查看: 29879|回复: 15
[求助] N1 安装了hassio,发现空间很紧张,查看了主要是docker占用...
发表于 2020-6-14 17:27:29 | 显示全部楼层 |阅读模式
N1 安装了hassio,发现空间很紧张,查看了,主要是docker占用了太多的空间,有什么办法精简一下吗?
root@aml:/var# du -h --max-depth=1 /var/lib/docker
518M    /var/lib/docker/containers
4.0K    /var/lib/docker/tmp
4.0K    /var/lib/docker/swarm
20K     /var/lib/docker/plugins
11M     /var/lib/docker/image
4.0K    /var/lib/docker/trust
100K    /var/lib/docker/network
20K     /var/lib/docker/builder
72K     /var/lib/docker/buildkit
221M    /var/lib/docker/volumes
4.0K    /var/lib/docker/runtimes
4.0G    /var/lib/docker/overlay2
4.7G    /var/lib/docker
root@aml:/var# docker ps
CONTAINER ID        IMAGE                                       COMMAND                  CREATED             STATUS              PORTS        NAMES
6b59df250edd        homeassistant/aarch64-addon-samba:8.2       "/run.sh"                32 hours ago        Up 32 hours        addon_core_samba
df2bddd5754f        homeassistant/aarch64-addon-mosquitto:5.1   "/run.sh"                32 hours ago        Up 32 hours         0.0.0.0:1883-1884->1883-1884/tcp, 0.0.0.0:8883-8884->8883-8884/tcp   addon_core_mosquitto
3b59de63f441        homeassistant/aarch64-hassio-multicast:2    "/init"                  32 hours ago        Up 32 hours        hassio_multicast
22867c7d8542        58334140878b                                "/init /bin/bash -c …"   32 hours ago        Up 32 hours        hassio_cli
a86647ef50e9        homeassistant/aarch64-hassio-audio:14       "/init"                  32 hours ago        Up 32 hours        hassio_audio
10175fdbfe9f        homeassistant/aarch64-hassio-dns:9          "/init coredns -conf…"   32 hours ago        Up 32 hours        hassio_dns
72f583ca9e72        homeassistant/aarch64-hassio-supervisor     "/init"                  6 days ago          Up 32 hours        hassio_supervisor
07895c25bfc0        6a067af9c51b                                "/bin/entry.sh pytho…"   4 months ago        Up 32 hours        homeassistant
root@aml:/var# docker images
REPOSITORY                                TAG                 IMAGE ID            CREATED             SIZE
homeassistant/aarch64-hassio-supervisor   latest              9f0bd68a4b8a        9 days ago          324MB
homeassistant/aarch64-hassio-dns          9                   0f808e80607a        2 months ago        75.3MB
homeassistant/aarch64-hassio-cli          latest              58334140878b        2 months ago        44.5MB
homeassistant/aarch64-hassio-multicast    2                   881075aad65b        2 months ago        34.8MB
homeassistant/aarch64-hassio-audio        14                  4df97665705b        2 months ago        110MB
homeassistant/qemuarm-64-homeassistant    latest              6a067af9c51b        4 months ago        1.17GB
<none>                                    <none>              58906864277c        7 months ago        111MB
homeassistant/aarch64-addon-samba         8.2                 7ae46ce7ed40        8 months ago        66.4MB
homeassistant/aarch64-addon-mosquitto     5.1                 56b6964bab3a        8 months ago        37.3MB
上面这些镜像都是必须的吗,可以删除哪个吗?
发表于 2020-6-15 06:50:58 来自手机 | 显示全部楼层
我也一样,不能删除,删了hassio运行不正常了,n1一切都好,就是8g内存是硬伤
发表于 2020-6-15 11:02:37 | 显示全部楼层
docker system prune -a
删除没使用的镜像
 楼主| 发表于 2020-6-15 13:41:06 | 显示全部楼层
删除没使用的镜像
这个试过,没什么用,没精简到。用的镜像还是得用。
 楼主| 发表于 2020-6-15 13:42:44 | 显示全部楼层
ylilike 发表于 2020-6-15 06:50
我也一样,不能删除,删了hassio运行不正常了,n1一切都好,就是8g内存是硬伤 ...
这很伤,最近N1总是100%使用空间。导致不断的重启。
发表于 2020-6-15 21:11:25 | 显示全部楼层
我也重装N次,update都没敢弄,保存三天日志,占用70%
若然,一切若然~
发表于 2020-6-15 22:44:29 | 显示全部楼层
跑sd卡上吧,hassio的话,稳定运行好几个月了,sd卡上面
 楼主| 发表于 2020-6-16 12:23:52 | 显示全部楼层
N1可以插sd卡的吗?
发表于 2020-6-20 11:21:21 | 显示全部楼层
astonish921 发表于 2020-6-16 12:23
N1可以插sd卡的吗?
读卡器不就好了嘛,或者买个大容量的2.0 U盘
发表于 2020-7-4 09:18:09 来自手机 | 显示全部楼层
插U盘,改/etc/docker/daemon.json,把docker数据指向U盘
GMT+8, 2025-12-17 07:28 , Processed in 0.915455 second(s), 7 queries , MemCached On.
