楼主: lizhenkun
ravencore貌似没有了,想问一下新的haa固件json如何配置?感谢
 楼主| 发表于 2020-6-13 21:05:17 | 显示全部楼层
囧 发表于 2020-6-7 17:25
一直亮应该是可控硅烧了。
大神我可控硅和温控开关都换了,但还是常亮,想问一下还有其他啥问题的可能性吗?
发表于 2020-6-14 12:50:46 | 显示全部楼层
lizhenkun 发表于 2020-6-13 21:05
大神我可控硅和温控开关都换了,但还是常亮,想问一下还有其他啥问题的可能性吗? ...
我认为没有别的可能性了。
发表于 2020-8-30 22:01:45 | 显示全部楼层
Aiden1 发表于 2020-6-7 19:14
json是简单,我都弄了好几个开关了,我遇到的问题就是快速按开关七八次就死机或者就进入设置模式了 ...
快速按七八次好像就是进入设置模式的。。这是固件的设定。
Q: I made a mistake in the configuration file. How to access the device configuration page?
A: If you input a JSON configuration string that has errors, the device should enter Setup mode automatically and you should be able to access it at its IP address or Hostname.
Q: I want to change the device configuration. How to access the device config page?
A: To access the configuration page to change device JSON config, you need to put the device in Setup Mode. You can do that using any additional input for that (you can have a HomeKit/physical button for enabling setup mode) or by default by clicking the device button rapidly 7-10 times (in Home app or physically).
NOTE: If you make changes in your JSON that involve accessory types, number of used accessories or change the order of them, you must check Reset HomeKit ID from within setup mode and remove your device from HomeKit; and then you must pair it again.
发表于 2020-8-31 14:13:10 | 显示全部楼层
362442340 发表于 2020-8-30 22:01
快速按七八次好像就是进入设置模式的。。这是固件的设定。Q: I made a mistake in the configuration file ...
是的,我已经知道了
发表于 2020-8-31 19:45:04 | 显示全部楼层
Aiden1 发表于 2020-8-31 14:13
是的,我已经知道了
请问您配置好json跟wifi后等多久才能用呢? 我的运气好等半天才能用 运气不好。几天都用不了。。。是不是跟网络有关呢?
发表于 2020-8-31 20:13:53 | 显示全部楼层
362442340 发表于 2020-8-31 19:45
请问您配置好json跟wifi后等多久才能用呢? 我的运气好等半天才能用 运气不好。几天都用不了。。。是不是 ...
我配置完之后等个一分钟吧,要断电重启一次才能配对
GMT+8, 2025-12-20 13:19 , Processed in 1.237455 second(s), 14 queries , MemCached On.
