查看: 2642|回复: 2
[技术探讨] 【求助】新风插件报错:Component error: Integration not found
发表于 2021-8-17 16:55:40 | 显示全部楼层 |阅读模式
家里装了新风,可以通过RS485总线控制。
所以想参考大神的新风插件,依葫芦画瓢改改。(大神新风插件:https://bbs.hassbian.com/thread-5091-1-1.html
但集成一直报错:Component error: jing_yang - Integration 'jing_yang' not found.
请小伙伴们帮忙看下什么原因,多谢多谢。
configuration.yml:
jing_yang:
  host: 192.168.19.26   ## 设备的ip地址,支持域名
  port: 9999  ## 设备的端口号
custom_components/jing_yang/manifest.json
  "domain": "jing_yang",
  "name": "Fresh Air - JingYanng",
  "documentation": "https://www.example.com",
  "dependencies": [],
  "codeowners": [],
  "requirements": [],
  "version": "1.0"
custom_components/jing_yang/__init__.py
import socket
import struct
import voluptuous as vol
import homeassistant.helpers.config_validation as cv
import logging
from homeassistant.components.fan import SPEED_OFF, SPEED_LOW, SPEED_MEDIUM, SPEED_HIGH
from homeassistant.helpers.discovery import load_platform
DOMAIN = "jing_yang"
CONF_HOST = "host"
CONF_PORT = "port"
_LOGGER = logging.getLogger(__name__)
CONFIG_SCHEMA = vol.Schema(
        DOMAIN: vol.Schema(
                vol.Required(CONF_HOST): cv.string,
                vol.Required(CONF_PORT): cv.positive_int,
    extra=vol.ALLOW_EXTRA)
def setup(hass, config):
    hass.data["jing_yang"] = JingYang(hass, config[DOMAIN])
    jy = hass.data["jing_yang"]
    load_platform(hass, 'fan', DOMAIN, {}, config)
    jy.search()
    return True
class JingYang:
    def __init__(self, hass, domain_config):
        self._hass = hass
        self.config = domain_config
        self.host = domain_config[CONF_HOST]
        self.port = domain_config[CONF_PORT]
        self.state = None
        self.mode = None
        # air_quality [00:Great, 01:Good, 02:Bad]
        self.air_quality = None
        # speed [80:low, 81:medium, 82:high, 83:bypass, 84:auto_comfort, 85:auto_intelligent, 00ff]
        self.speed = None
        # alert state [00:no alert, 01:交换芯提醒, 02:过滤部件清洁更换提醒, 03:两者都有]
        self.alert = None
        self.temperature_inside = None
        self.humidity = None
        self.temperature_outside = None
        self.co2 = None
        #self.voc = None
        self.pm25 = None
        #self.formic_acid = None  # 甲醛
        self.speed_low = "AA01050101808866"
        self.speed_medium = "AA01050101818966"
        self.speed_high = "AA01050101828A66"
        self.turn_off_cmd = "AA01050101000866"
        self.bypass = "AA01050101838B66"
        self.auto_comfort = "AA01050101848c66"
        self.auto_intelligent = "AA01050101858D66"
        self.read_all_data = "aa010502000a1266"
    def send_cmd(self, cmd):
        try:
            _LOGGER.info("send cmd hex: " + str(cmd))
            cmd = bytes.fromhex(cmd)
            host = socket.gethostbyname(self.host)
            port = (host, self.port)
            s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
            s.settimeout(20)
            s.connect(port)
            s.send(cmd)
            _LOGGER.info("send cmd: " + str(cmd))
            message = s.recv(1024)
            s.settimeout(None)
            message = ''.join(['%02x' % b for b in message])
            s.close()
            _LOGGER.info("send cmd recv: " + str(message))
            return message
        except Exception as e:
            _LOGGER.info(e)
            return e
    def turn_on(self, mode, speed):
        self.state = "on"
        self.speed = speed
        if speed == SPEED_LOW:
            cmd = self.speed_low
        elif speed == SPEED_MEDIUM:
            cmd = self.speed_medium
        elif speed == SPEED_HIGH:
            cmd = self.speed_high
        else:
            self.speed = SPEED_LOW
            _LOGGER.info("turn on speed of unknown: " + str(speed))
        response = self.send_cmd(cmd)
        _LOGGER.info("components turn on: " + str(response))
    def turn_off(self):
        self.state = "off"
        self.speed = SPEED_OFF
        response = self.send_cmd(self.turn_off_cmd)
        _LOGGER.info("components turn off: " + str(response))
    def set_mode(self, mode):
        # forward 排风   reverse 换气
        if self.mode is None:
            self.search()
        if mode == "bypass":
            self.mode = "bypass"
            cmd = self.bypass
        else:
            return
        res = self.send_cmd(cmd)
        _LOGGER.info("set mode in jing_yang.py: " + str(res))
    def set_speed(self, speed_set):
        _LOGGER.info("components set speed: " + str(speed_set))
        if speed_set == SPEED_LOW:
        elif speed_set == SPEED_MEDIUM:
            self.speed = SPEED_MEDIUM
        elif speed_set == SPEED_HIGH:
            self.speed = SPEED_HIGH
        elif speed_set == SPEED_OFF:
            cmd = self.turn_off_cmd
        else:
            _LOGGER.warning("set speed of unknown: " + str(speed_set))
        _LOGGER.info("set speed in jing_yang.py: " + str(res))
    def search(self):
        response = self.send_cmd(self.read_all_data)
        _LOGGER.info("search: " + str(response))
        if not str(response).startswith("aa"):
