4d9/ESP8266WiFi/ESP8266WiFiMulti.cpp.o
Compiling .pioenvs/scd30/lib4d9/ESP8266WiFi/ESP8266WiFiSTA-WPS.cpp.o
Compiling .pioenvs/scd30/lib4d9/ESP8266WiFi/ESP8266WiFiSTA.cpp.o
Compiling .pioenvs/scd30/lib4d9/ESP8266WiFi/ESP8266WiFiScan.cpp.o
Compiling .pioenvs/scd30/lib4d9/ESP8266WiFi/WiFiClient.cpp.o
Compiling .pioenvs/scd30/lib4d9/ESP8266WiFi/WiFiClientSecureAxTLS.cpp.o
Compiling .pioenvs/scd30/lib4d9/ESP8266WiFi/WiFiClientSecureBearSSL.cpp.o
Compiling .pioenvs/scd30/lib4d9/ESP8266WiFi/WiFiServer.cpp.o
Compiling .pioenvs/scd30/lib4d9/ESP8266WiFi/WiFiServerSecureAxTLS.cpp.o
Compiling .pioenvs/scd30/lib4d9/ESP8266WiFi/WiFiServerSecureBearSSL.cpp.o
Compiling .pioenvs/scd30/lib4d9/ESP8266WiFi/WiFiUdp.cpp.o
Compiling .pioenvs/scd30/lib189/ESPAsyncTCP-esphome/AsyncPrinter.cpp.o
Compiling .pioenvs/scd30/lib189/ESPAsyncTCP-esphome/ESPAsyncTCP.cpp.o
Compiling .pioenvs/scd30/lib189/ESPAsyncTCP-esphome/ESPAsyncTCPbuffer.cpp.o
Archiving .pioenvs/scd30/lib4d9/libESP8266WiFi.a
Compiling .pioenvs/scd30/lib189/ESPAsyncTCP-esphome/SyncClient.cpp.o
Compiling .pioenvs/scd30/lib189/ESPAsyncTCP-esphome/tcp_axtls.c.o
Compiling .pioenvs/scd30/lib6f5/Hash/Hash.cpp.o
Compiling .pioenvs/scd30/lib768/ESPAsyncWebServer-esphome/AsyncEventSource.cpp.o
Archiving .pioenvs/scd30/lib6f5/libHash.a
Compiling .pioenvs/scd30/lib768/ESPAsyncWebServer-esphome/AsyncWebSocket.cpp.o
Compiling .pioenvs/scd30/lib768/ESPAsyncWebServer-esphome/SPIFFSEditor.cpp.o
Archiving .pioenvs/scd30/lib189/libESPAsyncTCP-esphome.a
Compiling .pioenvs/scd30/lib768/ESPAsyncWebServer-esphome/WebAuthentication.cpp.o
Compiling .pioenvs/scd30/lib768/ESPAsyncWebServer-esphome/WebHandlers.cpp.o
In file included from /root/.platformio/lib/ESPAsyncWebServer-esphome/src/SPIFFSEditor.cpp:1:0:
/root/.platformio/lib/ESPAsyncWebServer-esphome/src/SPIFFSEditor.h:16:101: warning: 'SPIFFS' is deprecated (declared at /root/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/FS.h:269): SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
     SPIFFSEditor(const String& username=String(), const String& password=String(), const fs::FS& fs=SPIFFS);
Compiling .pioenvs/scd30/lib768/ESPAsyncWebServer-esphome/WebRequest.cpp.o
Compiling .pioenvs/scd30/lib768/ESPAsyncWebServer-esphome/WebResponses.cpp.o
Compiling .pioenvs/scd30/lib768/ESPAsyncWebServer-esphome/WebServer.cpp.o
Compiling .pioenvs/scd30/lib0d3/ESP8266mDNS/ESP8266mDNS.cpp.o
Compiling .pioenvs/scd30/lib0d3/ESP8266mDNS/ESP8266mDNS_Legacy.cpp.o
Compiling .pioenvs/scd30/lib0d3/ESP8266mDNS/LEAmDNS.cpp.o
Compiling .pioenvs/scd30/lib0d3/ESP8266mDNS/LEAmDNS_Control.cpp.o
Archiving .pioenvs/scd30/lib768/libESPAsyncWebServer-esphome.a
Compiling .pioenvs/scd30/lib0d3/ESP8266mDNS/LEAmDNS_Helpers.cpp.o
Compiling .pioenvs/scd30/lib0d3/ESP8266mDNS/LEAmDNS_Structs.cpp.o
Compiling .pioenvs/scd30/lib0d3/ESP8266mDNS/LEAmDNS_Transfer.cpp.o
Compiling .pioenvs/scd30/lib964/Wire/Wire.cpp.o
Compiling .pioenvs/scd30/lib760/DNSServer/DNSServer.cpp.o
Archiving .pioenvs/scd30/lib964/libWire.a
Archiving .pioenvs/scd30/libFrameworkArduinoVariant.a
Compiling .pioenvs/scd30/FrameworkArduino/Crypto.cpp.o
Archiving .pioenvs/scd30/lib760/libDNSServer.a
Compiling .pioenvs/scd30/FrameworkArduino/Esp-frag.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/Esp-version.cpp.o
Archiving .pioenvs/scd30/lib0d3/libESP8266mDNS.a
Compiling .pioenvs/scd30/FrameworkArduino/Esp.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/FS.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/FSnoop.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/IPAddress.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/MD5Builder.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/Print.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/Schedule.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/StackThunk.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/Stream.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/StreamString.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/Tone.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/TypeConversion.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/Updater.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/WMath.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/WString.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/abi.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/base64.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/cbuf.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/cont.S.o
