楼主: involute
[插件集成] 让你的HomePod可以TTS?没有那么多麻烦
发表于 2021-10-19 10:38:21 | 显示全部楼层
involute 发表于 2021-10-19 00:09
9.X是否正常使用呢?暂不推荐使用dev版本的HA。
好的。我换一个看看
发表于 2021-10-19 16:20:37 | 显示全部楼层
报错证书问题,如何解决啊
此错误来自自定义集成。
Logger: homeassistant
Source: custom_components/apple_airplayer/media_player.py:110
Integration: Apple AirPlayer (documentation, issues)
First occurred: 16:19:30 (1 occurrences)
Last logged: 16:19:30
Error doing job: Task exception was never retrieved
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 969, in _wrap_create_connection
    return await self._loop.create_connection(*args, **kwargs)  # type: ignore  # noqa
  File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1081, in create_connection
    transport, protocol = await self._create_connection_transport(
  File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1111, in _create_connection_transport
    await waiter
  File "/usr/local/lib/python3.9/asyncio/sslproto.py", line 528, in data_received
    ssldata, appdata = self._sslpipe.feed_ssldata(data)
  File "/usr/local/lib/python3.9/asyncio/sslproto.py", line 188, in feed_ssldata
    self._sslobj.do_handshake()
  File "/usr/local/lib/python3.9/ssl.py", line 944, in do_handshake
ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: IP address mismatch, certificate is not valid for '192.168.31.2'. (_ssl.c:1129)
The above exception was the direct cause of the following exception:
  File "/config/custom_components/apple_airplayer/media_player.py", line 110, in async_play_stream
    r = await session.get(url)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/client.py", line 520, in _request
    conn = await self._connector.connect(
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 535, in connect
    proto = await self._create_connection(req, traces, timeout)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 892, in _create_connection
    _, proto = await self._create_direct_connection(req, traces, timeout)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 1051, in _create_direct_connection
    raise last_exc
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 1020, in _create_direct_connection
    transp, proto = await self._wrap_create_connection(
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 971, in _wrap_create_connection
    raise ClientConnectorCertificateError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorCertificateError: Cannot connect to host 192.168.31.2:8123 ssl:True [SSLCertVerificationError: (1, "[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: IP address mismatch, certificate is not valid for '192.168.31.2'. (_ssl.c:1129)")]
自行解决了问题,在配置文件中,内外网同一使用域名解决
发表于 2021-10-20 16:34:13 | 显示全部楼层
大佬 膜拜啊 通俗易懂
发表于 2021-10-21 21:39:27 | 显示全部楼层
HA版本 10.0.6,homepod 又发不出声音了,重启了系统也没用。之前还是好好的。
arch: armv7
channel: stable
docker: 20.10.8
features:
- reboot
- shutdown
- services
- network
- hostname
- timedate
hassos: null
homeassistant: 2021.10.6
hostname: raspberrypi
logging: info
machine: raspberrypi4
operating_system: Raspbian GNU/Linux 10 (buster)
state: running
supervisor: 2021.10.0
supported: false
supported_arch:
- armv7
- armhf
 楼主| 发表于 2021-10-21 22:10:25 | 显示全部楼层
你提供下日志我兴许能帮你分析下问题所在
发表于 2021-10-22 08:36:28 | 显示全部楼层
involute 发表于 2021-10-21 22:10
你提供下日志我兴许能帮你分析下问题所在
Logger: custom_components.apple_airplayer.device_manager
Source: custom_components/apple_airplayer/device_manager.py:127
First occurred: 08:55:38 (1 occurrences)
Last logged: 08:55:38
Exception raised in async_stream_file, RTSP/1.0 method ANNOUNCE failed with code 400: Bad Request
知道原因了,我家庭app设置的只允许共享此家庭的用户才能播放,关掉就好了,谢谢
 楼主| 发表于 2021-10-22 22:49:23 | 显示全部楼层
muxiachuixue 发表于 2021-10-22 08:36
知道原因了,我家庭app设置的只允许共享此家庭的用户才能播放,关掉就好了,谢谢 ...
嗯,本贴之前应该已经有人遇到过此问题了.
另外这个设置是在哪啊?我找都找不到
发表于 2021-10-25 08:58:11 | 显示全部楼层
另外这个设置是在哪啊?我找都找不到
homekit左上角-家庭设置-允许访问扬声器和电视
发表于 2021-10-26 23:24:08 | 显示全部楼层
學習學習中
发表于 2021-10-27 16:41:58 | 显示全部楼层
看看怎么用homepod
GMT+8, 2026-1-16 03:19 , Processed in 0.866398 second(s), 11 queries , MemCached On.
