楼主: jiluxinqing
[插件集成] 云音乐4.0【支持播放本地音乐,断网也能听音乐哦】
 火.. [复制链接]
发表于 2020-8-7 13:10:05 | 显示全部楼层
发表于 2020-9-8 21:20:13 | 显示全部楼层
发现一个问题,需要修改media_player.py第65行为:api_config = ApiConfig(hass.config.path("custom_components/ha_cloud_music"))
2020-09-08 20:47:16 ERROR (MainThread) [homeassistant.components.media_player] Error while setting up ha_cloud_music platform for media_player
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 184, in _async_setup_platform
    await asyncio.shield(task)
  File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/config/custom_components/ha_cloud_music/media_player.py", line 65, in setup_platform
    api_config = ApiConfig(hass.config.path(".shaonianzhentan/ha_cloud_music"))
  File "/config/custom_components/ha_cloud_music/api_config.py", line 17, in __init__
    os.mkdir(_dir)
FileNotFoundError: [Errno 2] No such file or directory: '/config/.shaonianzhentan/ha_cloud_music'
另外我有mpd播放器在用的
  - platform: mpd
    host: 192.168.2.51
为啥云音乐配了识别不了
  - platform: ha_cloud_music
    api_url: http://192.168.2.51:3000
    mpd_host: 192.168.2.51
 楼主| 发表于 2020-9-9 10:33:27 | 显示全部楼层
evantalk 发表于 2020-9-8 21:20
发现一个问题,需要修改media_player.py第65行为:api_config = ApiConfig(hass.config.path(" ...
这个错误是因为配置目录改了导致的,我已经修复了这个错误
识别不了具体表现在哪里?具体可以看日志,连接到MPD会有日志显示的
http://github.com/shaonianzhentan
发表于 2020-9-9 21:59:43 | 显示全部楼层
捕获.JPG 这是现场
mpd日志正常:2020-09-09 21:47:04 INFO (SyncWorker_6) [mpd.base] Calling MPD connect('192.168.2.51', 6600, timeout=None)
倒是有数据库错误
2020-09-09 21:48:34 ERROR (Recorder) [homeassistant.components.recorder] Error adding event: (MySQLdb._exceptions.DataError) (1406, "Data too long for column 'event_data' at row 1")
[SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (%s, %s, %s, %s, %s, %s, %s, %s)]
[parameters: ('call_service', '{"domain": "media_player", "service": "play_media", "service_data": {"entity_id": "media_player.yun_yin_le", "media_content_id": "{\"index\":0,\"l ... (184273 characters truncated) ... \\\":373,\\\\\"url\\\\\":\\\\\"https://music.163.com/song/media/outer/url?id=18309240.mp3\\\\\"}]\"}", "media_content_type": "music_playlist"}}', 'LOCAL', datetime.datetime(2020, 9, 9, 13, 48, 34, 491258, tzinfo=<UTC>), datetime.datetime(2020, 9, 9, 13, 48, 34, 506228, tzinfo=<UTC>), '27860063f2a311eaa395835c6b1abf71', '6fdcbe90cbc44ab588dac7e0f79c2351', None)]
(Background on this error at: http://sqlalche.me/e/13/9h9h)
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1277, in _execute_context
    self.dialect.do_execute(
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/default.py", line 593, in do_execute
    cursor.execute(statement, parameters)
  File "/usr/local/lib/python3.8/site-packages/MySQLdb/cursors.py", line 206, in execute
    res = self._query(query)
  File "/usr/local/lib/python3.8/site-packages/MySQLdb/cursors.py", line 319, in _query
    db.query(q)
  File "/usr/local/lib/python3.8/site-packages/MySQLdb/connections.py", line 259, in query
    _mysql.connection.query(self, query)
MySQLdb._exceptions.DataError: (1406, "Data too long for column 'event_data' at row 1")
The above exception was the direct cause of the following exception:
  File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 377, in run
    self.event_session.flush()
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/session.py", line 2523, in flush
    self._flush(objects)
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/session.py", line 2664, in _flush
    transaction.rollback(_capture_exception=True)
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/util/langhelpers.py", line 68, in __exit__
    compat.raise_(
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/util/compat.py", line 178, in raise_
    raise exception
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/session.py", line 2624, in _flush
    flush_context.execute()
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/unitofwork.py", line 422, in execute
    rec.execute(self)
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/unitofwork.py", line 586, in execute
    persistence.save_obj(
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/persistence.py", line 239, in save_obj
    _emit_insert_statements(
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/persistence.py", line 1135, in _emit_insert_statements
    result = cached_connections[connection].execute(
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1014, in execute
    return meth(self, multiparams, params)
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/sql/elements.py", line 298, in _execute_on_connection
    return connection._execute_clauseelement(self, multiparams, params)
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1127, in _execute_clauseelement
    ret = self._execute_context(
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1317, in _execute_context
    self._handle_dbapi_exception(
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1511, in _handle_dbapi_exception
    util.raise_(
    raise exception
    db.query(q)
sqlalchemy.exc.DataError: (MySQLdb._exceptions.DataError) (1406, "Data too long for column 'event_data' at row 1")
发表于 2020-9-10 03:09:33 | 显示全部楼层
谢谢分享
需要测试一下
发表于 2020-9-10 10:36:07 | 显示全部楼层
加一个到ha里面看看效果。谢谢了。
 楼主| 发表于 2020-9-10 10:36:10 | 显示全部楼层
evantalk 发表于 2020-9-9 21:59
这是现场
mpd日志正常:2020-09-09 21:47:04 INFO (SyncWorker_6) [mpd.base] Calling MPD connect('192.1 ...
你最好阻止一下这个播放器记录到数据库,属性太多占用存储
eric 手机认证
卓越贡献
发表于 2020-9-11 08:22:04 | 显示全部楼层
感谢分享!!!家里只能用DLNA播放器。现在是没办法测试了。。
但是3.3好像最近也不能用了。。无法自动下一曲
发表于 2020-9-25 07:54:34 | 显示全部楼层
升级到115.2,无法使用了
挖煤的猫
发表于 2020-9-25 16:05:56 | 显示全部楼层
不错~~~~~~~~~~~~~~~
GMT+8, 2026-1-16 01:33 , Processed in 0.772341 second(s), 14 queries , MemCached On.
