查看: 36425|回复: 13
[技术探讨] 求助HASS升级115后,博联红外如何学码?
发表于 2020-10-7 21:41:23 | 显示全部楼层 |阅读模式
求助大佬指导一下,HASS升级115后,博联红外如何学码?试了很多方法都失败了。博联RM Pro已经集成到HA了,直接在服务里调用,也不知道正确格式。谢谢~
我就是六神
活跃会员教程狂人灌水之王
发表于 2020-10-8 01:59:58 | 显示全部楼层
你清理下缓存,下面会有service的默认示例的,直接套进去就行。
直接用模板学习,改一下device的名称,然后就可以一个个的改command 名称了,对于切换类的按键 如power 还有个参数。
最后生成的文件在.storge文件夹里面
entity_id: remote.rmmini3_1_remote  #控制器
device: hisense #设备名称
command: Power #按键名
alternative: true  #是否是切换按键
timeout: 30
最后生成的是这样的
    "version": 1,
    "key": "broadlink_remote_b4430dcc3dae_codes",
    "data": {
        "PPTV": {
            "Power": [
                "JgBYAAABJpMTNxMSEzYTEhM3EhMTEhITEhMSExITEjcTNxITEjcSOBITEjcTEhI4EjcSExITExITNhMSEzcTEhITEjcTNxM2EwAFKwABJUsSAAw3AAEnSRMADQU=",
                "JgBYAAABJZQTNxITEjcTEhI4EhMRExMSEhMTEhMSEzcSNxMSEzcSNxITEjgSExI3EjgTEhITEhMSNxMSEzcSExITETgTNxI3EwAFKwABJkoSAAw3AAEmShMADQU="
            "Turn UP": "JgBQAAABJpMTNxMSEjcTEhI4EhMSExITERQSEhITEzcTNhMSEzcTNhMSEjgTNxISExITNxMSExISNxMSExITNxI3ExITNxI3EwAFKgABJ0oSAA0FAAAAAAAAAAA=",
            "Turn Down": "JgBQAAABJ5MTNhMSEzcTEhM2ExITEhITExITEhMSEzcSNxMSEjgSNxM3EjcTNxMSEhMSNxMSEhMTEhMSExITNhM3ExISOBI3EwAFKgABJksSAA0FAAAAAAAAAAA=",
            "Turn Right": "JgBQAAABJpMTNxMSEjgSEhI4ExISExMSExISExITEjcTNxITEjcTNxM2ExITNxMSExISNxMSExISExM3EhMSNxM3EhMSNxM3EgAFKwABJkoTAA0FAAAAAAAAAAA=",
            "Turn Left": "JgBQAAABJpQTNhMSEzcTEhI3ExITEhMSExITEhMSEzYTNxMSEzcSNxMSEhMTNxEUERMTNxMSExISNxM3EhMTNxI3ExITNxE4EgAFLAABJkoTAA0FAAAAAAAAAAA=",
            "Turn Back": "JgBQAAABJpMTNxITEjcTEhM3ExITEhITEhMSExITEjcTNxITEjcTNxITEhMSNxM3EjcTEhM3EhMSNxM3EhMSExITEjcTEhM3EgAFKwABJ0kTAA0FAAAAAAAAAAA=",
            "Home": "JgBYAAABJpMTNxMSEjgSEhM3ExITEhITExISExITEjcTNxMSEjcTNxM2EzcTEhI3EzcTEhI3EhMTEhMSEzcTEhITEjcTEhI4EgAFKwABJkoTAAw2AAEmShMADQU=",
            "Menu": "JgBQAAABJ5MSNxMSEjgSExI3ExITEhITExITEhITEjcTNxITEjcSOBITEjcTEhM3EjcTEhM3ExISNxMSEzcSExITEjcTEhI3EwAFKwABJ0kSAA0FAAAAAAAAAAA=",
            "Mute": [
