楼主: anlong
[插件集成] 小米MIoT设备自动识别接入HA插件 2024-04-30新版发布
发表于 2021-1-23 14:40:05 | 显示全部楼层
您好,请看看这个可以加进去吗
发表于 2021-1-23 13:18:04 | 显示全部楼层
活跃会员
发表于 2021-1-23 13:02:11 | 显示全部楼层
微波炉
raw_command get_prop
erties "[{'did': 'result', 'siid': 2, 'piid': 1}]"
INFO:miio.cliebug mode active
Running command raw_command
DEBUG:miio.protocol:Unable to decrypt, returning raw bytes: b''
DEBUG:miio.miioprotocol:Got a response: Container:
    data = Container:
        data = b'' (total 0)
        value = b'' (total 0)
        offset1 = 32
        offset2 = 32
        length = 0
    header = Container:
        data = b'!1\x00 \x00\x00\x00\x00\x07\x9b\x93?\x00\x13Q*' (total 16)
        value = Container:
            length = 32
            unknown = 0
            device_id = unhexlify('079b933f')
            ts = 1970-01-15 15:39:22
        offset1 = 0
        offset2 = 16
        length = 16
    checksum = b'\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff' (total 16)
DEBUG:miio.miioprotocoliscovered 079b933f with ts: 1970-01-15 15:39:22, token: b'ffffffffffffffffffffffffff
ffffff'
DEBUG:miio.miioprotocol:192.168.xx.xx:54321 >>: {'id': 1, 'method': 'get_properties', 'params': [{'did': 're
sult', 'siid': 2, 'piid': 1}]}
DEBUG:miio.miioprotocol:192.168.xx.xx:54321 (ts: 1970-01-15 15:39:23, id: 1) << {'id': 1, 'result': [{'did':
'result', 'siid': 2, 'piid': 1, 'code': -4004}], 'exe_time': 420}
[{'did': 'result', 'siid': 2, 'piid': 1, 'code': -4004}]
发表于 2021-1-23 12:24:22 | 显示全部楼层
大家的token都是哪里获取的呢?
发表于 2021-1-23 12:07:55 | 显示全部楼层
智米电热器不行吗
发表于 2021-1-23 11:49:10 | 显示全部楼层
电磁炉
dee28605 raw_command get_properties "[{'did': 'result', 'siid': 2, 'piid': 1}]"
    data = Container:
        offset1 = 32
        offset2 = 32
        length = 0
    header = Container:
        data = b'!1\x00 \x00\x00\x00\x00\x07(\xdb\x87\x00\x02^\xd8' (total 16)
        value = Container:
            length = 32
            unknown = 0
            device_id = unhexlify('0728db87')
            ts = 1970-01-02 19:09:12
        offset1 = 0
        offset2 = 16
        length = 16
f' (total 16)
DEBUG:miio.miioprotocoliscovered 0728db87 with ts: 1970-01-02 19:09:12, token:
b'ffffffffffffffffffffffffffffffff'
DEBUG:miio.miioprotocol:192.168.31.199:54321 >>: {'id': 1, 'method': 'get_proper
ties', 'params': [{'did': 'result', 'siid': 2, 'piid': 1}]}
DEBUG:miio.miioprotocol:192.168.31.199:54321 (ts: 1970-01-02 19:09:12, id: 1) <<
{'id': 1, 'result': [{'did': 'result', 'siid': 2, 'piid': 1, 'code': -4004}], '
exe_time': 160}
发表于 2021-1-23 11:38:45 | 显示全部楼层
电磁炉和小米榨汁机找不到实体
发表于 2021-1-23 11:23:33 | 显示全部楼层
这个牛P了,膜拜大佬ing
发表于 2021-1-23 11:14:16 | 显示全部楼层
学习学习。谢谢大佬分享
我不生产技术,我只是技术的搬运工。
发表于 2021-1-23 11:00:15 | 显示全部楼层
这个无敌了
GMT+8, 2026-1-12 08:59 , Processed in 1.787334 second(s), 11 queries , MemCached On.