            return
        air_quality_temp         = response[10:12]
        state_temp               = response[12]
        speed_temp               = response[13]
        mode_temp                = response[14]
        alert_temp               = response[15]
        temperature_inside_temp  = response[16:18]
        humidity_temp            = response[18:20]
        temperature_outside_temp = response[20:22]
        co2_temp                 = response[22:26]
        #voc_temp                 = response[26:28]
        pm25_temp                = response[28:32]
        #formic_acid_temp         = response[32:34]
        if air_quality_temp == "00":
            self.air_quality = "Great"
        elif air_quality_temp == "01":
            self.air_quality = "Good"
        elif air_quality_temp == "02":
            self.air_quality = "Bad"
        else:
            self.air_quality = self.air_quality
        if speed_temp == '0':
        elif speed_temp == '1':
        elif speed_temp == '2':
        elif speed_temp == '3':
            self.speed = "bypass"
        elif speed_temp == '4':
            self.speed = "Auto-Comportable"
        elif speed_temp == '5':
            self.speed = "Auto-intelligent"
        else:
            _LOGGER.warning("unknown speed: " + str(speed_temp))
        if state_temp == '0':
            self.state = "off"
        elif state_temp == '8':
            self.state = "on"
        else:
            _LOGGER.warning("unknown state: " + str(state_temp))
        if mode_temp == '0':
            self.mode = "standard"
        elif mode_temp == '8':
        else:
            _LOGGER.warning("unknown state: " + str(mode_temp))
        if alert_temp == "0":
            self.alert = "No Alert"
        elif alert_temp == "1":
            self.alert = "交换芯维护"
        elif alert_temp == "2":
            self.alert = "Filter Unit Clean"
        elif alert_temp == "3":
            self.alert = "交换芯/Filter Clean"
        else:
            _LOGGER.warning("unknown alert: " + str(alert_temp))
        temperature_inside_temp = bin(int(temperature_inside_temp, 16))[2:].rjust(8, "0")
        if temperature_inside_temp.startswith("0"):
            self.temperature_inside = int(temperature_inside_temp, 2)
        else:
            self.temperature_inside = -int(temperature_inside_temp[1:], 2)
        self.humidity = int(humidity_temp, 16)
        temperature_outside_temp = bin(int(temperature_outside_temp, 16))[2:].rjust(8, "0")
        if temperature_outside_temp.startswith("0"):
            self.temperature_outside = int(temperature_outside_temp, 2)
        else:
            self.temperature_outside = -int(temperature_outside_temp[1:], 2)
        co2_temp = co2_temp[2:] + co2_temp[:2]
        self.co2 = int(co2_temp, 16)
        #self.voc = int(voc_temp, 16)
        pm25_temp = pm25_temp[2:] + pm25_temp[:2]
        self.pm25 = int(pm25_temp, 16)
        #self.formic_acid = int(formic_acid_temp, 16)
        _LOGGER.info("air_quality: " + str(self.air_quality) +
                     " speed: " + str(self.speed) +
                     " mode: " + str(self.mode) +
                     " alert: " + str(self.alert) +
                     " temperature_inside: " + str(self.temperature_inside) +
                     " temperature_outside: " + str(self.temperature_outside) +
                     " humidity: " + str(self.humidity) +
                     " CO2: " + str(self.co2) +
                     " PM2.5: " + str(self.pm25))
custom_components/jing_yang/fan.py
import logging
from homeassistant.components.fan import (
    FanEntity, SPEED_OFF, SPEED_LOW, SPEED_MEDIUM, SPEED_HIGH, SUPPORT_SET_SPEED)
import custom_components.jing_yang as jing_yang
DEPENDENCIES = ['jing_yang']
DOMAIN = 'jing_yang'
ENTITYID = "fan." + DOMAIN
CONF_HOST = "host"
CONF_PORT = "port"
SPEED_MAPPING = {
    0: SPEED_OFF,
    1: SPEED_LOW,
    2: SPEED_MEDIUM,
    3: SPEED_HIGH
        DOMAIN: vol.Schema(
# Validation of the user's configuration
# PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
#     vol.Required(CONF_HOST): cv.string,
#     vol.Optional(CONF_PORT): cv.string,
def setup_platform(hass, config, add_devices, discovery_info=None):
    dev = []
    _LOGGER.info("setup platform")
    jing_yang = hass.data["jing_yang"]
    dev.append(JingYangFan(hass, config, jing_yang))
    add_devices(dev, True)
class JingYangFan(FanEntity):
    def __init__(self, hass, config, jing_yang):
        self._hass = hass
        self._config = config
        self.jing_yang = jing_yang
        self._name = "jing_yang"
        self._state = "off"
        self._mode = None
        self._speed = SPEED_OFF
        self._air_quality = None
        self._alert = None
        self._temperature_inside = None
        self._humidity = None
        self._temperature_outside = None
        self._co2 = None
        #self._voc = None
        self._pm25 = None
        #self._formic_acid = None
        self.speeds = []
    @property
    def name(self):
        """Return the name of the fan."""