                "JgBYAAABJ5MTNhMSEzcTEhI3ExISExITEhMSExMSEjcTNxMSEzcSNxM3EjcSExM3EjcSExMSExITEhMSEjcTEhMSEzcTNhM3EwAFKgABJksRAAw4AAEmShIADQU=",
                "JgBQAAABJpQSNxMSEjgTEhI3ExISExITEhMSExMSEzcSNxMSEzcSNxI4EjcSExM3EzYSExITExITEhMSEjgSExITETgTNxI3EwAFKwABJ0kTAA0FAAAAAAAAAAA="
            "OK": "JgBQAAABJ5MTNxISEjgSExM2ExISExITExITEhITEjgSNxMSEzcTNhMSExISExM3EhMSNxMSEhMSOBI3EzcTEhI3EhMTNxM2EwAFKwABJkoTAA0FAAAAAAAAAAA=",
            "Play": "JgBQAAABJ5MSNxMSEzcTEhI3ExISExMSExITEhMSEzcSNxMSEzcSNxITExITEhM3ERQROBITExISOBI3EzcSExI3EhMSOBI3EwAFKwABJkoTAA0FAAAAAAAAAAA=",
            "Source Select": "JgBQAAABJpQSNxMSEjgSExI3ExITEhMSExITEhITEzYTNxMSEjcTNxM2ExISExMSExITEhI4EhMRFBE4EzcSNxM3EjcSExM3EgAFKwABJkoTAA0FAAAAAAAAAAA=",
            "Volume UP": "JgBYAAABJpQSNxMSEjgSExI3ExITEhITEhMTEhITEjcSOBITEzYTNxMSEzYTEhI4ExITEhMSEhMSNxMSEzcSExI3EzcSNxM3EgAFKwABJkoTAAw2AAEnSRMADQU=",
            "Volume Down": "JgBQAAABJpQTNxITEjcTEhM3EhMRExMSExITEhITEzcTNhITEjgTNhI4EzcSExI3ExITEhMSEhMSExMSEjcTEhM3EzYTNxI3EgAFLAABJkoTAA0FAAAAAAAAAAA="
参与人数 2金钱 +16 收起 理由
姚远 + 8 在下对你的景仰犹如滔滔长江之水,连绵不绝.
ylfzl + 8 论坛有你更精彩!
 楼主| 发表于 2020-10-8 17:51:55 | 显示全部楼层
直接用模板学习,改一下device的名称,然后 ...
太感谢了,指导的真够清楚了。解决了大问题,果然是因为缓存的原类,并且告知了学习后的代码存放位置。再次感谢
发表于 2020-10-14 10:30:01 | 显示全部楼层
学习了,谢谢
ccc
发表于 2020-11-17 16:45:28 | 显示全部楼层
大佬,想请教一下,我现在获取到控制码了,但是在0.116版本下应该在哪个文件下去配置博联遥控器,怎么配置,才能让我把博联的这些遥控功能用起来,进而应用在homekit中呢?大神能否给讲解一下  万分感谢!!!
我就是六神
活跃会员教程狂人灌水之王
发表于 2020-11-30 21:53:10 | 显示全部楼层
ccc 发表于 2020-11-17 16:45
大佬,想请教一下,我现在获取到控制码了,但是在0.116版本下应该在哪个文件下去配置博联遥控器,怎么配 ...
如果是HK的话,建议使用Smartir 那个会更方便。
单独使用单个码的话,用脚本。参考Script
发表于 2020-12-3 00:27:18 | 显示全部楼层
ylfzl 发表于 2020-10-8 17:51
太感谢了,指导的真够清楚了。解决了大问题,果然是因为缓存的原类,并且告知了学习后的代码存放位置。再 ...
我有一点没搞懂 清理缓存在哪里?
发表于 2020-12-3 17:18:11 | 显示全部楼层
请问一下您提到的清理缓存的这个步骤应该在哪里操作?代码录入完成之后如何添加至configuration.yaml。能不能提供一个示例供参考一下。谢谢
发表于 2020-12-7 13:10:08 | 显示全部楼层
正困惑着呢,感谢你的提示
发表于 2020-12-9 23:22:50 | 显示全部楼层
模版学习是哪个?
GMT+8, 2026-1-20 01:38 , Processed in 0.474894 second(s), 10 queries , MemCached On.