Compiling .pioenvs/scd30/FrameworkArduino/cont_util.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_app_entry_noextra4k.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_eboot_command.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_features.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_flash_quirks.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_flash_utils.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_i2s.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_main.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_noniso.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_phy.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_postmortem.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_si2c.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_sigma_delta.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_spi_utils.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_timer.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_waveform.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_wiring.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_wiring_analog.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_wiring_digital.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_wiring_pulse.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_wiring_pwm.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/core_esp8266_wiring_shift.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/crc32.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/debug.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/flash_hal.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/gdb_hooks.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/heap.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/libb64/cdecode.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/libb64/cencode.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/libc_replacements.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/sntp-lwip2.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/spiffs/spiffs_cache.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/spiffs/spiffs_check.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/spiffs/spiffs_gc.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/spiffs/spiffs_hydrogen.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/spiffs/spiffs_nucleus.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/spiffs_api.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/sqrt32.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/time.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/uart.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/umm_malloc/umm_info.c.o
Compiling .pioenvs/scd30/FrameworkArduino/umm_malloc/umm_integrity.c.o
Compiling .pioenvs/scd30/FrameworkArduino/umm_malloc/umm_local.c.o
Compiling .pioenvs/scd30/FrameworkArduino/umm_malloc/umm_malloc.cpp.o
Compiling .pioenvs/scd30/FrameworkArduino/umm_malloc/umm_poison.c.o
Archiving .pioenvs/scd30/libFrameworkArduino.a
Linking .pioenvs/scd30/firmware.elf
Retrieving maximum program size .pioenvs/scd30/firmware.elf
Checking size .pioenvs/scd30/firmware.elf
RAM:   [====      ]  40.0% (used 32804 bytes from 81920 bytes)
Flash: [====      ]  39.1% (used 400628 bytes from 1023984 bytes)
Building .pioenvs/scd30/firmware.bin
Creating BIN file ".pioenvs/scd30/firmware.bin" using "/root/.platformio/packages/framework-arduinoespressif8266/bootloaders/eboot/eboot.elf" and ".pioenvs/scd30/firmware.elf"
========================= [SUCCESS] Took 61.50 seconds =========================
INFO Successfully compiled program.
INFO Resolving IP address of scd30.local
INFO  -> 192.168.7.112
INFO Uploading /config/scd30/.pioenvs/scd30/firmware.bin (404784 bytes)
Uploading: [============================================================] 100% Done...
INFO Waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
黑名单 icstow昵称朝廷心腹
GMT+8, 2025-12-2 20:10 , Processed in 1.237500 second(s), 10 queries , MemCached On.
