楼主: 121665460
[经验分享] 更新0.113后完美实现云米浴霸的多种功能同时开启
发表于 2020-7-30 21:30:34 | 显示全部楼层
  - platform: xiaomi_miio_raw
    name: yunmi Bat Heater
    host: 192.168.1.22
    token: 71481a0c1425a37427845957ef6cc308
  - platform: mqtt
    state_topic: 'device/zdc1/68c63aa5c4de/sensor'
    unit_of_measurement: 'W'
    icon: 'mdi:gauge'
    value_template: '{{ value_json.power }}'
  - platform: mqtt
    unit_of_measurement: 'A'
    icon: 'mdi:gauge'
    value_template: '{{ value_json.current}}'
  - platform: mqtt
    unit_of_measurement: 'V'
    icon: 'mdi:gauge'
    value_template: '{{ value_json.voltage}}'
  - platform: mqtt
    # friendly_name: 温度--次卧
    state_topic: 'device/zm1/b0f8932575df/sensor'
    unit_of_measurement: '°C'
    icon: 'mdi:thermometer'
    value_template: '{{ value_json.temperature }}'
  - platform: mqtt
发表于 2020-7-30 21:59:10 | 显示全部楼层
Timeout fetching Home Assistant update data
下午9:39:49 – 更新提示 (ERROR)
Retrying in 15 minutes
下午9:39:49 – Meteorologisk institutt (Met.no) (ERROR)
https://aa015h6buqvih86i1.api.me ... cationforecast/1.9/ returned
下午9:39:49 – __main__.py (ERROR)
Setup of weather platform met is taking over 10 seconds.
下午9:39:48 – Weather (WARNING)
Error doing job: Task exception was never retrieved
下午9:39:39 – loader.py (ERROR)
Error setting up integration sensor - received exception
Setup failed for logbook: Could not set up all dependencies.
下午9:39:39 – setup.py (ERROR) - 消息首次出现在 下午9:39:34,显示了 3 次
Unable to set up dependencies of logbook. Setup failed for dependencies: recorder
Not connected with Hass.io / system too busy!
下午9:39:32 – Hass.io (WARNING)
Timeout on /supervisor/ping request
下午9:39:31 – Hass.io (ERROR)
Setup of recorder is taking over 10 seconds.
下午9:39:31 – __main__.py (WARNING) - 消息首次出现在 下午9:36:36,显示了 3 次
Setup failed for recorder: Integration failed to initialize.
下午9:39:12 – setup.py (ERROR)
Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed [SQL: CREATE INDEX ix_events_context_parent_id ON events (context_parent_id)] (Background on this error at: http://sqlalche.me/e/4xp6) (retrying in 3 seconds)
下午9:39:12 – recorder (ERROR) - 消息首次出现在 下午9:37:14,显示了 10 次
Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: CREATE INDEX ix_events_context_parent_id ON events (context_parent_id)] (Background on this error at: http://sqlalche.me/e/4xp6)
Adding columns context_parent_id to table events. Note: this can take several minutes on large databases and slow computers. Please be patient!
下午9:39:11 – recorder (WARNING) - 消息首次出现在 下午9:36:26,显示了 50 次
Database is about to upgrade. Schema version: 7
下午9:39:11 – recorder (WARNING) - 消息首次出现在 下午9:36:26,显示了 10 次
Waiting on integrations to complete setup: recorder
下午9:38:22 – bootstrap.py (WARNING) - 消息首次出现在 下午9:37:22,显示了 2 次
发表于 2020-7-30 22:01:59 | 显示全部楼层
版本是用一键HASSIO安装的 Home Assistant 0.112.4
各位大佬帮忙看看文体出在哪。。。难道是插件不兼容这个版本吗。。
 楼主| 发表于 2020-7-31 09:01:18 | 显示全部楼层
看日志sqlite有问题,删了.db重启试试
我就是六神
活跃会员教程狂人灌水之王
发表于 2020-8-1 05:08:10 | 显示全部楼层
gscsgscs 发表于 2020-7-29 10:48
我检查过了,只有一个sensor呀
你应该是多写了个域名~
发表于 2020-8-5 12:43:12 | 显示全部楼层
感谢,可以了,真的好用。。。。。。距离预想的全自动化又进了一大步。
我家还有个小鲸洗的智能马桶盖,可以接入米家,能感应到人是否坐在上面(人做上去会自动开启除臭风扇,离开马上关闭),很灵敏,我特别想实现人坐在马桶上,浴霸就自动开灯开换气,人一离开,延时几分钟自动关闭。但是马桶盖不开放联动。我打算把马桶盖拆了,把米家门窗感应器改装一下,检测除臭风扇是够通电,以此来判断是否有人坐在上面,不知道可不可行,大神有没有别的更好的办法。。
发表于 2020-8-5 15:22:27 | 显示全部楼层
jyz_0501 发表于 2020-8-1 05:08
你应该是多写了个域名~
多谢版主,搞定了~我是那个插件弄错了,一开始一个一个下载的,报错,后来打包下载就没有问题了
我就是六神
活跃会员教程狂人灌水之王
发表于 2020-8-5 20:51:59 | 显示全部楼层
我家还有个小鲸洗的智能马桶盖, ...
我家也有,没必要拆吧  这个防水性还是要考虑一下的,直接粘在旁边好了..让盖子和坐垫粘上门磁就行
发表于 2020-8-5 21:16:01 | 显示全部楼层
jyz_0501 发表于 2020-8-5 20:51
我家也有,没必要拆吧  这个防水性还是要考虑一下的,直接粘在旁边好了..让盖子和坐垫粘上门磁就行 ...
你也是小鲸洗的吗?我刚才已经拆了,不影响防水的,它里面关键主板已经做了防水了。刚才在某宝下单了DIY件,到货后试验一下,如果成功再来报告~~
我就是六神
活跃会员教程狂人灌水之王
发表于 2020-8-11 16:59:03 | 显示全部楼层
gscsgscs 发表于 2020-8-5 21:16
你也是小鲸洗的吗?我刚才已经拆了,不影响防水的,它里面关键主板已经做了防水了。刚才在某宝下单了DIY ...
还有DIY的?  真是什么都有呢~
GMT+8, 2026-1-18 15:53 , Processed in 0.267250 second(s), 9 queries , MemCached On.