        return self._name
    @property
    def speed(self):
        """Return the current speed."""
        return self._speed
    @property
    def icon(self):
        """Return the icon to use in the frontend."""
        return 'mdi:air-conditioner'
    @property
    def speed_list(self):
        """List of available fan modes."""
        return [SPEED_OFF, SPEED_LOW, SPEED_MEDIUM, SPEED_HIGH]
    @property
    def device_state_attributes(self):
        # self._state = self.jing_yang.state
        self._mode = self.jing_yang.mode
        self._air_quality = self.jing_yang.air_quality
        #self._speed = self.jing_yang.speed
        self._alert = self.jing_yang.alert
        self._temperature_inside = self.jing_yang.temperature_inside
        self._humidity = self.jing_yang.humidity
        self._temperature_outside = self.jing_yang.temperature_outside
        self._co2 = self.jing_yang.co2
        #self._voc = self.jing_yang.voc
        self._pm25 = self.jing_yang.pm25
        #self._formic_acid = self.jing_yang.formic_acid
        data = {"state": self._state,
                "mode": self._mode,
                "air_quality": self._air_quality,
                "speed": self._speed,
                "alert": self._alert,
                "temperature_inside": self._temperature_inside,
                "humidity": self._humidity,
                "temperature_outside": self._temperature_outside,
                "co2": self._co2,
                "pm2.5": self._pm25}
        return data
    def set_percentage(self, percentage: int) -> None:
        """Set the speed percentage of the fan."""
        if percentage == 0:
            self.turn_off()
        else:
            jingyang_speed = percentage_to_speed(percentage)
            self.set_speed(jingyang_speed)
    @property
    def is_on(self):
        """Return true if light is on."""
        _LOGGER.info("is on: " + str(self._state))
        self.jing_yang.search()
        return self._state not in ["off", None]
    def turn_off(self, *args, **kwargs):
        self.jing_yang.turn_off()
        if self.jing_yang.state == "off":
            self._state = "off"
    def turn_on(
        self,
        speed: str = None,
        percentage: int = None,
        preset_mode: str = None,
        **kwargs,
    ) -> None:
        """Turn on the fan."""
        if speed is None:
            speed = SPEED_LOW
        if percentage is not None:
            self.set_percentage(percentage)
        else:
            self.jing_yang.turn_on(None, speed)
        #self._state = self.jing_yang.state
    def set_speed(self, speed: str):
        if speed is None:
            self._speed = SPEED_LOW
            self.jing_yang.set_speed(self._speed)
        elif speed == SPEED_LOW:
            self._speed = SPEED_MEDIUM
            self._speed = SPEED_HIGH
        elif speed == SPEED_OFF or speed == "":
            self.turn_off()
        else:
            _LOGGER.info("set speed : " + speed + ". Warnning: Don't have this kind of speed")
        _LOGGER.info("set speed : " + speed + ", _speed: " + self._speed)
        return self._speed
    @property
    def percentage(self) -> int | None:
        if not self.is_on:
            return 0
        if self.speeds is None:
            return None
        return speed_to_percentage(self.speed)
    @property
    def supported_features(self) -> int:
        """Flag supported features."""
        return SUPPORT_SET_SPEED
jing_yang.zip
4.32 KB, 下载次数: 2
发表于 2021-8-17 17:23:28 | 显示全部楼层
我记得有某个版本以上ha自定义集成必须在manifest.json加入 "version",而且格式需要是"X.X.X"
记忆有些模糊,不知道正不正确。
 楼主| 发表于 2021-8-17 17:54:46 | 显示全部楼层
记忆有些模 ...
多谢回复。
刚把version改成0.0.1,还是报错。
  "dependencies": [],
  "codeowners": [],
  "requirements": [],
  "version": "0.0.1"
GMT+8, 2025-12-29 04:28 , Processed in 0.874656 second(s), 10 queries , MemCached On.
