楼主: rxwen
[插件集成] 小燕系统接入 homeassistant 插件
发表于 2022-6-15 07:26:05 | 显示全部楼层
Light
Switch
Curtain Motor
Smart Plug
Motion Sensor
Door Sensor
Temperature Sensor
Humidity Sensor
最新支持的产品
发表于 2022-7-14 02:11:09 | 显示全部楼层
更新版本后又不能用了,等老大解决。
发表于 2022-7-17 20:37:25 | 显示全部楼层
安裝最新版本的HA和插件,Temperature Sensor可以自動識別到HA裏邊去了,但Door Sensor沒在HA裏顯示出來是什麼原因呢?
发表于 2022-8-7 05:53:44 来自手机 | 显示全部楼层
青鸞可編程開關可接入HA並在HA「實現所有功能」嗎
发表于 2022-10-16 20:31:10 | 显示全部楼层
集成安装好后可使用,但homeassistant一旦重启,就出现错误如下:
Logger: root
Source: custom_components/terncy/hub_monitor.py:66
Integration: Terncy
First occurred: 20:26:44 (1 occurrences)
Last logged: 20:26:44
Uncaught thread exception
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_utils/asyncio.py", line 97, in run_coro_with_timeout
    return asyncio.run_coroutine_threadsafe(aw, loop).result(
  File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 448, in result
    raise TimeoutError()
concurrent.futures._base.TimeoutError
The above exception was the direct cause of the following exception:
  File "/usr/local/lib/python3.9/threading.py", line 973, in _bootstrap_inner
    self.run()
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_services/browser.py", line 533, in run
    self._fire_service_state_changed_event(event)
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_services/browser.py", line 416, in _fire_service_state_changed_event
    self._service_state_changed.fire(
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_services/__init__.py", line 55, in fire
    h(**kwargs)
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_services/browser.py", line 177, in on_change
    getattr(listener, _ON_CHANGE_DISPATCH[state_change])(zeroconf, service_type, name)
  File "/config/custom_components/terncy/hub_monitor.py", line 66, in add_service
    info = zconf.get_service_info(svc_type, name)
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_core.py", line 540, in get_service_info
    if info.request(self, timeout, question_type):
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_services/info.py", line 462, in request
    return bool(run_coro_with_timeout(self.async_request(zc, timeout, question_type), zc.loop, timeout))
  File "/usr/local/lib/python3.9/site-packages/zeroconf/_utils/asyncio.py", line 101, in run_coro_with_timeout
    raise EventLoopBlocked from ex
zeroconf._exceptions.EventLoopBlocked
发表于 2022-11-28 22:49:58 | 显示全部楼层
有什么办法可以不买网关,直接接入z2m吗?
发表于 2022-11-29 20:59:47 | 显示全部楼层
大佬能否支持一下光线传感器  感谢
发表于 2022-11-30 13:13:21 | 显示全部楼层
发表于 2023-9-4 10:05:25 | 显示全部楼层
我也是同样的问题,请问解决了吗?
GMT+8, 2026-1-16 12:26 , Processed in 0.062190 second(s), 11 queries , MemCached On.
