『瀚思彼岸』» 智能家居技术论坛
楼主: scry
[插件集成] 【240428更新】向日葵插座免刷机接入ha,支持本地控制
帖子
379
Rank: 3Rank: 3
 楼主| 发表于 2024-2-23 21:32:05 | 显示全部楼层
zws1023 发表于 2024-2-22 11:19
我有P1Pro和P2 还有一个C1Pro  测试下了,只能添加一个,如果添加多个,其他的就不能用,期待大佬修复 ...
贴一下调试日志,敏感信息注意打码
我测试用P1和两个C1pro可以正常控制
帖子
2664
Rank: 6Rank: 6
发表于 2024-2-26 10:52:25 | 显示全部楼层
也搞了一个c1 pro,成功添加,但是功能有点少,是真的少
帖子
Rank: 1
发表于 2024-3-6 15:18:03 | 显示全部楼层
多孔插座能用吗
帖子
Rank: 1
发表于 2024-3-13 10:32:07 | 显示全部楼层
账号 和短信都失败了    本地添加后不显示设备
帖子
379
Rank: 3Rank: 3
 楼主| 发表于 2024-3-14 11:28:48 | 显示全部楼层
可以贴一下调试日志嘛,sn注意打码
帖子
56
Rank: 2
发表于 2024-3-24 11:51:12 | 显示全部楼层
向日葵c2插座看不到电量显示,怎么搞,楼主。调试日志在哪里,我贴出来
帖子
379
Rank: 3Rank: 3
 楼主| 发表于 2024-3-24 20:45:32 | 显示全部楼层
先删除条目,点启用调试日志,再点添加条目重新添加一下插座,然后禁用调试日志,sn注意打码
帖子
56
Rank: 2
发表于 2024-3-25 20:28:33 | 显示全部楼层
删不掉。。。报错了
帖子
56
Rank: 2
发表于 2024-3-25 20:29:45 | 显示全部楼层
2024-03-25 20:24:24.411 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 543, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 114, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 91, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 25, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 79, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 235, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 31, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 68, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 93, in delete
    result = await hass.config_entries.async_remove(entry_id)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1443, in async_remove
    del self._entries[entry.entry_id]
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1324, in __delitem__
    self._unindex_entry(entry_id)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1311, in _unindex_entry
    self._domain_index[domain].remove(entry)
KeyError: 'sunlogin'
帖子
379
Rank: 3Rank: 3
 楼主| 发表于 2024-3-25 21:37:28 | 显示全部楼层
Traceback (most ...
你会修改ip吗,给插座分配一个新的ip,能多次添加同一个插座
先开调试日志,再点添加条目
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-5-19 10:15 , Processed in 0.089824 second(s), 32 queries .
Powered by Discuz! X3.4
